Powdercoating hangers
tutton
PostPosted: 18:47 - 18 May 2010    Post subject: Powdercoating hangers Reply with quote
Bought a powercoating gun ages ago, works by negativly charging your part, and shooting positive charged powder so its attracted and sticks to your part
already had a compressor and heat gun so thought id give it a try today, this is a first attempt so not yet perfected.
First hanger part stripped off
https://i123.photobucket.com/albums/o297/Gfxs/DSC00059.jpg
Wet sanded with 120 grit to smooth and remove dirt
https://i123.photobucket.com/albums/o297/Gfxs/DSC00060.jpg
Washed and degreased with white spirit and tissue
https://i123.photobucket.com/albums/o297/Gfxs/DSC00061.jpg
Hung on some threaded bar and preheated with heatgun
https://i123.photobucket.com/albums/o297/Gfxs/DSC00062.jpg
Then shot the colour on, unlike paint once youve got enough power coating on it won't carry on sticking it will just fall off.
https://i123.photobucket.com/albums/o297/Gfxs/DSC00063.jpg
Then heated it up for around 5 mins a side with the heatgun
https://i123.photobucket.com/albums/o297/Gfxs/DSC00065-1.jpg
Finished result
https://i123.photobucket.com/albums/o297/Gfxs/DSC00068.jpg
https://i123.photobucket.com/albums/o297/Gfxs/DSC00070.jpg
Would of got a better finish on them, if i had baked them in a suitable sized box and not used a heatgun for the heat source (suggestions on what to use as a box welcome) and also if i had not spilt most of the power on the floor then scooped it back up!
Comments welcome!
bacon
PostPosted: 18:52 - 18 May 2010    Post subject: Re: Powdercoating hangers Reply with quote
alright mega tits, never powder coated before but looks like a good first attempt to me!
What you going to do next?
PostPosted: 19:06 - 18 May 2010    Post subject: Re: Powdercoating hangers Reply with quote
tutton wrote:
Would of got a better finish on them, if i had baked them in a suitable sized box and not used a heatgun for the heat source (suggestions on what to use as a box welcome)...
Your mum's oven?
mad4it028
PostPosted: 19:12 - 18 May 2010    Post subject: Reply with quote
heal plates look good have you tryed hot soapy water on the rest of the bike? i guess not...lol
tutton
PostPosted: 19:31 - 18 May 2010    Post subject: Reply with quote
Nah chives, its mildly poisenous so once its been done in the oven you shouldnt eat from it again. Need to actually make a box thatll take 180degrees for 12 minutes comfortably, shame no one can think of anything already on the market for another purpose that would work...
and madforit, im a believer of seasonal cleaning, and it only looks that horrific at the back as id oiled my chain with some valvoline wet lube and its sprayed it all over the rear, will clean her up tommorow maybe....
Charlie
PostPosted: 19:47 - 18 May 2010    Post subject: Reply with quote
Will a biscuit tin and a decent fire not do it?
tutton
PostPosted: 19:54 - 18 May 2010    Post subject: Reply with quote
Need to regulate the temperature, as ive found out with these, too high a temp and you get a little orange peel effect, so needs recoating and slow baking, fire would just get too hot.
If i can find a box ill do this for mates and that, always got people asking for items coated! keep suggestions rolling
cheers
Minty
PostPosted: 20:56 - 18 May 2010    Post subject: Reply with quote
A 2nd hand oven to leave in the garage. Maybe one of them integrated ones for smallness?
My fingers smell of your mum.
tutton
PostPosted: 21:40 - 18 May 2010    Post subject: Reply with quote
Normal ovens use around 30-40 amps if i remember right,
So may be slightly over loading it wiring it into the ring main, dont wanna set me hoose on fire or anything, or take another feed from the cooker out to the garage not really worth it tho.
Integrated ones are too small as at some point i will be planning to do wheels etc. On the guidance of bacon i have bought a galvanised bin a mini one that should do all i need to do!
CHR15
Turbo nutter bastard
PostPosted: 22:01 - 18 May 2010    Post subject: Reply with quote
a microwave with oven function.
timer and temp controlled.
build a little A frame, with a small baking tray underneath to catch exess powder.
£67 brand new sure you could find something second hand for alot less.
also, a 2kw microwave oven combi is only drawing 8 and a bit amps, so shouldnt blow anything.
