spindle protection
nightshaddow
PostPosted: 12:38 - 04 May 2010    Post subject: spindle protection Reply with quote
after the winter i decided to service up the rear end, the last few times i have removed it it has looked like this
https://img215.imageshack.us/img215/2224/spindle1.jpg
after 10 mins on the wire wheel on the bench grinder they look like this
https://img704.imageshack.us/img704/8185/spindle2.jpg
question is it only takes a few weeks to look rusty again so how can i protect it all
Itchy
PostPosted: 12:48 - 04 May 2010    Post subject: Reply with quote
Well the inside should have been packed with grease, I grease the spindles quite heavily and the outer bits get FS365'd.
nightshaddow
PostPosted: 13:17 - 05 May 2010    Post subject: Reply with quote
stupid question maybe but never hear of it, what is it and where can i get it?
also what grease is best to use? i have used copper slip and lithium grease both with the same result....
Itchy
PostPosted: 13:34 - 05 May 2010    Post subject: Reply with quote
Copper grease! copper grease is an abbrasive!.
I use whatever there is to hand previously using this yellow castrol stuff then a sachet of moby grease I found lying around, but copper grease is a no no!
DrDonnyBrago
PostPosted: 13:40 - 05 May 2010    Post subject: Reply with quote
FS365 is a scottoiler product, similar to ACF50 but a lot cheaper.
Spray it on absolutely everything (esp those things made of metal) except for your brakes, tyres, seat and grips - makes washing it easier and does a good job at stopping corrosion.
This reminds me that mine is due a top up.
Thom
PostPosted: 14:45 - 05 May 2010    Post subject: Reply with quote
As has been said copper grease is abrassive, it has fine particles of copper in it and is generally used to maintain a condustive connection or prevent seizure.
You're problem there is the steel is rusting as a result of not being protected.
Again, as has been said you should have the axle heavily greased, including the spacers, and i also grease the chain adjusters heavily too with a general automotive grease (i believe mines bearing grease) which in my case comes in a tin by castrol and is smooth (unlike copper grease) and yellow/clear.
If you dont care how dirty your bike looks grease the heads of the nuts and bolts too, it'll help protect them, your copper grease can be used on the spingle nut and chain adjuster bolt/nut to prevent them seizing through rust.
PostPosted: 15:40 - 05 May 2010    Post subject: Reply with quote
There shouldn't be any parts moving against the wheel spindle. It remains stationary, the bearing inner races remain stationary clamped between the spacers. As such, using a mildly abrasive grease is neither here nor there, there is nothing for it to abrade because abrasion requires movement. The only movement it should be seeing is when the spindle is pulled in or out during wheel removal.
The problem you are trying to prevent is the spindle seizing in place and corroding.
As such, I use copper grease on my wheel spindles. I wouldn't if they had open bearings in case it contaminated the bearing grease but mine are all sealed.
PostPosted: 15:48 - 05 May 2010    Post subject: Reply with quote
ACF50 Very Happy Very Happy Very Happy Very Happy Very Happy here's something I found after a quick search ......
ACF-50 is a state-of-the-art compound for controlling corrosion on aircraft electrical and avionics systems and airframes. ACF-50 is certified under Mil-C-81309-E, Amendment 3, Type II. ACF-50 is manufactured under ISO 9000 Certified Processes. Used in motorcycles ACF-50 protects the bare metal finish with a thin film to keep the surface looking as good as it did when you applied it.
THE CORROSION PROCESS:
When moisture is present for a prolonged period of time, corrosion "cells" are formed. These cells act as catalysts, feeding the transfer of electrons as long as any moisture is present.
WAXES RETAIN WATER:
Most corrosion inhibitors contain sealants such as wax, tar, asphalt, teflon or silicone lay on top of the corrosion cell. Because of their thick composition, they cannot remove the electrolyte and may actually seal it in, thereby encouraging corrosion.
ACF-50 PENETRATES THE CORROSION BY-PRODUCT:
ACF-50's ultra-thin formula easily penetrates the entire corrosion cell.
ACF-50 EJECTS THE ELECTROLYTE:
The encapsulated and emulsified electrolyte is ejected from the corrosion cell and replaced with ACF-50.
