Help with Honda CG125B.
X9-rider
PostPosted: 23:29 - 23 Apr 2010    Post subject: Help with Honda CG125B. Reply with quote
Hello people...........
Wounder if anyone knows whats size the CG125BR Head light is, and can you add a bigger one, and upgrade the bulb from 25w to something more Brighter?
Riding to squires down them dark roads, i may as well ride with a candle with the dim lights on this Honda CG125BR.
Any one with ideas ?
Alexio
PostPosted: 23:34 - 23 Apr 2010    Post subject: Reply with quote
I just use my "full beam" in the dark on my CG and it's just fine. Not perfect if I'm honest but it's ok.
X9-rider
PostPosted: 23:38 - 23 Apr 2010    Post subject: Reply with quote
i know you can put in a 40w halogen upgrade bulb in, but i know the Head light part is a non standed size, will a 8'' onwards headlight fit ?
Robby
Dirty Old Man
PostPosted: 23:52 - 23 Apr 2010    Post subject: Reply with quote
As has been said, you could fit a bigger headlight.
However, I have never owned a bike where the standard headlight has been insufficient for the bike as standard - even my old 6 volt moped light was ok.
You light will be crap if your battery is knackered, or if the bulb is old and corroded, or is the wiring connectors on the lighting circuit are corroded.
X9-rider
PostPosted: 00:05 - 24 Apr 2010    Post subject: Reply with quote
the bulb that is in is 25w low beam and 25w high beam, battery fully charge.
On way to squires the road is hardly light on the pitch black roads with 25w and light spread isn't good.
Iam used to the Twin HID lights of my X9, but these lights on Honda are like stone age.
These are the HID light on my X9, is there anyway i can get a brighter light from the CG125, i know i cant add HIDs to the CG as it such a old bike, but must be away to improve light output
https://farm5.static.flickr.com/4010/4479468887_ca59300b3e.jpg
nightshaddow
PostPosted: 09:28 - 24 Apr 2010    Post subject: Reply with quote
you might find as it is an old bike the reflective surface of the on the inside has gone bad and you may need to replace the whole unit, i had this with one of mine i just replaced with some e marked streetfighter lights off ebay, the wattage of the bulb was the same but it was 10x brighter in the end
X9-rider
PostPosted: 21:21 - 24 Apr 2010    Post subject: Reply with quote
streetfighter lights will fit the CG ...
Forgive me for sounding stupid but iam a guy whos been in the scooter world but........ what are streetfighter lights ?
nightshaddow
PostPosted: 22:05 - 24 Apr 2010    Post subject: Reply with quote
something similar to this
https://cgi.ebay.co.uk/STREETFIGHTER-MOTORBIKE-FAIRING-HEADLIGHT-INDICATORS-BK_W0QQitemZ270356234136QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item3ef27cbf98
there are many different styles you can get but most can be modded to fit, you can also buy a standard headlight depending on the look you want to go for
https://cgi.ebay.co.uk/UNIVERSAL-MOTORCYCLE-5-CHROME-HEADLIGHT-12v-25w-BULB_W0QQitemZ250359600156QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item3a4a98541c
something like this would be easily fitted to a cg
X9-rider
PostPosted: 19:02 - 27 Apr 2010    Post subject: Reply with quote
Hello all.
Got a a tapping sound coming from engine, does anyone know what it could be ?
DrDonnyBrago
PostPosted: 19:31 - 27 Apr 2010    Post subject: Reply with quote
X9Travels wrote:
Hello all.
Depends where it is coming from exactly, could be lots of things.
Valves in need of adjustment, cam chain flapping around, blowing exhaust, bearings dying etc etc etc. Where is the noise coming from, does it increase with revs and does it happen in gear/neutral/with clutch pulled in?
nightshaddow
PostPosted: 19:40 - 27 Apr 2010    Post subject: Reply with quote
DonnyBrago wrote:
X9Travels wrote:
Hello all.
most prob the valves in need of adjustment no cam chain on the old cg's they a pushrod engine. bairings more going to grind than tap though it could be a gearbox prob had a cb throw a tooth on the 1st gear outer shaft once that taped like a son of a........
X9-rider
PostPosted: 22:57 - 27 Apr 2010    Post subject: Reply with quote
The sound has made the bike vibrate more too.
Here are some pictures i toke today too of the Honda CG 125 BR - 1990.
https://farm4.static.flickr.com/3469/4559035560_6cfaa5afdb.jpg
https://farm4.static.flickr.com/3026/4559036546_91233c849a.jpg
https://farm4.static.flickr.com/3325/4559034872_21e0f08039.jpg
Alexio
PostPosted: 01:07 - 28 Apr 2010    Post subject: Reply with quote
Oh man, I'm the biggest fan you'll ever find of the CG but that windshield is ugly!
Robby
Dirty Old Man
PostPosted: 09:22 - 28 Apr 2010    Post subject: Reply with quote
As said, tapping can be caused by an awful lot of things. Valve clearances are a likely one, or an exhaust blow where it seals to the head - this can make a sort of ticking noise, diagnosed by holding your hand near it and seeing if you can feel air blowing or by getting someone who knows the sound to listen.
Check and set your valve clearances, it's a screw and locknut job on the CG so dead easy. Use a workshop manual, and make sure you're using the right measurements for your feeler gauges - my set are imperial, so I get silly clearance if make a mistake and read the metric measurement (0.10mm) and set the valves to 0.0010".
An easy way to find where the noise is coming from is to use a long screwdriver as a stethoscope. Metal end on to the engine, put the plastic end to your ear, and you hear exactly what's happening inside the engine.
X9-rider
PostPosted: 10:51 - 29 Apr 2010    Post subject: Reply with quote
thanks for the tip
The last post was made 15 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 88.01 Kb
