 Posted: 17:53 - 19 May 2010 Post subject: What would you call a spanner like this? |
Like a normal open ended wrench but with a lot less metal around the jaw area so it can be used in a tight spot without fouling the parts next to it.
It's for adjusting the tappets on my bullet. I've fitted some chunkier pushrod adjusters to it but they have a larger hex. It is very tight trying to turn them, you can only get about 1/8 of as turn on the spanner before the head of the spanner fouls the casing. Makes things more laborious than it needs to be.
It's a bit that has to be done fairly regularly so having the correct tool would be a good idea.
I know I could grind down a standard spanner but I'm sure I've seen purpose made ones with narrow, pointy jaws that have a ridge of metal along the edge of the jaw to give them strength and prevent them springing open as easily. The thickness of the spanner isn't an issue (within reason). Just don't know what to call them.
I've done a rough picture of what I mean:
https://www.bikechatforums.com/download.php?id=72595 ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 18:21 - 19 May 2010 Post subject: |
fuck knows.
but just get one of these and mill it or attack it with an angle grinder.
https://www.diytools.co.uk/diy/Images/DB_Detail/_27503_140156.jpg ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
 Posted: 18:29 - 19 May 2010 Post subject: |
Stinky can't you sacrifice a ring spanner by cutting out a section out of the end? I've done that many times and never had one spread, you can get in some very tight places especially if you use a cranked ring spanner. ____________________ a.k.a 'Geri'
| MaybeGuy |
 Posted: 19:04 - 19 May 2010 Post subject: |
Says a man who's never tried to fit a fiesta water pump
Only issue I see is the sizes - 5.5mm isn't used much at all and 7mm is for jubilee clips mostly. 13mm is nowhere near as common as 12. ____________________ a.k.a 'Geri'
| MaybeGuy |
| temeluchus |
| Tim.. |
 Tim.. World Chat Champion
 . Renault 5 Driver
| Vincent |
 Vincent Banned
 Posted: 13:00 - 21 May 2010 Post subject: |
| Vincent wrote: |
I remember imperial ((frighteningly commplicated & whoever thought it up, (mr Whitworth I suppose), needs horse whipping)), but I have mainly worked with metric and have always thought of 13mm and 10mm as the most commenly used sizes. |
The thing is, at least some of the imperial systems were worked out from an engineering point of view rather than by what is convenient to do the maths on.
The unified system is one such. They worked out what thread pitches (a coarse and a fine) would be the strongest for a particular diameter of bolt.
Don't malign Mr Whitworth too much. He came up with the first, standardised series of threads. Prior to then people just did what they felt like. On older steam engines etc., each nut goes on it's own specific bolt, they aren't interchangeable and if you need to replace one, you have to make it.
Whitworth invented his thread system in 1841. Metric threads were standardised in 1947. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
 Posted: 16:22 - 21 May 2010 Post subject: |
The Whitworth thread is still the strongest symmetrical threadform. He was a clever bunny, and his spanners make good fishing weights  ____________________ a.k.a 'Geri'
| WetSparks |
 WetSparks Renault 5 Driver
 Posted: 12:01 - 24 May 2010 Post subject: |
The last post was made 16 years, 113 days ago. Instead of replying here, would creating a new thread be more useful? |
