Confidence in corners.... new rider
deanmcreynold...
PostPosted: 19:56 - 02 May 2010    Post subject: Confidence in corners.... new rider Reply with quote
Hello,
Got my licence a few weeks ago now and been out getting used to the bike as much as i can...
Im pretty confident on the bike and will give it some on the straights then i come to the corners and seem to be continuously assesing my entry speed, once in the corner ill happily accelerate round and out of it.
I know im pretty new and its gona take time, just looking for some advice or experiences to help me out, had a car up my arse earlier in a corner i slowed down quite a bit and i dont want to hold the traffic up either, but im not going to let a car dictate how fast and capable i am Rolling Eyes
Been on youtube and had a look at some cornering technique videos...
Clanger
Stirrer
PostPosted: 20:01 - 02 May 2010    Post subject: Reply with quote
Best way to improve your cornering is to go out with someone competent and follow them. Then practice. Thing to remember is road surface, camber, temperature, and weather all come into play.
And yeah, experience comes with time, so just be patient and let yourself learn at your own speed. Sod what other road users think.
Another top tip...before you post a new post...READ THE FORUM...do a search...this was about 4 posts down... https://www.bikechatforums.com/viewtopic.php?t=195756
Whosthedaddy
PostPosted: 20:29 - 02 May 2010    Post subject: Reply with quote
Relax and don't think.
Best way to ride naturally.
The Artist
PostPosted: 21:22 - 02 May 2010    Post subject: Reply with quote
Just get loads of riding hours in on some bendy roads and you will get into a natural pattern.
deanmcreynold...
PostPosted: 21:33 - 02 May 2010    Post subject: Reply with quote
that was the plan today, until it starting peeing it down...
confidence in my tyres is another thing lol
T0MMY
PostPosted: 21:37 - 02 May 2010    Post subject: Reply with quote
Just read the other thread, it's all in there.
In summary, be smooth, progress slowly, think about your lines and tyres are better than you think.
ZX6R + CBR600RR
PostPosted: 22:18 - 02 May 2010    Post subject: Reply with quote
Part 1 good, part 2 fail.
DaveH
PostPosted: 22:28 - 02 May 2010    Post subject: Reply with quote
Use the "Limit Point" and position yourself on the road correctly keeping to the outside of the approaching corner to allow maximujm visibility through it.
https://www.msgroup.org/forums/mtt/topic.asp?TOPIC_ID=10495
and
https://www.youtube.com/watch?v=Rb2gZVuoNU4
Takes practice, but then it becomes second natures Thumbs Up and always read the road as far ahead as possible, without forgetting the mid and near distance Smile
https://www.timhastingsracing.co.uk/
ZX7R & ER6F
The Artist
PostPosted: 22:32 - 02 May 2010    Post subject: Reply with quote
I know it will take a while but you can lean a lot further than you think. Even on my crappy bike I can get right down on either side a lot further than I would have thought possible before riding it. It will take time though.
Acemastr
PostPosted: 08:51 - 03 May 2010    Post subject: Reply with quote
as much as it's not GOOD advice, I found that going into a corner wayyy too hot (not on purpose, just didn't realise) and HAVING to lean the fucker over lets you know how far over you can go.
*disclaimer* yes it's not good advice, but it is in a way, if you need to turn more, lean more, it's the only option. *don't die* Smile
2016 Toyota Tacoma Limited
robbieguy2003
PostPosted: 09:44 - 03 May 2010    Post subject: Reply with quote
One thing I've noticed on my bike, lean a lot on a slow corner, it'll feel pretty terrible (i.e. leaning too much just for the sake of it).
Add some speed to it and it feels a lot better. My feel for it improves as the suspension has some load on it, if its too unloaded then i dont seem to be able to measure/feel the grip as well.
So going in too hot should load you up a little and give you good grip.
