RXS Speedo Died
UnspeedySam
PostPosted: 11:20 - 13 May 2010    Post subject: RXS Speedo Died Reply with quote
I think it happened when I hit a camouflaged pot hole last night. But the speedo now reads 0 regardless of speed. I probably won't have time to have a look until the weekend, but what is the problem most likely to be? I'm going to take apart the clock and see if the drive is turning first I think...
Itchy
PostPosted: 11:21 - 13 May 2010    Post subject: Reply with quote
Just undo the cable going into the back of the clocks, roll bike forward the cable spins? = your clocks are the broken bit.
If doesn't turn then your cable is snapped 5 minute replacement job.
Paxovasa
PostPosted: 11:23 - 13 May 2010    Post subject: Reply with quote
Speedo cable may just have come loose.
PostPosted: 11:38 - 13 May 2010    Post subject: Reply with quote
Do this but also hold the cable in an attempt to stop in spining (not too hard)
DrDonnyBrago
PostPosted: 12:12 - 13 May 2010    Post subject: Reply with quote
He could have broken the speedo drive too.
If pushing it forward doesn't turn the cable at the speedo end then take the cable off at both ends and spin it by hand - if it doesnt spin then yes the cable is snapped (put a little resistance on it as chris suggested though). If it does spin then the speedo drive (probably front wheel) is probably the culprit and would need replacing.
27cows
PostPosted: 17:45 - 13 May 2010    Post subject: Reply with quote
I've jarred the cable out of the speedo housing over potholes more than once. Usually you can just push the cable back into place. Makes you wonder why they didn't make it a few mm longer Confused
UnspeedySam
PostPosted: 23:41 - 13 May 2010    Post subject: Reply with quote
Whoops I forgot I posted this Razz Thanks for all the informative replies. I might have a chance to have a look tomorrow.
However much I love this bike and all the fun I've had on it, I do sometimes wish I had my friend's nearly new YBR. However, even after fixing all these little things I'll still be about £700 better off and have a more characterful bike Very Happy
Serendipity
PostPosted: 09:34 - 14 May 2010    Post subject: Reply with quote
DonnyBrago wrote:
He could have broken the speedo drive too...
Most likely to be either the cable snapped or come adrift. However I had the speedo drive go a couple of times when I used to do big daily miles on the RXS.
The weather seal on the front drum is far from perfect and I had water and road crap get in and seize the speedo drive. I seem to remember that there is a sacrificial tabbed washer that shears off and prevents further damage.
I just cleaned up the drive cogs and re-greased them, then fitted a new tabbed washer. The genuine Yamaha part was only pennies.
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
UnspeedySam
PostPosted: 11:58 - 14 May 2010    Post subject: Reply with quote
Ok, the drive cable is snapped almost cleanly in two Razz A few people mentioned putting resistance on the cable when testing it, so is it not ok to ride the bike with half a speedo cable?
Also, newbie question: What kind of grease should I buy for greasing the axle/speedo cogs when I'm fitting the new cable?
edit: Just read the haynes manual and allegedly it's as simple as removing a little clip. The little hole is full of crap on my bike so I didn't spot it... Would still like to know what grease I should be buying though, assuming the cable I just bought won't come ready-greased.
PostPosted: 12:24 - 14 May 2010    Post subject: Reply with quote
It's fine to ride with a broken cable, leave it on to save getting crap in the clocks speedo drive, I would use generic grease for the drive I can;t imagine it matter that much a new cable should be around £10
UnspeedySam
PostPosted: 12:38 - 14 May 2010    Post subject: Reply with quote
Just bought:
Yambits Speedo Cable
CarlubeLM2 Lithium Grease
Hope to get it sorted by Tuesday. Want to go to the Poole bike night and it's a bit far to go with no speedo Razz
27cows
PostPosted: 19:20 - 14 May 2010    Post subject: Reply with quote
I had about six rev counter cables but no spare speedo item when my last one snapped. So I modified the outer by shortening it, so the tacho inner cables would fit. I expected this bodge to be short lived and the inner cable to last a dozen miles before snapping...but 35,000 miles later it's still fine Laughing
The last post was made 16 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.64 - MySQL Queries: 13 - Page Size: 74.08 Kb
