CB250N Won't rev beyond 5000 revs
MadDogMcQ
PostPosted: 08:49 - 23 Apr 2010    Post subject: CB250N Won't rev beyond 5000 revs Reply with quote
I have a 1980 CB250N which I have refurbished over the last year or so. Having virtually completed the work, I fired it up and Vroom!! Engine started first time and ticks over superbly. BUT, it won't rev beyond 5k. It splutters and dies until the revs drop back down.
Fuel supply is okay, vent in tank okay, plugs okay, timing okay, compression okay, carb inlet-boots okay, alternator okay, valve clearances okay, cuddly toy okay!
Having read a similar thread by ANT123 on here, I was overjoyed to read his final post and rushed out to remove the air filter to see if it made any difference - and it doesn't! So I'm guessing that Ant's air filter had bugger all to do with it and his Dad has more likely cured it (inadvertently) some other way.
Anyone any ideas?? Damn, its soooo frustrating!! PLEASE help!
https://www.mcqart.com/mcqweb/images/bikes/cb250n/b4_96.jpg
temeluchus
PostPosted: 09:00 - 23 Apr 2010    Post subject: Reply with quote
drained the carbs? carb diaphragms ok?
TQ
PostPosted: 09:06 - 23 Apr 2010    Post subject: Reply with quote
Check the jets aren't blocked.
First Bike :Gilera DNA 50 | Second: Imported 1989 NSR125
Third: 1998 Yamaha XJ600N | Currently: 1999 Yamaha FZS600
MadDogMcQ
PostPosted: 09:20 - 23 Apr 2010    Post subject: Reply with quote
Carbs have been completely overhauled, ultrasonically cleaned, new Keyster Carb Kits fitted (jets, needles, washers, etc) and the float heights have been set.
Go figure!
temeluchus
PostPosted: 09:45 - 23 Apr 2010    Post subject: Reply with quote
if the carburettors are ok as you say and all functional Then youll have to check the timing again. Is it electronic ignition or points?
Id also recheck the float heights as this can starve the engine if set incorrectly.
pepperami
PostPosted: 10:05 - 23 Apr 2010    Post subject: Reply with quote
Does it have an advance/retard part to the ignition? is that stuck/not working?
did it used to be easier to get it to fire on one cylinder and harder to get it to fire on the other cylinder,..... that can be a sign that the advance/retard is not working right?
i am having similar problems with an old XS400 i am putting back together.
just an idea!
temeluchus
PostPosted: 10:12 - 23 Apr 2010    Post subject: Reply with quote
Alot of early electronic ignition still have mechanical advance retard units, so thats deffo worth looking at. I had a GPz550 that did similar. Tured out to be the unit.
temeluchus
PostPosted: 10:13 - 23 Apr 2010    Post subject: Reply with quote
this is you i take it Razz
https://cb250n.blogspot.com/
Odie
PostPosted: 10:29 - 23 Apr 2010    Post subject: Reply with quote
Check your alternator.
It can be that your alternator isnt kicking out enough voltage to allow the ignition to advance the timing at 5,000 rpm, same problem that the CX500 used to get.
Also, your carb to cylinder head rubbers, if they are not split, have they gone hard, if so they will not seal properly and let air in and cause problems.
temeluchus
PostPosted: 10:32 - 23 Apr 2010    Post subject: Reply with quote
The pickups appear to to be integrated with the generator stator. Do you have another stator to try?
Ditto
PostPosted: 13:00 - 23 Apr 2010    Post subject: Reply with quote
Is the fuel new and good?
I had a similar problem because of water in the tank.
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
MadDogMcQ
PostPosted: 15:10 - 23 Apr 2010    Post subject: Reply with quote
Hi Guys,
The fuel is fresh. The alternator voltage is nice and high and increases with revs, the inlet rubbers are new. The advancing of the ignition is done electronically by the CDI and is working fine.
It has me VERY puzzled up to now. I'm away for the weekend and then the carbs are coming off (I'm not sure why, but I've looked at everything else!).
temeluchus
PostPosted: 16:11 - 23 Apr 2010    Post subject: Reply with quote
well assuming the ignition is 100% it must be fuel related....
