Drilling/cutting 4mm Steel
binge
Emo Kiddy
PostPosted: 18:54 - 27 Apr 2010    Post subject: Drilling/cutting 4mm Steel Reply with quote
I've mocked up a custom made, Highflow inlet manifold for my TZR engine.
It's basically a flat piece of steel, around 3" x 4".
4 holes drilled in it. One in each corner.
I've then got a curved piece of tubular steel, 30mm internal diameter.
I have cut one end off at a steep angle, So the lays almost flat, when stood on the Steel plate.
The other end is cut off square, as the carb will face up to this with a silicone coupling.
Now I need to cut a hole in the middle of this steel plate. It needs to be about 34mm wide, And about 50mm long. An elongated hole I guess.
I've had a shot at it with a hole saw, But have got nowhere really. It burnt the hole saw out. Razz
Whats the best option?
I considered using the oxy/acc at work to blow it out, Starting from the middle.
It needs welding to the tubular steel, and grinding neat/flush after anyway.
However, I was afraid the heat transfer from the Oxy/Acc would warp the steel and make it quite un-flat. Giving a poor seal when bolting it to the engine.
Any help MUCH appreciated, as I am not a steel engineer. Laughing
Tristan.
PostPosted: 18:59 - 27 Apr 2010    Post subject: Reply with quote
Get a local engineering firm to do it on a milling machine. Or if you have access to a pillar drill, that + a large bit + lots of time.
PostPosted: 19:09 - 27 Apr 2010    Post subject: Reply with quote
Fistly drill your four mounting holes in the plate.
50-34 = 16, so draw two center-lines that cross in the middle, and then mark-off 8mm either side of centre on the long line. Center-punch these points. Fix the plate using the mounting holes to some scrap timber/mdf/the dog and then spot the two center-punch marks with a small drill. Get a 34mm tank cutter (a.k.a hole saw, starrett cutter) and drill a mm at a time swapping between the two holes so you are describing two over-lapping circles. Swap between them until one breaks though then remove that disc and drill the other using the hole in the timber beyond as a guide. Use a half-round file to tidy the job up.
If you are burning out hole saws then you have a hole saw for drilling timber or you are turning it too fast. Use water or oil for coolant/lube.
Walloper
PostPosted: 20:17 - 27 Apr 2010    Post subject: Reply with quote
What 'Steel'?
Stainless will eat any hole saw unless you let yer Gran do it.
Tunza lube and no heavy feed or fast speed.
Or you could use a small diameter bit and make hundreds of wee holes around the inside of the circle you want the half round b4stard file to clean up.
effit
PostPosted: 20:36 - 27 Apr 2010    Post subject: Reply with quote
Use a mag drill with a 34mm cutter, any Fab shop will have one and shouldnt cost you a lot of dosh to have it done. The ones Ive used are Evolution but I think Rothenberger and a few other types are out there. Even have a look and see if you can hire one for a couple of hours at a local tool shop.
The shop will probably ram you for the cost of the drill bit so have a looky on Egay or somewhere like that.
here is one similar to what i`m talking about...
https://www.evolutionpowertools.co.uk/us/evolution_me3500.html
PostPosted: 20:38 - 27 Apr 2010    Post subject: Reply with quote
I agree with Tristan.. A milling machine is the weapon of choice for this task.
If you take it in already marked out, they might even do it for a six pack of beer during their lunch break.
jimspeed
PostPosted: 21:01 - 27 Apr 2010    Post subject: Reply with quote
if you are anywhere near ludlow i have a huge milling machine here and i would be willing to give it a go for you one eve..
i would mill it after welding too so the plate is flat again unless you were thinking of brazing it
jim
edit just seen you are in kent so a bit far i would av thought lol
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
Walloper
PostPosted: 21:18 - 27 Apr 2010    Post subject: Reply with quote
jim
So your mill isn't huge enuf to reach? Pity..... Very Happy
jimspeed
PostPosted: 21:37 - 27 Apr 2010    Post subject: Reply with quote
na and its a bit big to post.. Rolling Eyes
binge
Emo Kiddy
PostPosted: 23:47 - 27 Apr 2010    Post subject: Reply with quote
Brazing it was going to be my weapon of choice as that's all I have access to. And I'm also pretty good at brazing, I've made up complete exhaust systems with the gas axe.
