| sgaliwags |
 sgaliwags L Plate Warrior
| jimspeed |
 jimspeed World Chat Champion
 Posted: 20:32 - 06 May 2010 Post subject: |
is it 2 stroke? maybe its running backwards i have heard of it. have you tried bump starting it forwards?
bet that gave you a shock when you let the clutch out lol  ____________________ Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?" |
| Fisty |
 Fisty Super Spammer
| sgaliwags |
| stirlinggaz |
 Posted: 20:54 - 06 May 2010 Post subject: |
happened to me last year on the mtx. (i posted in here, iirc)
scared the f*ck out of me, as i stalled it in the middle of the dual carriage way. (was having timing problems)
the look on the fat birds face in the x5 behind me was a picture. (im sure mines was as well) as i hurtled backwards in 2nd.
had to stall it & ended up doing a accidental wheelie
& then bump it a few times to get it to go forwards.
f*cking hilarious.
cheers,
GAZ : |
| finpos |
 finpos World Chat Champion
| sgaliwags |
| sgaliwags |
| Blue_SV650S |
| cloric_tzr |
 cloric_tzr Brolly Dolly
| sgaliwags |
 Posted: 10:38 - 07 May 2010 Post subject: |
does anyone know how i can fix the timming?? n thanx for the rather intresting replies  |
| everyreasonto |
 everyreasonto Nitrous Nuisance
 Posted: 12:12 - 07 May 2010 Post subject: |
Sounds stupid, but you haven't put it in reverse have you?  |
| Blue_SV650S |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 03:35 - 08 May 2010 Post subject: |
sounds like when you put the piston back on, the conrod when the wrong way,
if you put the bike on the center stand and chuck it in top gear, and turn the back wheel forward in the normal direction of travel, it should reach tdc and correct itself,
bump starting should have the same affect,
really this shouldnt be able to happen unless you bump start the bike back wards, as when you kick the bike over it turns the crank in the right direction ____________________ the humans are dead
I kick arse for the lord
| Blue_SV650S |
| Blue_SV650S |
| sgaliwags |
 Posted: 11:03 - 08 May 2010 Post subject: |
it will only bump start in revers lol,everithing is bk in the correct way, do i have to get the flyweel off to sort out the timing.the bike runs excelent but in the wrong direction,how do i sort this out lol  |
| stirlinggaz |
| Paxovasa |
 Paxovasa World Chat Champion
| Paxovasa |
| paddlesat16 |
 paddlesat16 Crazy Courier
 Posted: 11:18 - 08 May 2010 Post subject: |
The powerband is broke, he needs a new one... god you lot don't no nuffink..  ____________________ I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T. |
| sgaliwags |
 Posted: 19:23 - 08 May 2010 Post subject: |
it wont bump start forwads at all or it wont kick start. it will only start if i bump it in reverse lol, the engin is running in the oposit direction  |
| sgaliwags |
 Posted: 20:00 - 08 May 2010 Post subject: |
i found out by accident when i was moving it was in gear as i moved it bk words and it fired up lol. the piston is in corect with the arow pointing to the outlet,if it was in the wrong way it woldnt run at all  |
 Posted: 20:06 - 08 May 2010 Post subject: |
You should do what Stirlingaz suggested, and remove the flywheel to check if the key is sheared. ____________________ a.k.a 'Geri'
| Blue_SV650S |
The last post was made 16 years, 171 days ago. Instead of replying here, would creating a new thread be more useful? |
