ts 50 when its put into gear it goes backwards
sgaliwags
PostPosted: 20:25 - 06 May 2010    Post subject: ts 50 when its put into gear it goes backwards Reply with quote
hi please can anyone help me! i have just put a new piston kit and after starting the bike it moves in reverse help
jimspeed
PostPosted: 20:32 - 06 May 2010    Post subject: Reply with quote
is it 2 stroke? maybe its running backwards i have heard of it. have you tried bump starting it forwards?
bet that gave you a shock when you let the clutch out lol Rolling Eyes
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
Fisty
PostPosted: 20:33 - 06 May 2010    Post subject: Reply with quote
Try bump starting it. Mates Mito did the same, we bumped it forward in 2nd and it was fine.
Tom
Fatter and faster than Fret
sgaliwags
PostPosted: 20:38 - 06 May 2010    Post subject: Reply with quote
i have tried bumping it n still wont go forward and ye lol it did give me quiet a reaction very strange aye
stirlinggaz
PostPosted: 20:54 - 06 May 2010    Post subject: Reply with quote
happened to me last year on the mtx. (i posted in here, iirc)
scared the f*ck out of me, as i stalled it in the middle of the dual carriage way. (was having timing problems)
the look on the fat birds face in the x5 behind me was a picture. (im sure mines was as well) as i hurtled backwards in 2nd.
had to stall it & ended up doing a accidental wheelie
& then bump it a few times to get it to go forwards.
f*cking hilarious.
cheers,
GAZ Very Happy :
finpos
PostPosted: 21:05 - 06 May 2010    Post subject: Reply with quote
Ignition timing way too advanced. It's probably not adjustable so my guess is you've had the flywheel off?
f.
sgaliwags
PostPosted: 21:15 - 06 May 2010    Post subject: Reply with quote
no m8 i havnt had the flywheel off
sgaliwags
Blue_SV650S
PostPosted: 22:17 - 06 May 2010    Post subject: Reply with quote
It does sound like the timing has slipped, my guess is the flywheel has turned on the crankshaft.
cloric_tzr
PostPosted: 22:47 - 06 May 2010    Post subject: Reply with quote
has the bike been dropped? prehaps it has concution. couple of days bed rest and she'll be fine
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
sgaliwags
PostPosted: 10:38 - 07 May 2010    Post subject: Reply with quote
does anyone know how i can fix the timming?? n thanx for the rather intresting replies Laughing
everyreasonto
PostPosted: 12:12 - 07 May 2010    Post subject: Reply with quote
Sounds stupid, but you haven't put it in reverse have you? Laughing
Blue_SV650S
PostPosted: 01:18 - 08 May 2010    Post subject: Reply with quote
yes, you need to get a timing light on the HT lead ...
But to be frank, the only realistic way the timing can be out is if the flywheel has spun on the crank slightly.
For this to happen, the woodruff key will be broken when/if you take the flywheel off ...
hmmmnz
PostPosted: 03:35 - 08 May 2010    Post subject: Reply with quote
sounds like when you put the piston back on, the conrod when the wrong way,
if you put the bike on the center stand and chuck it in top gear, and turn the back wheel forward in the normal direction of travel, it should reach tdc and correct itself,
bump starting should have the same affect,
really this shouldnt be able to happen unless you bump start the bike back wards, as when you kick the bike over it turns the crank in the right direction
the humans are dead
I kick arse for the lord
Blue_SV650S
PostPosted: 10:41 - 08 May 2010    Post subject: Reply with quote
I am not really sure what you are proposing has happened there ... Confused
Blue_SV650S
PostPosted: 11:02 - 08 May 2010    Post subject: Reply with quote
CHR15 wrote:
i think he means, did he put the piston in the wrong way round.
i would of thought if it was a ported piston, it wouldnt work at all?
The TS50X is reeds ... not sure about the ER ...
If it is the ER then it is a possibility I suppose ... and the OP didn't state which ...
sgaliwags
PostPosted: 11:03 - 08 May 2010    Post subject: Reply with quote
it will only bump start in revers lol,everithing is bk in the correct way, do i have to get the flyweel off to sort out the timing.the bike runs excelent but in the wrong direction,how do i sort this out lol Crying or Very sad
stirlinggaz
PostPosted: 11:06 - 08 May 2010    Post subject: Reply with quote
hi,
take the flywheel off & see if the woodruff key has sheared,
cheers,
GAZ
Paxovasa
What happens when you try and bump start it forwards.
Paxovasa
PostPosted: 11:16 - 08 May 2010    Post subject: Reply with quote
iva already asked this twice, and havnt had a sensible answer yet.
I noticed Thumbs Up I thought I would try Razz
paddlesat16
PostPosted: 11:18 - 08 May 2010    Post subject: Reply with quote
The powerband is broke, he needs a new one... god you lot don't no nuffink.. Laughing
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
sgaliwags
PostPosted: 19:23 - 08 May 2010    Post subject: Reply with quote
it wont bump start forwads at all or it wont kick start. it will only start if i bump it in reverse lol, the engin is running in the oposit direction Question
sgaliwags
PostPosted: 20:00 - 08 May 2010    Post subject: Reply with quote
i found out by accident when i was moving it was in gear as i moved it bk words and it fired up lol. the piston is in corect with the arow pointing to the outlet,if it was in the wrong way it woldnt run at all Laughing
PostPosted: 20:06 - 08 May 2010    Post subject: Reply with quote
You should do what Stirlingaz suggested, and remove the flywheel to check if the key is sheared.
Blue_SV650S
PostPosted: 20:11 - 08 May 2010    Post subject: Reply with quote
Depends on the skirting of the piston to be fair ...
Many pistons are symmetrical, so it would run either way round .. the reason the pistons are direction arrow is so that the ring ends are cunningly located such that they can't catch on a port as they just miss them all!! Cool
The last post was made 16 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 125.11 Kb
