| deanmcreynold... |
 deanmcreynold... Two Stroke Sniffer
 Posted: 19:56 - 02 May 2010 Post subject: Confidence in corners.... new rider |
Hello,
Got my licence a few weeks ago now and been out getting used to the bike as much as i can...
Im pretty confident on the bike and will give it some on the straights then i come to the corners and seem to be continuously assesing my entry speed, once in the corner ill happily accelerate round and out of it.
I know im pretty new and its gona take time, just looking for some advice or experiences to help me out, had a car up my arse earlier in a corner i slowed down quite a bit and i dont want to hold the traffic up either, but im not going to let a car dictate how fast and capable i am
Been on youtube and had a look at some cornering technique videos... |
| Clanger |
 Clanger Stirrer
 Posted: 20:01 - 02 May 2010 Post subject: |
Best way to improve your cornering is to go out with someone competent and follow them. Then practice. Thing to remember is road surface, camber, temperature, and weather all come into play.
And yeah, experience comes with time, so just be patient and let yourself learn at your own speed. Sod what other road users think.
Another top tip...before you post a new post...READ THE FORUM...do a search...this was about 4 posts down... https://www.bikechatforums.com/viewtopic.php?t=195756 ____________________ Be who you are and say what you feel, because those who mind don't matter, and those who matter won't mind - Dr. Seuss |
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 20:29 - 02 May 2010 Post subject: |
Relax and don't think.
Best way to ride naturally. ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| The Artist |
 The Artist Super Spammer
| deanmcreynold... |
| T0MMY |
 T0MMY World Chat Champion
| MarJay |
 MarJay But it's British!
| DaveH |
 DaveH World Chat Champion
| The Artist |
| Acemastr |
 Acemastr World Chat Champion
 Posted: 08:51 - 03 May 2010 Post subject: |
as much as it's not GOOD advice, I found that going into a corner wayyy too hot (not on purpose, just didn't realise) and HAVING to lean the fucker over lets you know how far over you can go.
*disclaimer* yes it's not good advice, but it is in a way, if you need to turn more, lean more, it's the only option. *don't die*  ____________________ 2017 KTM 350 XC-F - 2014 Yamaha R6 - 2005 Yamaha YZ125
2016 Toyota Tacoma Limited |
| robbieguy2003 |
 robbieguy2003 World Chat Champion
| deanmcreynold... |
 Posted: 21:21 - 04 May 2010 Post subject: |
cheers for the replys guys...
been watching the keith code twist of wrist II on youtube and got a good bit from that as well, just gona take it easy and ill get there!
| Alexio |
 Alexio World Chat Champion
| Ratmonkey |
 Ratmonkey Nova Slayer
 Posted: 07:56 - 05 May 2010 Post subject: |
Try going out early evening when the roads are quieter and most communters are at home. Pick a nice twisty road and go for a sensible ride. Adjust your speed so your entry to the corner isnt too fast then as you go into the corner keep looking at your exit point. As long as you keep focusing on your exit you will get around the corner and practising this enough will enable you to gain confidence. Dont think about how far to lean over, just think about going through the corner as smooth as possible each time. ____________________ Current Bike - 2005 Triumph 1050 Speed Triple
Previous Bikes - Yamaha R1,Hornet 600, Triumph T595 Daytona, Kawasaki ZX6R, Ducati 600ss
Small Bikes - FSIE, RD50, RD125LC, Kawasaki KH125, Suzuki GP100, TS125X, DT50 |
| Smooth |
 Smooth Could Be A Chat Bot
| Pete. |
 Pete. Super Spammer
 Posted: 10:21 - 05 May 2010 Post subject: |
You'll only gain confidence with either training or practice, and training will only take you so far.
As you're new it's better to be entering the corners too slow than too fast, because it saves having to roll-off the throttle mid-corner, which will tip you in and require either application of power or a tightening of the turn to stand you back up again (neither of which might be desirable). Another reason to start more slowly is target-fixation. You should always be looking at where you want to go, not where you bike is pointed. It's not rare for an inexperienced rider to run right into the kerb on even a gentle bend simply because they have fixed their vision on a point and headed straight for it. It only takes a moment of this for the brain to lose track of it's constant speed-and-direction calculations and then panic sets in. If you are travelling more slowly you give yourself more time to react, your brain is processing info at a slower rate and you're less likely to freeze up and run off the road.
It also gives you a safety-factor to deal with decreasing-radius turns. Motorway slip-roads are the most commonly found example of these. ____________________ a.k.a 'Geri'
| Smooth |
| poorboyspost |
 poorboyspost Derestricted Danger
 Posted: 02:55 - 06 May 2010 Post subject: |
Well just don't forget to wear your safety gear and drive safely. ____________________ Pimp my RIDE |
| Alexio |
The last post was made 16 years, 131 days ago. Instead of replying here, would creating a new thread be more useful? |
