GS125 acting up after top end strip down.
The Artist
PostPosted: 15:54 - 10 May 2010    Post subject: GS125 acting up after top end strip down. Reply with quote
After this thread https://www.bikechatforums.com/viewtopic.php?t=196765 my bike has started acting up.
Acceleration is no where near what it was like before.
Only gets up to 45 on the flat.
Feels like someone is tugging the back of the bike like it is misfiring or something.
We had the whole top end off and adjusted the valve clearances to 0.15mm on both.
Anyone got any ideas? Only suggestion so far is valve clearances too small.
Thanks
B10Hazard
PostPosted: 16:00 - 10 May 2010    Post subject: Reply with quote
Dont let ginger people fuck around with your bike then Thumbs Up
You always break stuff when pointlessly playing with stuff !
You best have my box moss Wink
No longer any socks
B10Hazard
PostPosted: 16:09 - 10 May 2010    Post subject: Reply with quote
Maybe your getting fatter Thumbs Up
I bet i can get 60
No longer any socks
27cows
PostPosted: 16:51 - 10 May 2010    Post subject: Reply with quote
Valve timing to buggery, perhaps.
The Artist
PostPosted: 16:52 - 10 May 2010    Post subject: Reply with quote
I know roughly what speed I am doing. I can see everything go past and estimate a speed. Definitely not doing over 50.
The Artist
PostPosted: 16:55 - 10 May 2010    Post subject: Reply with quote
rob yarrr wrote:
stop wasting your money and get a big bike
LOL I haven't spent any money.
The Artist
PostPosted: 17:17 - 10 May 2010    Post subject: Reply with quote
Here we go...
Does anyone have any real suggestions?
Alexio
PostPosted: 17:19 - 10 May 2010    Post subject: Reply with quote
I assume the carb was cleaned and that all the pipes and tubes are clear of obstructions and that the jetting is nice and that the spark plug is sparking brightly.
In which case do a compression test.
paddlesat16
PostPosted: 19:07 - 10 May 2010    Post subject: Reply with quote
What do you mean by a top end strip down, have you had the head off and barrel? poked about and put it back together.
1 your timing might be out by one tooth or more
2 Your compression is low, possibly gummed up rings
3 Valves need adjusting properly, the gaps are too large and it's overfueling. or too tight and your not getting enough fuel/exhaust
4 the carb is full of crap/needs adjusting
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
cloric_tzr
PostPosted: 21:10 - 10 May 2010    Post subject: Reply with quote
the carb had shit in it.
well you really should find somewhere better to go toilet then should'nt you? Mr. Green
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
rob_scott92
PostPosted: 21:22 - 10 May 2010    Post subject: Reply with quote
To me it sounds like they'd be too large if anything! Shocked
The smallest 'permitted' is 0.08mm, so try setting them somewhere in the middle like 0.10mm.
Rob Thumbs Up
First bike: 1982 Suzuki Gs 125 'The beast MK1' Wink > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p
The Artist
PostPosted: 21:29 - 10 May 2010    Post subject: Reply with quote
I think shaking the tank around when it was nearly empty mixed up some crap which got pulled into the tank when we took the top end off.
Still doesn't feel 100% right and I think the valve clearances should be 0.12mm-0.13mm or something so that might make a difference.
rob_scott92
PostPosted: 21:36 - 10 May 2010    Post subject: Reply with quote
Manual says 0.08-0.13, may be worth setting them at 0.10 to see if it helps? I think 0.15 is a bit loose tbh, how long did you take it out for? would it have been hot enough to start tapping?
Ditto
PostPosted: 21:38 - 10 May 2010    Post subject: Reply with quote
CHR15 wrote:
paddlesat16 wins the prize with answer number 4.
my engine rebuilding skills are fine. so are my valve timing skills.
Not to spoil the party or anything but Alexio gave that answer a couple of hours before Shifty
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
prawny1
PostPosted: 23:28 - 10 May 2010    Post subject: Reply with quote
Did you fit a new head gasket or reuse your old one?
hellkat wrote:
Some people are only alive cos its against the law to kill them.
Alexio
PostPosted: 00:19 - 11 May 2010    Post subject: Reply with quote
Aw, thanks for sticking up for me Ditto Laughing Thumbs Up
The last post was made 16 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.35 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 98.24 Kb
