Honda CG125 stalling mid-drive
Jarlak
PostPosted: 16:17 - 24 Apr 2010    Post subject: Honda CG125 stalling mid-drive Reply with quote
Hi there
I’ve recently gotten into biking, so my mechanical knowledge is only limited at the moment. Having said that, I’m trying to learn quickly.
I own a 2005 reg Honda CG125 at the moment, which has a choke. I think I have the hang of this now.
I half choke it, as suggested by the previous owner when it’s normal temp and full choke when it’s very cold. About a minute of warming the engine up, I take the choke off.
Recently, I’ve been experiencing engine stalls, mid drive, which, as you can imagine is quite dangerous.
Here’s my example:
Been on the road for 10mins, having already warmed the engine beforehand for 1min aprox.
I slow for a roundabout by braking, pull the clutch in and start tapping down the gears. As I slow to around 15mph, the engine cuts out, usually as I’m entering the roundabout or the junction. This means I have to crawl across on the momentum of the bike and start the engine again, at the kerbside.
If anyone has any idea what might be causing this, please let me know.
Thanks
Edit: I've just done some research and have noticed I may be riding in too high a gear. I've been using 4th or 5th for 30/35mph. Could this be causing the problem?
P.
PostPosted: 16:32 - 24 Apr 2010    Post subject: Reply with quote
on a CG...i'd be in around 3rd gear for 30mph tops..
probably in 2nd if it goes that far Razz
i tend to use 4 and 5 as cruising gears..
Saying that...if you are pulling clutch in, your idle screw might need sorting.
When you turn the bike on and its warm does it sound lumpy (i dont think you have a rev counter)
try turning the idle screw in half a turn.
Jarlak
PostPosted: 16:34 - 24 Apr 2010    Post subject: Reply with quote
I think this may be causing the problems, as my high gear riding isn't turning the engine over. (That sounds like the mechanical thing to say!)
I'll try staying in 3rd tomorrow.
P.
PostPosted: 16:36 - 24 Apr 2010    Post subject: Reply with quote
but if your clutch is in and you go back to 15mph in 2nd...it shouldnt stall.. if it stalls with the clutch in, try the idle jet..
if its fine when thats in you might have some crap in the tank/carb thats blocking a jet..
Jarlak
PostPosted: 16:40 - 24 Apr 2010    Post subject: Reply with quote
What's an idle jet - is it a component?
P.
PostPosted: 16:47 - 24 Apr 2010    Post subject: Reply with quote
when your bike is warm and sitting still does it sound really lumpy, like its struggling to stay alive?
cloric_tzr
PostPosted: 16:48 - 24 Apr 2010    Post subject: Reply with quote
rather than risk getting squashed by a artic on the roundabout cant u bump it an carry on?
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
Jarlak
No, it sounds about as normal as other bikes do.
Jarlak
PostPosted: 16:50 - 24 Apr 2010    Post subject: Reply with quote
rather than risk getting squashed by a artic on the roundabout cant u bump it an carry on?[/quote]
Yeah, I usually manage that, except on one corner today, when it just wouldnt restart
cagiva gezzer
PostPosted: 16:56 - 24 Apr 2010    Post subject: Reply with quote
Idle is set too low. You shouldn't need the choke to start it in this weather.
Jarlak
PostPosted: 16:57 - 24 Apr 2010    Post subject: Reply with quote
Cool. I'll give it a twist
cloric_tzr
PostPosted: 17:10 - 24 Apr 2010    Post subject: Reply with quote
Yeah, I usually manage that, except on one corner today, when it just wouldnt restart[/quote]
hmmmm. it sound like it could be a combination of ur idle setting/fueling and/or spark plug have you tryed a new 1? or looked to see what condition your existing one is in?
Jarlak
PostPosted: 17:12 - 24 Apr 2010    Post subject: Reply with quote
hmmmm. it sound like it could be a combination of ur idle setting/fueling and/or spark plug have you tryed a new 1? or looked to see what condition your existing one is in?[/quote]
I actually looked at that the other day. Having seen picture examples of degraded ones, I was pleased to see it looked fairly new.
Jarlak
PostPosted: 18:26 - 26 Apr 2010    Post subject: Reply with quote
Guys, jut to say, that after 2 days of putting your suggestions into practice, I've had no problems at all.
Must have been a combination of low engine idle speed and high gears at low speeds.
Thanks!
P.
PostPosted: 21:58 - 26 Apr 2010    Post subject: Reply with quote
glad to see its going well Mr. Green
The last post was made 15 years, 236 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 83.91 Kb