NO ELECTROLYTE = NO CORROSION:
The ACF-50 acts as an insulator, terminating the electrolytic process for 24 months!
About ACF-50:
ACF-50 was developed 15 years ago and has amassed a record of performance unique in the aerospace industry.
ACF-50 is an excellent penetrant.
ACF-50 kills any corrosion currently in progress with just one application.
ACF-50 is good for rubber, preventing it from cracking or drying out.
In most applications, ACF-50's unique properties will last for 24 months before it needs to be re-applied.
The ultra-thin-film does not hold any salt crystals, dirt particles and does not "dry", it stays a flexible liquid.
ACF-50 will not displace or melt any grease which is already in place. It will mix with it and make it more efficient.
ACF-50 is non-carcinogenic and virtually non-toxic.
ACF-50 can be easily removed with MEK or soap and water.
ACF-50 will not harm any plastics or painted surfaces.
ACF-50 can be safely applied to electrical components such as alternators, starters, magnetos, generators, distributors, carburators, wiring, switches, rheostats, compressors, battery terminals, light bulb sockets, electrical connectors, circuit breakers, ignition systems, wire harnesses, etc.
ACF-50 holds written OEM approvals from the following manufacturers: Bombardier Regional Aircraft, Douglas/Boeing Helicopter, ATR Regional Transport, Bell Helicopter Textron, The New Piper Aircraft, Gulfstream Aerospace, Robinson Helicopter, McDonnell Douglas, Enstrom Helicopter, Schweitzer Aircraft, British Aerospace, Concorde Battery, Raytheon Aircraft, Sikorsky Aircraft, MD Helicopters, Cessna Aircraft, Pilatus Aircraft, Beech Aircraft, Van's Aircraft, Extra Aircraft, Hiller Aircraft, Air Tractor, Lake Aircraft, Rolls-Royce, Britten-Norman Aircraft, Learjet, and Canadair.
Walloper
PostPosted: 16:11 - 05 May 2010    Post subject: Reply with quote
FFS!!! Shocked
Are you the Bike Chat Forum member from Lindisfarne?
Check out this to avoid too much corrosion on your commute.
https://holy-island.info/lindisfarnecastle/2010/
Normal Lithium/molybdenum/PTFE grease (or Copper Grease). I don't know what benefit there is from copper grease. The grease is only creating a barrier between moisture and the components.
To eliminate the water effect ensure the parts are very clean and dry then give them a good smeeeering of clean grease.
These parts are usually zinc plated but your's has lost this over time due to the action of salt and water.
I am another Scottoiler FS365 hoor. I even use it on the lawnmower and my mountain bike.
Call me old fashioned if you like but I am now trying Waxoil on the adjusters and any exposed metal of our CG125 and on my R1200GS. Washing will remove it but the theory is that the properties that Waxoil claim it will 'wick' into nook & crannies. Fingers krossed then.
Wild Tangent/Side-Track:
Bike makers seem reluctant to step up their game to prevent bikes dissolving under our shitty winter road dressing regime. And dealers have a standard script on offer if you complain that your bike is shedding pounds in rust.
Years ago British cars would practically melt after four or five years now there are no British car makers coz.... they wouldn't listen to customers.
British Steel offered an anti-corrosion coating on the sheet metal they produced for car manufacturers (during the rolling process). Most European companies asked for the coating. British Leyland took it bare. Rolling Eyes
DrDonnyBrago
PostPosted: 18:09 - 05 May 2010    Post subject: Reply with quote
I have to admit, nothing pisses me off more than finding another siezed/rusted part on my bike. Considering Honda's "legendary" build quality and that my bike has spent 99% of it's life in a garage, all I seem to have is problems that could be avoided if it were made out of better quality metals!
Just grease the snot out of it and hammerite all the bits you don't want to stick grease on.
PostPosted: 18:47 - 05 May 2010    Post subject: Reply with quote
I'd strongly recomend that you never, ever buy a Suzuki.
The last post was made 16 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.94 - MySQL Queries: 13 - Page Size: 79.19 Kb
