Clutchups...
Bike Chat Forums Index -> General Bike Chat Goto page 1, 2, 3, 4, 5  Next
tutton
PostPosted: 21:33 - 20 Apr 2010    Post subject: Clutchups... Reply with quote
I know there is many many threads already about this, but there must be something im just not grasping...
Ive been practising power flickups for the last few days now, as as you'd expect its falling as i havnt got enough revs, and shift up and it drops. like so
https://i123.photobucket.com/albums/o297/Gfxs/th_bestsofar.jpg
Ive heard about clutch ups before
As in 2nd gear, around 4k hit clutch all the way in then loads of gas and let go, the 636 only seems to lurch forward which makes me think im doing something wrong as it dosnt feel like it wants to lift at all on clutch?
what am i doing wrong? body positioning? not enough revs? not letting clutch out fast enough?
Cheers for all the help Wink
PostPosted: 22:12 - 20 Apr 2010    Post subject: Reply with quote
Can't wheelie for toffee but I would have thought you would need to be highier up the revs than 4k, more like 8.
PostPosted: 22:17 - 20 Apr 2010    Post subject: Re: Clutchups... Reply with quote
2nd gear on standard gearing at 4k rpm is probably a bit low - practice the technique (start small of course) in first, they play about at different points of the rev range in second.
Or get it higher in first Smile.3
In the video it doesn't sound like you were running out of revs - have you made sure you can fully easily rotate your hand around to full throttle - start with your hand pointed higher up.
tutton
PostPosted: 22:20 - 20 Apr 2010    Post subject: Reply with quote
I did get it higher but my camera man was kicking stones most the fucking time Laughing
felt like i was running out of revs alot too, like bouncing on the limiter
So is it not dangerous trying clutching in 1st?
what kind of revs on a 636 would we be thinking 8k as it really comes on cam at like 10,
Acemastr
PostPosted: 22:26 - 20 Apr 2010    Post subject: Reply with quote
best thing to do is try, if 4k won't get it up, try 6, if 6 can't, try 8, just cover the rear brake Smile
2016 Toyota Tacoma Limited
swiftb
PostPosted: 22:27 - 20 Apr 2010    Post subject: Reply with quote
This is in no way an expert opinion but what ive experienced while 'dabbling'. Ive clutched my '00 6R up in 2nd but it wasnt far off the limiter before I could get it to come up (prob 11-12k+)
Will clutch up at around 8k in first, I think (generally not looking at the rev counter when im trying to hoist a minger Laughing )
With revs any lower in 1st or 2nd it kind of just slips a bit and launches forwards.
I found a little tug on the bars meant I could get it up from lower rpm but gave me brown pants from getting a little to high for my own comfort.
lllN30lll
PostPosted: 22:29 - 20 Apr 2010    Post subject: Reply with quote
I f*cking hate photobucket vids, trying to watch it over and over so i can see where you're going wrong, but it keep buffering.
Turbo R1
CRF450R
tutton
PostPosted: 22:30 - 20 Apr 2010    Post subject: Reply with quote
Where you want it reuploaded mate and ill throw it up?
Surely that means if it needs to be around 11-12k clutch up, it wont rise enough before the gear change and fall?
Is the technique im trying correct, ride along at the revs clutch in loads of gas for like a second then just drop clutch out and hold on tight?
lllN30lll
PostPosted: 22:32 - 20 Apr 2010    Post subject: Reply with quote
youtube please mate so I can stop it on the frame's I want.
Turbo R1
CRF450R
R6jonny
Clutching in 1st... why would you not just bring it up on the throttle... ??
Honda NSR125 - Yamaha R6 - Ducati 748 - Suzuki GSXR750K6/GSXR1000K7/GSXR750K8 - Ducati 848 - Honda SP1 - Triumph Daytona 675
"simply because she is a female and is thus her actions largely make no sense whatsoever by default"
lllN30lll
PostPosted: 22:34 - 20 Apr 2010    Post subject: Reply with quote
watch at 2:12 on my video.
https://www.youtube.com/watch?v=CNUaLiTfWKg
and you can see my 2 fingers, I take it yours is cable operated so it might not be as easy. It's a case of slipping the clutch, rather then holding it in, revving it and pinging it out IMO.
