Bike running like it's running out of fuel
Misc
PostPosted: 20:26 - 28 May 2010    Post subject: Bike running like it's running out of fuel Reply with quote
Hopefully BCF can help on this one too,
I made a thread somewhere down the forum about thinking my bike was restricted & was told to check the carbs for washers, so i did. I removed the airbox & the clamps but found no washers so put it all back together.
Went out for a ride & straight away the bike felt blocked & hesitant like it was running out of fuel (fuel was topped up) pulled over & changed the petrol tap settings & it ran better, not 100% but better nonetheless, went like this for about 2 miles & on the way home i had to pull over 4 or 5 times as the bike would rumble, lose power & eventually conk out. I waited a few minutes & it started again & seemed to run 'smoothly' for the next several hundred metres or so until it did it again. I now know this was the float or something filling up which explains why it started after a few minutes.
I moved both the vacuum & petrol hoses about & went for another ride, it started out feeling blocked & hesitant then after a minute or so the bike seemed back to normal, 15 minutes or so later it was back to the 'crappy' feel.
Any ideas? I haven't touched any settings or adjustments. Just removed air box & removed petrol tank/hoses. Also adjusted the tap settings several times.
Bike is a '96 bandit 600.
Cheers,
oldbiker
PostPosted: 20:49 - 28 May 2010    Post subject: Reply with quote
sounds like fuel starvation,
check for crap or water in the tank,
check that the fuel lines are clear,
check the vacuum pipe is clear,
check for crap in the float bowl,
check for crap in the jets and air ways (blow through with compressed air,
after all this check the float valve is clear and the float height is correct.
all these checks should take about an hour or so.
to check the fuel tap is working as it should, connect a litt bottle of fuel directly to the carbs via a small pipe.
It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg
Misc
PostPosted: 21:09 - 28 May 2010    Post subject: Reply with quote
Cheers.
I don't have a clue how to check any of the above. Apart from the vacuum & fuel line. Laughing
Will give anything a go so if you can put each in a little more detail i'll give it a go tomorrow.
I have seen crap floating around in the tank but this was when it was running fine.
Grimnir
PostPosted: 22:00 - 28 May 2010    Post subject: Reply with quote
Did these problems only start *after* you 'fiddled' with the bike? Did you make *absolutely* sure things went back where they should / as tight as they should?
WetSparks
PostPosted: 22:05 - 28 May 2010    Post subject: Reply with quote
Have you tried opening your petrol cap to let some air into the tank when the problem starts. If this makes a difference it would indicate you tank breather pipe is blocked somewhere.
Misc
PostPosted: 22:08 - 28 May 2010    Post subject: Reply with quote
Yup, after i'd fiddled around a bit. The only things i removed where the carbs, 2 hoses from the fuel tap & the air filter. The carbs to the air filter are on tight but it wouldn't hurt to check the cars to the engine again, i'll do this tomorrow.
Anything that i might of popped out but didn't see? Like a hidden hose somewhere?
I did open the cap but only for several seconds or so, no difference really.
swampy
PostPosted: 22:18 - 28 May 2010    Post subject: Reply with quote
This might well be ya problem.... I remember similair symptoms years ago with my NSR. Turns out I thought I had pushed the carb into the rubber mainfold thingy properly, but had misaligned it... Thumbs Up
Misc
PostPosted: 22:19 - 28 May 2010    Post subject: Reply with quote
Will definitely check this then. It's a bugger because it's awkward to see & get your hand down there.
TUG
PostPosted: 22:36 - 28 May 2010    Post subject: Reply with quote
Fuel pump? Check that its pumping when you rev it up, had a cbr600f with same problem and it was the pump not doing its job past 13v.
If not that could possibly be a blocked jet.
Haz ER-5, innit!
Misc
PostPosted: 22:37 - 28 May 2010    Post subject: Reply with quote
How do you check this & the jet? Thumbs Up
Grimnir
PostPosted: 22:38 - 28 May 2010    Post subject: Reply with quote
Maybe that is a different thread?
(gets coat)
Misc
PostPosted: 22:39 - 28 May 2010    Post subject: Reply with quote
(gets coat)
I thought someone may make a comment about that post. Laughing
TUG
PostPosted: 23:10 - 28 May 2010    Post subject: Reply with quote
Take the fuel pump outlet (one to the carbs) off and put in a bucket or container then run, rev the bike up (so its past 13volts) and if it stops pumping theres your problem.
The blocked jet means taking the carb apart unfortunaltly.
Haz ER-5, innit!
Misc
PostPosted: 23:15 - 28 May 2010    Post subject: Reply with quote
Thank you. Would this be a possible problem tho because it was running fine 48 hours ago.
