| Jarlak |
 Jarlak Derestricted Danger
 Posted: 16:17 - 24 Apr 2010 Post subject: Honda CG125 stalling mid-drive |
Hi there
I’ve recently gotten into biking, so my mechanical knowledge is only limited at the moment. Having said that, I’m trying to learn quickly.
I own a 2005 reg Honda CG125 at the moment, which has a choke. I think I have the hang of this now.
I half choke it, as suggested by the previous owner when it’s normal temp and full choke when it’s very cold. About a minute of warming the engine up, I take the choke off.
Recently, I’ve been experiencing engine stalls, mid drive, which, as you can imagine is quite dangerous.
Here’s my example:
Been on the road for 10mins, having already warmed the engine beforehand for 1min aprox.
I slow for a roundabout by braking, pull the clutch in and start tapping down the gears. As I slow to around 15mph, the engine cuts out, usually as I’m entering the roundabout or the junction. This means I have to crawl across on the momentum of the bike and start the engine again, at the kerbside.
If anyone has any idea what might be causing this, please let me know.
Thanks
Edit: I've just done some research and have noticed I may be riding in too high a gear. I've been using 4th or 5th for 30/35mph. Could this be causing the problem? |
| P. |
 P. Red Rocket
 Posted: 16:32 - 24 Apr 2010 Post subject: |
on a CG...i'd be in around 3rd gear for 30mph tops..
probably in 2nd if it goes that far
i tend to use 4 and 5 as cruising gears..
Saying that...if you are pulling clutch in, your idle screw might need sorting.
When you turn the bike on and its warm does it sound lumpy (i dont think you have a rev counter)
try turning the idle screw in half a turn. |
| Jarlak |
| P. |
 P. Red Rocket
| Jarlak |
| P. |
 P. Red Rocket
| cloric_tzr |
 cloric_tzr Brolly Dolly
| Jarlak |
| Jarlak |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| Jarlak |
| cloric_tzr |
| Jarlak |
| Jarlak |
| P. |
 P. Red Rocket
 Posted: 21:58 - 26 Apr 2010 Post subject: |
glad to see its going well  |
The last post was made 15 years, 235 days ago. Instead of replying here, would creating a new thread be more useful? |
