| binge |
 binge Emo Kiddy
 Posted: 18:54 - 27 Apr 2010 Post subject: Drilling/cutting 4mm Steel |
I've mocked up a custom made, Highflow inlet manifold for my TZR engine.
It's basically a flat piece of steel, around 3" x 4".
4 holes drilled in it. One in each corner.
I've then got a curved piece of tubular steel, 30mm internal diameter.
I have cut one end off at a steep angle, So the lays almost flat, when stood on the Steel plate.
The other end is cut off square, as the carb will face up to this with a silicone coupling.
Now I need to cut a hole in the middle of this steel plate. It needs to be about 34mm wide, And about 50mm long. An elongated hole I guess.
I've had a shot at it with a hole saw, But have got nowhere really. It burnt the hole saw out.
Whats the best option?
I considered using the oxy/acc at work to blow it out, Starting from the middle.
It needs welding to the tubular steel, and grinding neat/flush after anyway.
However, I was afraid the heat transfer from the Oxy/Acc would warp the steel and make it quite un-flat. Giving a poor seal when bolting it to the engine.
Any help MUCH appreciated, as I am not a steel engineer.  |
| Tristan. |
 Tristan. World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 19:09 - 27 Apr 2010 Post subject: |
Fistly drill your four mounting holes in the plate.
50-34 = 16, so draw two center-lines that cross in the middle, and then mark-off 8mm either side of centre on the long line. Center-punch these points. Fix the plate using the mounting holes to some scrap timber/mdf/the dog and then spot the two center-punch marks with a small drill. Get a 34mm tank cutter (a.k.a hole saw, starrett cutter) and drill a mm at a time swapping between the two holes so you are describing two over-lapping circles. Swap between them until one breaks though then remove that disc and drill the other using the hole in the timber beyond as a guide. Use a half-round file to tidy the job up.
If you are burning out hole saws then you have a hole saw for drilling timber or you are turning it too fast. Use water or oil for coolant/lube. ____________________ a.k.a 'Geri'
| Walloper |
 Walloper Super Spammer
| effit |
 effit Scooby Slapper
 Posted: 20:36 - 27 Apr 2010 Post subject: |
Use a mag drill with a 34mm cutter, any Fab shop will have one and shouldnt cost you a lot of dosh to have it done. The ones Ive used are Evolution but I think Rothenberger and a few other types are out there. Even have a look and see if you can hire one for a couple of hours at a local tool shop.
The shop will probably ram you for the cost of the drill bit so have a looky on Egay or somewhere like that.
here is one similar to what i`m talking about...
https://www.evolutionpowertools.co.uk/us/evolution_me3500.html
| stinkwheel |
 Posted: 20:38 - 27 Apr 2010 Post subject: |
I agree with Tristan.. A milling machine is the weapon of choice for this task.
If you take it in already marked out, they might even do it for a six pack of beer during their lunch break. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jimspeed |
 jimspeed World Chat Champion
| Walloper |
| jimspeed |
 Posted: 21:37 - 27 Apr 2010 Post subject: |
na and its a bit big to post..  ____________________ Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?" |
| binge |
 binge Emo Kiddy
| stinkwheel |
| binge |
 binge Emo Kiddy
| stinkwheel |
| BanditsHigh |
 BanditsHigh Worse than a woman
 Posted: 06:19 - 28 Apr 2010 Post subject: |
Just use a jigsaw with a metal cutting blade ... I made some suspension linkages out of 6mm stainless steel and although it took a while it worked out ok ... 4mm steel will be a breeze  |
| Walloper |
| Pete. |
 Pete. Super Spammer
 Posted: 11:27 - 28 Apr 2010 Post subject: |
You can drill stainles with a hole saw no problem, you use low speed and high pressure (and coolant). Some stainless steels work-harden very quickly if you don't use enough pressure. I drilled four 38mm holes in 6mm thick 316 stainless with one drill and it still had all it's teeth. ____________________ a.k.a 'Geri'
| stinkwheel |
| Blau Zedong |
 Blau Zedong Banned
| Walloper |
 Posted: 12:06 - 28 Apr 2010 Post subject: |
Thermal Conductivity
Steel, Carbon 17 - 43 (app)
Stainless Steel 16
Aluminium 118 -144
Copper 204 - 233
Silver 248 (best)
Gold 182
Platinum 42
Generally, a material's electrical conductivity is almost equal to it's thermal conductivity.
Stinkers, have you tried putting a bar of Aluminumimnun and one of Steel in a fire to find out which one you drop first?  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 12:14 - 28 Apr 2010 Post subject: |
Oooh I thought thermal conductivity was at least partly dependent on the density of the material...
Learn something new everyday eh  |
| stinkwheel |
| Pete. |
 Pete. Super Spammer
 Posted: 19:35 - 28 Apr 2010 Post subject: |
What an excellent line to drop into a conversation "Back when I did fire-eating"
Yes, that would be the reason - the heat was radiating off the aluminium rod. The denser steel rod would store more heat and radiate it less quickly. ____________________ a.k.a 'Geri'
| Walloper |
The last post was made 15 years, 245 days ago. Instead of replying here, would creating a new thread be more useful? |