Turbo R1
CRF450R
st3v3
PostPosted: 22:36 - 20 Apr 2010    Post subject: Reply with quote
Utube, embedding that frame is no more benefit than a linky to Utube anyway. Thumbs Up
I'd say start off slower(so a slower rolling start), take your time and concentrate on having it lift with feel rather than 'what clutch can I give it to make it pop up'
As above, when I used to wheelie the NS it was clutch slipping rather than holding it in, piling revs on a popping it out - that just the front bounce around without any wheelie, each 'airtime' lasted for literally split seconds. Thumbs Down
PostPosted: 22:37 - 20 Apr 2010    Post subject: Reply with quote
Only if you're a twat doing it. I once tried to clutch my heavily downgeared/tuned zx9 in second off a speed bump for it to almost hit me in the face - turned out it was in first, luckily I'd only tweaked it.
Just start at somewhere 6-9k maybe and rev a little, then dump. Play about, making sure you start small and you should get a feel for where works and doesn't. I often give my GSXR a quick tweek of the clutch to flick it up in first - but it's quite tall geared of course.
tutton
PostPosted: 22:38 - 20 Apr 2010    Post subject: Reply with quote
https://www.youtube.com/user/ImTutton
Ill upload all todays lil efforts up there.
You can see it quite well (maybe better?) at 3:28.
lllN30lll
PostPosted: 22:41 - 20 Apr 2010    Post subject: Reply with quote
When my forks come back from the shops on Friday I'll do you a video mate Thumbs Up
This is the only video i watched https://www.youtube.com/watch?v=qncPBZ9DRRk Copy it to your phone, and go play on a quiet road or private road. Take your time and follow his steps.
Remember to keep your arms loose so the bike's front end doesn't have to lift your stiff upper body too, and sit as far back on the seat as you can.
Turbo R1
CRF450R
st3v3
PostPosted: 22:44 - 20 Apr 2010    Post subject: Reply with quote
You gotta do more vids like that. Thumbs Up Cool
tutton
This is the only video i watched https://www.youtube.com/watch?v=CNUaLiTfWKg Copy it to your phone, and go play on a quiet road or private road. Take your time and follow his steps.
Ok bud, i look forward to seeing it,
you just said the only video you watched was your own? how did you do that? Laughing
st3v3
PostPosted: 22:46 - 20 Apr 2010    Post subject: Reply with quote
I thought he'd pasted wrong linky back in.. Laughing
lllN30lll
PostPosted: 22:47 - 20 Apr 2010    Post subject: Reply with quote
lmao, was still in my clipboard, edited now Thumbs Up
Turbo R1
CRF450R
tutton
PostPosted: 23:11 - 20 Apr 2010    Post subject: Reply with quote
How far out is the adjustment on your clutch is that literally just as its biting?
TUG
PostPosted: 23:30 - 20 Apr 2010    Post subject: Reply with quote
Because unless yout on a big litre V twin its hard to hit your BP before you run out of revs. If you hit your power off the clutch the bike will lift the front and your revs will drop enough to help keep your BP.
Haz ER-5, innit!
PostPosted: 23:34 - 20 Apr 2010    Post subject: Reply with quote
Not hard really I'd say on most 600cc+ sports bike, but certainly easier using the clutch - also once you get used to it, more precise too.
Ichy
PostPosted: 00:06 - 21 Apr 2010    Post subject: Reply with quote
How do you fancy wasting an hour showing me and CHRI5 how to improve our pathetic/non existent efforts?
J D
PostPosted: 08:11 - 21 Apr 2010    Post subject: Reply with quote
Martin come down here and ill help you.
https://www.youtube.com/watch?v=1UrF8scRf4g
Did that after only riding the bike for a minute previous to the video, Piece of piss Thumbs Up
https://img690.imageshack.us/img690/5573/p1030759g.jpg
https://img442.imageshack.us/img442/6254/p1030758l.jpg
The last post was made 16 years, 153 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 5
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 130.87 Kb
