ZX7R problems (carb icing??)
killa
Won't Shut Up
PostPosted: 11:34 - 19 Apr 2010    Post subject: ZX7R problems (carb icing??) Reply with quote
Only recently getting a problem with fueling or air on the 7R.
Out for a ride at the weekend, the bikes running sweet as a nut. When i have stopped at lights for a minute or two and then pull away the bikes splutters...once it completely stalled!
Whats going on there?!
Im running her only on good fuel from either Texco or BP. I haven't had the problem until recently.
Killa
Barry_M2
PostPosted: 11:39 - 19 Apr 2010    Post subject: Reply with quote
Does it run lumpy at idle?
What's it like cruising at 30-40?
Did it stall when you let the clutch out, or when you tried to give it some gas, or when you knocked it into 1st?
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
killa
Won't Shut Up
PostPosted: 12:07 - 19 Apr 2010    Post subject: Reply with quote
Runs fine at idle, rpm is consistant.
It happens when i release cluth and give some throttle, its splutters as if im running out of fuel but i know im not. I have to give it some beans to raise the RPM and it clears itself. This doesn't happen everytime i pull away.
Barry_M2
PostPosted: 12:13 - 19 Apr 2010    Post subject: Reply with quote
Have you had the tank off recently?
It sounds like it's not got enough fuel there, or, too much air getting in from somewhere on the inlet side.
killa
Won't Shut Up
PostPosted: 13:02 - 19 Apr 2010    Post subject: Reply with quote
Good point, ill take the tank off asap and have a look. Thumbs Up
wabbithunter
PostPosted: 22:34 - 20 Apr 2010    Post subject: Reply with quote
mate you need to get your carbs apart and give them a good clean, prob got shit in there. have you ever ran the tank dry,if so you would have pulled loads of crap through, even small bits will get through the fuel filter.
if it was the carbs icing up, you'd notice it as you were constatly riding,not just from pulling away etc.
used to have the problem of the carbs icing on my zx7r.
TL1000R Fighter,TL1000R ,Husaberg 650 ,883 sportser,Ducati 996,RGV/RS 250 Special Fighter
I INTEND TO LEAVE THIS WORLD THE SAME WAY I CAME IN, BLOODY AND SCREAMING
PostPosted: 22:39 - 20 Apr 2010    Post subject: Reply with quote
Doesn't sound like carb icing to me. If it was I would expect it to get worse at speed and idle like a pig (if at all) when you first stopped, with sitting still for a while before moving off fixing it.
killa
Won't Shut Up
PostPosted: 08:18 - 22 Apr 2010    Post subject: Reply with quote
Oh i think i forgot to add that this problem seems to only be happening when it's warm.
I go to work in the mornings with no issues (cold air) then on the way home she gets really hot (45min ride) when i get back to my town the problems start there.
PostPosted: 09:19 - 22 Apr 2010    Post subject: Reply with quote
Wonder if it could be fuel vaporisation? Fuel in the lines turning to vapour and preventing fuel flow, or in the carbs richening the mixture? Not sure of how the ZX7R fuel system is laid out (ie, where the fuel pipes run relative to the hot engine / radiator, where breathers go, etc), so not sure if this is possible on your bike. If it is then I would expect it to be a bit of a pig to restart when it stalled.
Jenks
PostPosted: 15:17 - 22 Apr 2010    Post subject: Reply with quote
my 2nd 7r used to do this so much..
changed the carbs and she was fine... (She came with a second set, so thats why the swap)
id presume some rubbish in the carbs, or a slight kink in the fuel line (Easily done!)
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
killa
Won't Shut Up
PostPosted: 15:21 - 22 Apr 2010    Post subject: Reply with quote
Yeah i think this is the best way to go although i don't see how this can be mainly effected by heat.
Jenks
PostPosted: 15:58 - 22 Apr 2010    Post subject: Reply with quote
im not sure mate, mine was doing exactilly the same though...
if something is stopping the full ammount of fuel getting through, and its hot, it will evaporate the rest as posted previously.
Barry_M2
PostPosted: 16:06 - 22 Apr 2010    Post subject: Reply with quote
Check the float height. If its not letting enough fuel into the bowls, and heat is evaporating a little then you may get these symptoms.
The fuel lins are fairly short on a 7 and dont really run near anything hot. Carbs sit right above the gearbox, but it does get a little warm there!
killa
Won't Shut Up
PostPosted: 16:38 - 22 Apr 2010    Post subject: Reply with quote
Yeah this makes sense...i don't think its crap from tank.
Need to have a play around i think. Thumbs Up
The last post was made 16 years, 140 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 86.08 Kb
