| Misc |
 Misc World Chat Champion
| oldbiker |
 oldbiker Nitrous Nuisance
 Posted: 21:49 - 28 May 2010 Post subject: |
sounds like fuel starvation,
check for crap or water in the tank,
check that the fuel lines are clear,
check the vacuum pipe is clear,
check for crap in the float bowl,
check for crap in the jets and air ways (blow through with compressed air,
after all this check the float valve is clear and the float height is correct.
all these checks should take about an hour or so.
to check the fuel tap is working as it should, connect a litt bottle of fuel directly to the carbs via a small pipe. ____________________ It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg |
| Misc |
| Grimnir |
 Grimnir Trackday Trickster
| WetSparks |
 WetSparks Renault 5 Driver
| Misc |
| swampy |
 swampy World Chat Champion
| Misc |
| TUG |
 TUG World Chat Champion
| Misc |
| Grimnir |
| Misc |
| TUG |
| Misc |
| Grimnir |
| Ditto |
 Ditto Nearly there...
| Misc |
 Posted: 01:41 - 29 May 2010 Post subject: |
| Ditto wrote: | Bandits dont have a fuel pump, it's a gravity fed fuel line jobby.
Anyway now youve posted this across a variety of forums I dont know where to reply to  lol
But you say you looked for restrictors. They would be on the other side of the carb going into the engine. And would not necessarily be discs. Mine uses diaphragms as restrictors which look like this and go into the top of the carbs:
https://images.wemoto.com/full/CARBURETTOR_DIAPHRAGM/10008505.jpg
But if you say its pulling well then it probably isnt restricted.
And these 3:
| Quote: | check for crap in the float bowl,
after all this check the float valve is clear and the float height is correct. |
Require stripping down the carbs. And I believe youve checked everything else. Tis a strange one!
Oh and if you havnt got the service manual yet download it here:
https://www.carlsalter.com/download.asp?fileid=10830117012201170107010510951071108310701054104810481095105710531045105710571046011201000102 |
Posted here & the Bandit forum, always post a couple of threads when really stuck. The more help the better.
When you say your restrictors went into the top of the carbs, what would be required to see this? Definitely nothing on either side of the carbs but might as well check the above whilst i'm down there.
Tis pulling well but i've heard that even some restricted bikes feel more or less the same until they reach higher speeds.
Thank you for the manual.
| Ditto |
 Posted: 01:50 - 29 May 2010 Post subject: |
Well basically, in this pic you put up:
https://img155.imageshack.us/img155/6241/dsc00243w.jpg
Underneath those black caps with the 4 screws is one of those diaphragms. The standard one just had 2 small holes in the bottom for the needle, but the restricted one has 4 more at the top near the rubber bit to allow more airflow, hence restricting the power.
When restricting this way you replace those diaphragms with the restricted ones.
Although saying that I would have thought they would all be standard, as its a bit cheap to sell you a bike with the restricted diaphragms and not the standard ones!
Theres this aswell actually just found. Similar manual but the Haynes one, not Suzuki:
https://filespump.com/go/18181219-suzuki-gsf600-1200-bandit-95-01-pdf.html ____________________ CG 125 > Bandit 600 > CBR 600 FY > Street Triple R |
| Misc |
| Ditto |
| Misc |
| Ditto |
| Misc |
| Ditto |
| Misc |
The last post was made 15 years, 312 days ago. Instead of replying here, would creating a new thread be more useful? |
