Mountain Bike Tech Help.
johnsmith222
PostPosted: 23:15 - 05 May 2010    Post subject: Mountain Bike Tech Help. Reply with quote
Hi guys.
I have a trek mountain bike which has been abused for the past 8 years. I have decided to go over it and make repairs and replacements where needed along with general maintenance.
My problem is that I don't know much about mountain bike parts, but I don't have any problem fitting anything. I will try to give you as much detail about each part I can and provide photos so you can tell me what I need to get my bike sorted again.
This is my shopping list.
*4x V Brake Pads
*Front Sprockets
*Rear Sprockets
*Rear Derailer Cogs
*New Chain
I am needing new V brake pads for both front and rear. The ones that are originally on there are made by avid and they say "Din A" on them. I liked them so I'll want to order something similar.
https://i14.photobucket.com/albums/a324/david_m213/AvidPads2.jpg
https://i14.photobucket.com/albums/a324/david_m213/AvidPads1.jpg
There are three front sprockets. I am wanting to replace these but I don't even know if you buy the individual sprockets or buy all three together. Here are a couple of photos if these are any help.
https://i14.photobucket.com/albums/a324/david_m213/SuntourSpeedXR180.jpg
https://i14.photobucket.com/albums/a324/david_m213/FrontSprockets.jpg
I could read "561-24" off one of them if that's any help.
Then onto the rear sprockets:
https://i14.photobucket.com/albums/a324/david_m213/RearSprockets.jpg
https://i14.photobucket.com/albums/a324/david_m213/RearSprocketsCloseup.jpg
Then there are these plastic cogs on the rear derailer:
https://i14.photobucket.com/albums/a324/david_m213/DerailerCogs.jpg
I don't know if these need replaced or not but I might as well if I'm replacing everything.
As for the chain, is it just a case of cutting it and counting all the links?
Any questions will be answered about number of teeth on specific sprockets etc if needed. The bike is a trek y26 frame if that tells you anything.
Thanks for any help. Ebay links would be best so I can get all this stuff ordered and on the way.
Very Happy
cagiva gezzer
PostPosted: 23:35 - 05 May 2010    Post subject: Reply with quote
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_249200_langId_-1_categoryId_230503
You can't replace the chain-rings on their own, they will be rivete to the crank. The freewheel can be replaced:
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_209833_langId_-1_categoryId_165540
Think it's a six speed.
Chain will he a HG/IG shimano one and parts of the drive train will be marked HG/IG.
SpicyBlimp
PostPosted: 23:54 - 05 May 2010    Post subject: Reply with quote
chainreactioncycles.com will have everything you need, get all my parts from them.
If you email them the pictures they should tell you what you need Thumbs Up
PostPosted: 00:06 - 06 May 2010    Post subject: Reply with quote
That's a lot of stuff you're needing there.
Can I recommend to you, www.chainreactioncycles.com Purveyors of a wide selection of reasonhably prices and speedily delivered bicycle stuff to the masses.
Brake pads first. They don't say divA. They say Avid. About £5.99 a pair.
Chainrings. It's a cheapo suntour chainset. You could replace the entire chainset (ie the whole crank complete with three chainrings attached) with a new one of equivalent quality for £16. I'm presuming it fits on a square taper. Count the teeth on your chainrings and buy the same, probably 28; 38; 48.
You'll need a crank pulling tool or a loan of one. Undo the central bolt, screw in the extractor, tighten the extractor bolt and it'll pop off.
While you're there. Judging by the shit state of the rest of it, consider replacing the bottom bracket too. You'll get a lower end, shimano square-taper, sealed bottom bracket for just over a tenner. Measure the overall length of your existing bottom bracket with the cranks removed (between 103 and 122mm usually, it's probably 118mm) also measure the width of the frame where it screws in (68 or 73mm).
The rear cogs on yours are known as a "freewheel". You'll need a pulling tool to remove yours by turning it anticlockwise using the notches in the middle. I strongly suspect it will be nigh-on impossable to remove so see if you can take it off before blowing your wad on a new one.
You have a 6-speed, spin-on freewheel. They are pretty much obsolete. Ebay is the best bet, expect to pay around a fiver.
If it wont come off, you're looking at a new wheel or making do with the one you have (if it isn't skipping on the smallest cog, it's probably ok. A clean up and lube can only help). I'd suggest replacing the wheel bearings and regreasing the hub internals.
The deralieur jockey wheels are easy. Shimano items. £2.99 a set.
The chain is in a shocking state. You'll need a 3/32", 6 or 7 speed chain. £6.99 for a cheaper end one. Count the links. You will also need a chain splitting tool to remove the old chain, remove excess links off the new one and rejoin it.
I'll also point you in the direction of Sheldon Browns superb website on how to do all things bicycle. If you don't know how to do something, look it up in the glossary and there will usually be a link to a detailed article on the subject. https://www.sheldonbrown.com/
EDIT: Tack a bottle of chain lube onto the end of your order eh?
DrDonnyBrago
PostPosted: 09:25 - 06 May 2010    Post subject: Reply with quote
I went through the same thought processes about 2 months ago, i decided a new bike was in order as the price of the parts and tools far outweighed the value I'd place on the bike - the suspension was past it's best and realistically I would have also needed new chain, cranks, sprockets, cables , tyres, inner tubes, grips and bearings all round.
BTW, cranks and front sprocket can be removed in pikey fashion with a dremel to cut the sprockets off and then a big hammer to bash the F out of the cranks. Probably doesnt do your bottom bracket much good though.
Bin it or bodge it Thumbs Up .
The last post was made 16 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 49.68 Kb