Grimnir
PostPosted: 23:16 - 28 May 2010    Post subject: Reply with quote
This is BCF! - you just know that someone will bring the tone down... Very Happy
Ditto
PostPosted: 00:14 - 29 May 2010    Post subject: Reply with quote
Bandits dont have a fuel pump, it's a gravity fed fuel line jobby.
Anyway now youve posted this across a variety of forums I dont know where to reply to Thinking lol
But you say you looked for restrictors. They would be on the other side of the carb going into the engine. And would not necessarily be discs. Mine uses diaphragms as restrictors which look like this and go into the top of the carbs:
https://images.wemoto.com/full/CARBURETTOR_DIAPHRAGM/10008505.jpg
But if you say its pulling well then it probably isnt restricted.
And these 3:
Require stripping down the carbs. And I believe youve checked everything else. Tis a strange one!
Oh and if you havnt got the service manual yet download it here:
https://www.carlsalter.com/download.asp?fileid=10830117012201170107010510951071108310701054104810481095105710531045105710571046011201000102
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
Misc
PostPosted: 00:41 - 29 May 2010    Post subject: Reply with quote
And these 3:
Posted here & the Bandit forum, always post a couple of threads when really stuck. The more help the better. Thumbs Up
When you say your restrictors went into the top of the carbs, what would be required to see this? Definitely nothing on either side of the carbs but might as well check the above whilst i'm down there.
Tis pulling well but i've heard that even some restricted bikes feel more or less the same until they reach higher speeds.
Thank you for the manual.
Smile
Ditto
PostPosted: 00:50 - 29 May 2010    Post subject: Reply with quote
Well basically, in this pic you put up:
https://img155.imageshack.us/img155/6241/dsc00243w.jpg
Underneath those black caps with the 4 screws is one of those diaphragms. The standard one just had 2 small holes in the bottom for the needle, but the restricted one has 4 more at the top near the rubber bit to allow more airflow, hence restricting the power.
When restricting this way you replace those diaphragms with the restricted ones.
Although saying that I would have thought they would all be standard, as its a bit cheap to sell you a bike with the restricted diaphragms and not the standard ones!
Theres this aswell actually just found. Similar manual but the Haynes one, not Suzuki:
https://filespump.com/go/18181219-suzuki-gsf600-1200-bandit-95-01-pdf.html
Misc
PostPosted: 14:49 - 29 May 2010    Post subject: Reply with quote
Ditto, just took off the top cover of the carbs & here's what's underneath. It looks like the pic you posted but not sure what the standard ones look like so what do you make of it?
https://img46.imageshack.us/img46/759/dsc00266wv.jpg
https://img337.imageshack.us/img337/2974/dsc00267f.jpg
Ditto
PostPosted: 15:00 - 29 May 2010    Post subject: Reply with quote
Youd have to lift it out, being careful not to damage the rubber and look at the metal stalk to it.
Restricted ones have 4 holes near the top by the rubber aswell as the 2 ones at the bottom. So 6 in total compared to 2 for the standard ones.
Misc
PostPosted: 15:23 - 29 May 2010    Post subject: Reply with quote
Took a photo, bad quality i know. All looks fine to me but here's a pic anyway.
https://img442.imageshack.us/img442/7344/dsc00268dx.jpg
Ditto
PostPosted: 15:55 - 29 May 2010    Post subject: Reply with quote
Yer id say your bikes standard!
Whats the latest on the fuel issue?
Misc
PostPosted: 16:04 - 29 May 2010    Post subject: Reply with quote
Just trying to sort out some of the advice with checking the pipes. Currently checking what you said with the fuel tap. Not sure if they're OK so have another pic. Smile
The carbs are all in tight, will need to check the main fuel hose but seems like a bugger to remove & get the clip off, even worse to put back on i'm guessing!
Checked the fuel tap filter & couldn't see anything built up in it.
https://img231.imageshack.us/img231/1637/dsc00269d.jpg
Ditto
PostPosted: 16:08 - 29 May 2010    Post subject: Reply with quote
That looks fine.
Yeh well its an easier job if your doing a carb removal. It could be the case that grit has gotten into the carbs which would block the jets or flood the foat bowls.
If youve already removed the carbs before its not a difficult job to strip them. Just have that workshop manual to hand.
This way you could check the jets, and the fuel pipe and should be able to discover the problem, as all the pipes are on ok by the looks of it.
Misc
PostPosted: 16:11 - 29 May 2010    Post subject: Reply with quote
Ditto wrote:
That looks fine.
So if i've already detached the clamps on both sides of the carbs, is it just a case of unbolting them from the frame? Do i need to block the leftover holes in the engine when they're out? Always see people covering them up.
I've got some carb cleaner too. Thumbs Up
The last post was made 15 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.72 - MySQL Queries: 14 - Page Size: 136.17 Kb
