How much oil ?
Dazbo666
PostPosted: 15:34 - 08 May 2010    Post subject: How much oil ? Reply with quote
Just curious if anyone knows off the top of their head, or can check for me, how much oil I'd need for an oil and filter change...
I have a 2003 Suzuki Bandit 600N, and it's overdue for an oil change.
I already have a new filter, and a magnetic drain plug but less than half a jack of bike oil waiting at home. I haven't changed the oil on this particular bike before, so would hate to have drained the oil only to find out that I don't have enough to replace the new oil.
(I have a Haynes manual at home, but I'm at work at the moment, and curious if I should pick some up on the way home.)
Cheers Thumbs Up
Word of the day : DILLIGAF
Paxovasa
PostPosted: 15:38 - 08 May 2010    Post subject: Reply with quote
Should be stamped on the bike next to the oil filler cap Thumbs Up
Mine says 3.3 litres
Dazbo666
PostPosted: 16:06 - 08 May 2010    Post subject: Reply with quote
Will check if it's stamped, but if it's anything like 3.3 litres I'll probably need another jack. I have just under half of a 5 litre jack at home, so probably not enough Confused
Paxovasa
PostPosted: 16:11 - 08 May 2010    Post subject: Reply with quote
I have a 2003 bandit 600 naked, and it does take 3300ml. That is stamped on the bike. Thumbs Up
PostPosted: 16:20 - 08 May 2010    Post subject: Reply with quote
Is that not just oil. Usually with a filter too change they take a couple of hundred ml more.
Paxovasa
PostPosted: 16:30 - 08 May 2010    Post subject: Reply with quote
I always change the oil filter whenever I change the oil.
I don't adhere to the 3300ml, I will measure out 3 litres, then add more oil so it is between the high and low mark.
I then start the engine and let it run for a couple of minutes, then switch it off, leave it a few minutes, then top up if required.
I only posted about 3300ml as it is stamped on the bike and I use it as a guide. Thumbs Up
PostPosted: 16:35 - 08 May 2010    Post subject: Reply with quote
Measure what comes out. Saves time for the next service.
Manual for my 250 says 2lts when dry. 1.7 when oil change. I checked mine before emptying (middle of dipsick). Measured what came out (1.8ltrs)
Jobs a good'un Thumbs Up .
Pat
Dazbo666
PostPosted: 17:08 - 08 May 2010    Post subject: Reply with quote
Exactly what I did with my previous bike, but this is the first change that I've done with the Bandit.
Cheers for the advice Thumbs Up Karma
Ditto
PostPosted: 18:09 - 08 May 2010    Post subject: Reply with quote
3.3 L straight oil change,
3.5 L oil change + filter,
4.6 L if youve just rebuilt the engine and given it an overhaul, (which you probably haven't Thumbs Up)
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
TUG
PostPosted: 19:21 - 08 May 2010    Post subject: Reply with quote
200ml more i think off the top of my head possibly 300ml.
Haz ER-5, innit!
Paxovasa
PostPosted: 19:23 - 08 May 2010    Post subject: Reply with quote
The filter on a bandit is tilted upwards so the oil drains out of it Thumbs Up
TUG
PostPosted: 19:27 - 08 May 2010    Post subject: Reply with quote
Are you serious with that post? Rolling Eyes
Oil filters still like to hold oil when tipped anyway and will take hours for it to completely drain.
Do you change alot of oil filters and work on alot of bikes just out of curiousity?
Haz ER-5, innit!
Paxovasa
PostPosted: 19:30 - 08 May 2010    Post subject: Reply with quote
No, I wasn't been serious Razz
But it is best to get the oil warm before changing it, as it will be thinner and drain quicker*
*serious comment.
TUG
PostPosted: 19:37 - 08 May 2010    Post subject: Reply with quote
*serious comment.
Yes it would, go for a 40 min ride and then as soon as you get back whip the drain bolt out and remove the filter, it will be like water and extremely hot obviously but just for the tards i'd thought i'd remind.
Haz ER-5, innit!
Paxovasa
PostPosted: 19:44 - 08 May 2010    Post subject: Reply with quote
*serious comment.
I always warm the engine before changing the oil.
Warm as in let it tick over for about 5 minutes Thumbs Up
The last post was made 16 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 88.28 Kb