Pete, You're the man! Will give that a go tomorrow with a fresh hole saw. Will have to check what ones I've got.
Failing that, I'll have to nip round a few places and see if an engineering firm can help me out.
It's just regular mild steel I beleive. I've used it to make my engine mounts out of. Certainly not stainless because a piece I used for a reg bracket, That I didnt paint, Has rusted slightly.
Ben
PostPosted: 23:52 - 27 Apr 2010    Post subject: Reply with quote
Alloy would be far easier to machine and lighter. Much more difficult to join though.
binge
Emo Kiddy
PostPosted: 00:16 - 28 Apr 2010    Post subject: Reply with quote
Alloy also stores heat. I made the 2 pieces out of alloy a while back. Never did get them joined up though.
Ben
PostPosted: 00:47 - 28 Apr 2010    Post subject: Reply with quote
Ben
Stores it but is poor at conducting it.
Have you had a play with lumiweld solder? That nutter who makes the five cylinder kawasaki 2-strokes by splicing parts of two triple engines run through a bandsaw joins the crankcases together using aluminium solder.
It's a fine line between the temperature that flows the solder and the temperature that melts the alloy but once it's joined, it stays joined.
BanditsHigh
Worse than a woman
PostPosted: 06:19 - 28 Apr 2010    Post subject: Reply with quote
Just use a jigsaw with a metal cutting blade ... I made some suspension linkages out of 6mm stainless steel and although it took a while it worked out ok ... 4mm steel will be a breeze Thumbs Up
Walloper
PostPosted: 09:21 - 28 Apr 2010    Post subject: Reply with quote
Alloy (Aluminimuminum) will conduct heat and electricity quite easily and better than steel.
PostPosted: 11:27 - 28 Apr 2010    Post subject: Reply with quote
You can drill stainles with a hole saw no problem, you use low speed and high pressure (and coolant). Some stainless steels work-harden very quickly if you don't use enough pressure. I drilled four 38mm holes in 6mm thick 316 stainless with one drill and it still had all it's teeth.
PostPosted: 11:41 - 28 Apr 2010    Post subject: Reply with quote
If you put the end of an aluminium bar and the end of a steel bar in a fire and hold onto the ends of them, you'll drop the steel one first.
Walloper
PostPosted: 12:06 - 28 Apr 2010    Post subject: Reply with quote
Thermal Conductivity
Steel, Carbon 17 - 43 (app)
Stainless Steel 16
Aluminium 118 -144
Copper 204 - 233
Silver 248 (best)
Gold 182
Platinum 42
Generally, a material's electrical conductivity is almost equal to it's thermal conductivity.
Stinkers, have you tried putting a bar of Aluminumimnun and one of Steel in a fire to find out which one you drop first? Karma
DrDonnyBrago
PostPosted: 12:14 - 28 Apr 2010    Post subject: Reply with quote
Oooh I thought thermal conductivity was at least partly dependent on the density of the material...
Learn something new everyday eh Thumbs Up
PostPosted: 14:31 - 28 Apr 2010    Post subject: Reply with quote
When I did fire eating (back before I had a huge beard), I very quickly learned to use bits of alumnium rod rather than steel fencing wire to make my torches with. The wire ones got too hot to hold very quickly. You could do a full routine with the aluminium ones.
It may be that the heat from the torch is being radiated away from the metal more quickly than it can be conducted along it?
PostPosted: 19:35 - 28 Apr 2010    Post subject: Reply with quote
What an excellent line to drop into a conversation "Back when I did fire-eating" Very Happy
Yes, that would be the reason - the heat was radiating off the aluminium rod. The denser steel rod would store more heat and radiate it less quickly.
Walloper
PostPosted: 00:27 - 29 Apr 2010    Post subject: Reply with quote
Does that fire-eating not lead to heart-burn and Charring of the Underpants?
The last post was made 15 years, 236 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 122.43 Kb