Float heights, hunction of the tap, state of the filters, breather in the fuel cap, condition of the vacuum diaphragms etc etc
Ant132
PostPosted: 19:10 - 23 Apr 2010    Post subject: Reply with quote
I remember this very well and embarrasingly enough, it was indeed the air filter that was the sole cause of my problems. It was simply in upside down Mr. Green
The plate in the airbox is a bit ambiguous, so check the the foam filter and plate are sitting correctly. (Dont just remove it!)
Ant
Blue_SV650S
PostPosted: 20:16 - 23 Apr 2010    Post subject: Reply with quote
This may sound a bit stupid, but have you actually tried riding it or is all this done on the stand???
My wetdream always needed a bit of a run before it would rev cleanly ....
MaybeGuy
PostPosted: 20:18 - 23 Apr 2010    Post subject: Reply with quote
cam timing. does it start without the choke? almost too easily?
MadDogMcQ
PostPosted: 08:23 - 26 Apr 2010    Post subject: Reply with quote
Sorry Ant, but I just cannot accept that it was because your airfilter plate was upside down. It is, after all, just a plate full of holes and whether it's upside down or not, the holes are still there. My air-filter is fitted correctly anyway and it makes no difference to the problem whether it's installed or not. I assume you mean the plate indicated in the arrow below btw.
Ant, your bike was running perfectly before you changed the rocker-gasket and the oil, so how has the air filter suddenly effected it? Come on, let's be sensible. I'm REALLY glad your bike's running fine, but I reckon you must have had a dodgy connection somewhere and your Dad's "fiddling" has sorted it.
And yes, the problem on my bike exists on and off the road and the cam-timing's spot on. I didn't even look at the bike yesterday - it's peeing me off.
27cows
PostPosted: 08:34 - 26 Apr 2010    Post subject: Reply with quote
It's got to be something simple. Something so ridiculous you probably wouldn't think of it, like the ignition wiring block not fully pushed home, leading to a weak spark under compression (happened to me on one of my 400 Superdreams...and took me days to suss Embarassed ).
MadDogMcQ
PostPosted: 08:49 - 26 Apr 2010    Post subject: Reply with quote
I think you may be right 27cows. Getting all those cable and connectors into the headlamp shell is a total pig(!) and has all the potential for problems. I have, however, checked mine and everthing looks sound. I've even tried changing the ignition switch itself and that made no difference either.
27cows
PostPosted: 11:52 - 26 Apr 2010    Post subject: Reply with quote
Is the crankcase breather clear of obstructions, pipe not kinked/trapped?
nightshaddow
PostPosted: 12:34 - 26 Apr 2010    Post subject: Reply with quote
i had the same problem with my 125 tdc wetdream turned ot the 24 year old bike(at the time) needed new coils, not sure if you can have them tested but it would start and run up to 4500 rpm but almost choking out any higher, i checked loads of things and turned out under load it wouldent fire not sure if its the same for you but maybe something to check
MadDogMcQ
PostPosted: 13:10 - 26 Apr 2010    Post subject: Reply with quote
Yes, KnightShadow, the coil is a likely culprit. In fact, I was on wemoto.co.uk earlier, pricing one up - £27. It's just such a bugger having to spend money on this stuff to find out if it's the problem item. My CDI arrived today and I know now that it's not that, so there's £15 wasted!
nightshaddow
PostPosted: 14:41 - 26 Apr 2010    Post subject: Reply with quote
generally to my knowledge the cdi normally works or not and theirs no in between (but i could be wrong) a coil may brake down and voltage and heat build up could make it worse,
i hope the coils work for you but keeping my thinking cap on
good luck
temeluchus
PostPosted: 15:45 - 26 Apr 2010    Post subject: Reply with quote
do you have another bike the you could grab a coil from?
any twin lead japanese coil should do the trick, like a coil from a bandit, early GSXR, GPzs and probably many others.
There is a gap of 1 year, 17 days between these two posts...
big lad
PostPosted: 10:23 - 14 May 2011    Post subject: Reply with quote
Hello, I have exactly the same problem... Did you ever find a cure??? I've had my carb off about 20 times thinking its something to do with that..I'm ready for putting a flame to the bike!!!
Please help
The last post was made 15 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 3.16 - MySQL Queries: 13 - Page Size: 130.02 Kb