400bandit
PostPosted: 22:11 - 18 May 2010    Post subject: Reply with quote
https://www.electrostaticmagic.co.uk/
Have a look on there, click systems then customers oven.
Looks ideal.
Joe
tutton
PostPosted: 12:48 - 19 May 2010    Post subject: Reply with quote
Chris its a nice idea, but id like to be able to start experimenting with larger parts such as swing arm, which would have no chance in a oven of that size Laughing
Yeah already know about that company mate,
and ikea dont sell the box anymore, i phoned and got them to check!
and then its too small for what i ultimatly want to end doing which is wheels.
PostPosted: 13:03 - 19 May 2010    Post subject: Reply with quote
I think the best option would be to pay somebody else to blast and powder coat your larger items. It's not like it's expensive.
tutton
PostPosted: 13:04 - 19 May 2010    Post subject: Reply with quote
Local powder coating shop charges around 100 for 2 bike wheels.
When if i get the setup right i could do it for like half the price easy?
PostPosted: 13:28 - 19 May 2010    Post subject: Reply with quote
Gat a box insulate it and stick 1 or 2 100w bulbs inside, You can cook a chicken using this method.
tutton
PostPosted: 13:29 - 19 May 2010    Post subject: Reply with quote
Thats basicallly the method im going down now, a box big enough and mount heatguns inside and a meat thermometer to keep it at 180 for 12 mins Laughing not pretty but functional i hope!
PostPosted: 13:37 - 19 May 2010    Post subject: Reply with quote
How much was the heat gun?
tutton
PostPosted: 13:58 - 19 May 2010    Post subject: Reply with quote
40 When i bought it,
there now around 20-30.
Not bad as long as there not dropped that kills em!
Will see if 1 gun can do the job if not ill mount a 2nd adjacent, although im hoping it shouldnt be too hard, if i prewarm it for 10 mins before hand should be fine.
PostPosted: 14:36 - 19 May 2010    Post subject: Reply with quote
I don't know why I typed heat I meant powdercoat Laughing
How much was the powder coat gun.
tutton
PostPosted: 14:41 - 19 May 2010    Post subject: Reply with quote
I paid around 80 quid for mine Thumbs Up
have seen em go as cheap before, for a similar home system about 120-130 posted usually.
400bandit
PostPosted: 16:30 - 19 May 2010    Post subject: Reply with quote
If you are deffo keen to do a fair bit more I'd make a proper oven I think, you could use a heating element like this;
https://cgi.ebay.co.uk/CARAVAN-450-WATT-HEATER-ELEMENT-/170487970975?cmd=ViewItem&pt=UK_Campervan_Caravan_Accessories&hash=item27b1dffc9f#ht_500wt_1182
Pop it in the bottom of one of them metal cabinets and then wrap it in fibre glass insulation (or similar)
Joe
tutton
PostPosted: 16:33 - 19 May 2010    Post subject: Reply with quote
i am keen,
will that element get hot enough to do 180 degrees in a space big enough for a 18" alloy tho..
i doubt it? and then ill have to make up some theromostat or something as theres no heat control with a element alone..
Rowey
PostPosted: 17:11 - 19 May 2010    Post subject: Reply with quote
What if you made a brick box. You can make is as big as you want. Use a couple layers of kiln bricks. Layer it with ceramic tiles. Put a door on it or a lid.
Then use something like a deconstructed electric element heater.
A home 5 element heater should do the job as long as you removed any plastic it shoudln't melt. Fit a rheostat to regulate the power then use a thermometer to calibrate it.
ZX6R C6F.
tutton
PostPosted: 17:16 - 19 May 2010    Post subject: Reply with quote
Could do this if doing this takes off, at the moment im builing something short term before i build my own oven,
Ultimatly itll be one in sheet steel, with insulation inside, door, cooker element thermostatically controlled, and the whole unit be on some small caster wheels for wheels etc easier loading...
well thats the plan!
L-Jam
PostPosted: 17:47 - 27 May 2010    Post subject: Reply with quote
Fair play to you mate, awesome 'go and do it' attitude you have! If more people were like this, maybe places wouldn't charge as much for services.
Journalist, student, egotist.
The last post was made 16 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 2.26 - MySQL Queries: 13 - Page Size: 131.06 Kb