Current Bikes: Honda CBR 600RR - '07, Suzuki GSX1250 FA ST '11
Old Bikes: Suzuki Intruder 125 LC - '2001, Honda CBR 600F - '92, Honda CBR 600RR - '03
deanmcreynold...
PostPosted: 21:21 - 04 May 2010    Post subject: Reply with quote
cheers for the replys guys...
been watching the keith code twist of wrist II on youtube and got a good bit from that as well, just gona take it easy and ill get there!
Alexio
PostPosted: 00:55 - 05 May 2010    Post subject: Reply with quote
I agree with robbieguy2003, if you enter the corner too slowly (because of lack of confidence) you won't get the right feel for the corner and won't be learning how to corner at all.
Here's what I would do:
Just stick to the speed limit and practice your corners. There are very few corners my bike hasn't been capable of taking at the speed limit unless extremely twisty at the NSL (use your common sense).
After that then you car start to push further.
Ratmonkey
PostPosted: 07:56 - 05 May 2010    Post subject: Reply with quote
Try going out early evening when the roads are quieter and most communters are at home. Pick a nice twisty road and go for a sensible ride. Adjust your speed so your entry to the corner isnt too fast then as you go into the corner keep looking at your exit point. As long as you keep focusing on your exit you will get around the corner and practising this enough will enable you to gain confidence. Dont think about how far to lean over, just think about going through the corner as smooth as possible each time.
Current Bike - 2005 Triumph 1050 Speed Triple
Previous Bikes - Yamaha R1,Hornet 600, Triumph T595 Daytona, Kawasaki ZX6R, Ducati 600ss
Small Bikes - FSIE, RD50, RD125LC, Kawasaki KH125, Suzuki GP100, TS125X, DT50
Smooth
PostPosted: 09:29 - 05 May 2010    Post subject: Re: Confidence in corners.... new rider Reply with quote
That's probably true for 90% of riders.
Ride more and don't give it so much on the straight bits -any fool can do that- so that you don't need to over-brake for the corners and can then build up your confidence. It takes time to understand how the bike responds.
Good observation allows for good anticipation.
Practice means that you will be able to use the controls (gas, gears,brakes, indicators, horn, lights) without having to think about them all individually and so will eventually ride more smoothly.
Make sure that your suspension is working and set-up correctly.
TDM850
PostPosted: 10:21 - 05 May 2010    Post subject: Reply with quote
You'll only gain confidence with either training or practice, and training will only take you so far.
As you're new it's better to be entering the corners too slow than too fast, because it saves having to roll-off the throttle mid-corner, which will tip you in and require either application of power or a tightening of the turn to stand you back up again (neither of which might be desirable). Another reason to start more slowly is target-fixation. You should always be looking at where you want to go, not where you bike is pointed. It's not rare for an inexperienced rider to run right into the kerb on even a gentle bend simply because they have fixed their vision on a point and headed straight for it. It only takes a moment of this for the brain to lose track of it's constant speed-and-direction calculations and then panic sets in. If you are travelling more slowly you give yourself more time to react, your brain is processing info at a slower rate and you're less likely to freeze up and run off the road.
It also gives you a safety-factor to deal with decreasing-radius turns. Motorway slip-roads are the most commonly found example of these.
Smooth
PostPosted: 13:54 - 05 May 2010    Post subject: Reply with quote
Although I've not quite done that, the concept is correct and, with experience, a rider looks at where they want to go, not directly in front of them or at a hazard that they are trying to avoid.
I found myself sometimes turning in too early (to prevent running wide) when I started and ended up pointing into the apex of the corner. I soon learned!
TDM850
poorboyspost
PostPosted: 02:55 - 06 May 2010    Post subject: Reply with quote
Well just don't forget to wear your safety gear and drive safely.
Pimp my RIDE
Alexio
PostPosted: 03:37 - 06 May 2010    Post subject: Reply with quote
I would suggest you try to ride safely too Thumbs Up Razz
The last post was made 16 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 104.97 Kb
