| MadDogMcQ |
 MadDogMcQ Derestricted Danger
 Posted: 08:49 - 23 Apr 2010 Post subject: CB250N Won't rev beyond 5000 revs |
I have a 1980 CB250N which I have refurbished over the last year or so. Having virtually completed the work, I fired it up and Vroom!! Engine started first time and ticks over superbly. BUT, it won't rev beyond 5k. It splutters and dies until the revs drop back down.
Fuel supply is okay, vent in tank okay, plugs okay, timing okay, compression okay, carb inlet-boots okay, alternator okay, valve clearances okay, cuddly toy okay!
Having read a similar thread by ANT123 on here, I was overjoyed to read his final post and rushed out to remove the air filter to see if it made any difference - and it doesn't! So I'm guessing that Ant's air filter had bugger all to do with it and his Dad has more likely cured it (inadvertently) some other way.
Anyone any ideas?? Damn, its soooo frustrating!! PLEASE help!
https://www.mcqart.com/mcqweb/images/bikes/cb250n/b4_96.jpg
| temeluchus |
| TQ |
 TQ Trackday Trickster
| MadDogMcQ |
| temeluchus |
| pepperami |
 pepperami Super Spammer
| temeluchus |
| temeluchus |
 Posted: 10:13 - 23 Apr 2010 Post subject: |
this is you i take it
https://cb250n.blogspot.com/ ____________________ Some shite cruiser. Now with guns and FREEDOM! |
| Odie |
 Odie World Chat Champion
| temeluchus |
| Ditto |
 Ditto Nearly there...
| MadDogMcQ |
| temeluchus |
| Ant132 |
 Ant132 World Chat Champion
| Blue_SV650S |
 Blue_SV650S World Chat Champion
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 20:18 - 23 Apr 2010 Post subject: |
cam timing. does it start without the choke? almost too easily? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| MadDogMcQ |
| 27cows |
 27cows World Chat Champion
 Posted: 08:34 - 26 Apr 2010 Post subject: |
It's got to be something simple. Something so ridiculous you probably wouldn't think of it, like the ignition wiring block not fully pushed home, leading to a weak spark under compression (happened to me on one of my 400 Superdreams...and took me days to suss ). ____________________ The RXS100: vehicle of choice for Chuck Norris |
| MadDogMcQ |
| 27cows |
| nightshaddow |
 nightshaddow Nearly there...
 Posted: 12:34 - 26 Apr 2010 Post subject: |
i had the same problem with my 125 tdc wetdream turned ot the 24 year old bike(at the time) needed new coils, not sure if you can have them tested but it would start and run up to 4500 rpm but almost choking out any higher, i checked loads of things and turned out under load it wouldent fire not sure if its the same for you but maybe something to check ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| MadDogMcQ |
| nightshaddow |
 Posted: 14:41 - 26 Apr 2010 Post subject: |
generally to my knowledge the cdi normally works or not and theirs no in between (but i could be wrong) a coil may brake down and voltage and heat build up could make it worse,
i hope the coils work for you but keeping my thinking cap on
good luck ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
| temeluchus |
There is a gap of 1 year, 17 days between these two posts... |
| big lad |
 big lad Two Stroke Sniffer
The last post was made 15 years, 136 days ago. Instead of replying here, would creating a new thread be more useful? |
