 johnsmith222 World Chat Champion
 SpicyBlimp World Chat Champion
 Posted: 23:54 - 05 May 2010 Post subject: |
chainreactioncycles.com will have everything you need, get all my parts from them.
If you email them the pictures they should tell you what you need  |
 Posted: 00:06 - 06 May 2010 Post subject: |
That's a lot of stuff you're needing there.
Can I recommend to you, www.chainreactioncycles.com Purveyors of a wide selection of reasonhably prices and speedily delivered bicycle stuff to the masses.
Brake pads first. They don't say divA. They say Avid. About £5.99 a pair.
Chainrings. It's a cheapo suntour chainset. You could replace the entire chainset (ie the whole crank complete with three chainrings attached) with a new one of equivalent quality for £16. I'm presuming it fits on a square taper. Count the teeth on your chainrings and buy the same, probably 28; 38; 48.
You'll need a crank pulling tool or a loan of one. Undo the central bolt, screw in the extractor, tighten the extractor bolt and it'll pop off.
While you're there. Judging by the shit state of the rest of it, consider replacing the bottom bracket too. You'll get a lower end, shimano square-taper, sealed bottom bracket for just over a tenner. Measure the overall length of your existing bottom bracket with the cranks removed (between 103 and 122mm usually, it's probably 118mm) also measure the width of the frame where it screws in (68 or 73mm).
The rear cogs on yours are known as a "freewheel". You'll need a pulling tool to remove yours by turning it anticlockwise using the notches in the middle. I strongly suspect it will be nigh-on impossable to remove so see if you can take it off before blowing your wad on a new one.
You have a 6-speed, spin-on freewheel. They are pretty much obsolete. Ebay is the best bet, expect to pay around a fiver.
If it wont come off, you're looking at a new wheel or making do with the one you have (if it isn't skipping on the smallest cog, it's probably ok. A clean up and lube can only help). I'd suggest replacing the wheel bearings and regreasing the hub internals.
The deralieur jockey wheels are easy. Shimano items. £2.99 a set.
The chain is in a shocking state. You'll need a 3/32", 6 or 7 speed chain. £6.99 for a cheaper end one. Count the links. You will also need a chain splitting tool to remove the old chain, remove excess links off the new one and rejoin it.
I'll also point you in the direction of Sheldon Browns superb website on how to do all things bicycle. If you don't know how to do something, look it up in the glossary and there will usually be a link to a detailed article on the subject. https://www.sheldonbrown.com/
EDIT: Tack a bottle of chain lube onto the end of your order eh? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
 Posted: 09:25 - 06 May 2010 Post subject: |
I went through the same thought processes about 2 months ago, i decided a new bike was in order as the price of the parts and tools far outweighed the value I'd place on the bike - the suspension was past it's best and realistically I would have also needed new chain, cranks, sprockets, cables , tyres, inner tubes, grips and bearings all round.
BTW, cranks and front sprocket can be removed in pikey fashion with a dremel to cut the sprockets off and then a big hammer to bash the F out of the cranks. Probably doesnt do your bottom bracket much good though.
Bin it or bodge it . |
