| peugeot xps 50 |
 peugeot xps 50 Derestricted Danger
| steven_191 |
 steven_191 Nearly there...
| Jesta_ZX6R |
 Jesta_ZX6R Borekit Bruiser
| peugeot xps 50 |
| Frost |
 Frost World Chat Champion
| peugeot xps 50 |
| Jesta_ZX6R |
| peugeot xps 50 |
| Jesta_ZX6R |
| steven_191 |
| nightshaddow |
 nightshaddow Nearly there...
 Posted: 19:43 - 24 May 2010 Post subject: |
are they the correct indicators for the bike bike (from the factory) or are they after market,
did you fit them or where they fitted when you got the bike.
most likely is that it will be the relay, though if they are aftermarket they could have been wired incorrectly.
also check the connection between the loom and the indicator, normally bullet connectors if they green or black it could be that, carbon or rust build up may cause a failing in the circuit.
some (very few but some) bikes have to have the "idiot" light working also, check the bulb in the console to make sure ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| peugeot xps 50 |
| That_Hornet |
 That_Hornet World Chat Champion
| peugeot xps 50 |
| Jesta_ZX6R |
| That_Hornet |
| Jesta_ZX6R |
| lonie |
 lonie Banned
 Posted: 08:54 - 30 May 2010 Post subject: |
if they are led indis then even if the relay is working then they wont work as you need a special relay fo led indis sa far as i know correct me if im wrong though
p.s please excuse bad spelling+grammar just finished the graveyard shift at work  |
| peugeot xps 50 |
| lonie |
 lonie Banned
| peugeot xps 50 |
| lonie |
 lonie Banned
 Posted: 10:08 - 30 May 2010 Post subject: |
depends maate like i said it can be earthd in a few places so it may just be the one that earths your indi circit that is loose
the god of earth works in mysterious ways  |
| peugeot xps 50 |
| Jesta_ZX6R |
 Posted: 15:59 - 30 May 2010 Post subject: |
Yes, everything electrical needs checking with a multimeter. You can switch it to 20volts or to 200ohms, either will do the job, although you need to have one probe on a positive wire if your checking volts, if your checking ohms then poke it in the indicator bulb socket (theres two places inside here, one for positive and one for negative, so try both) and the other probe onto the ground point. You may have to run through some of the wiring loom to find the end point.
I would start out with volts as thats the more easy of the two and quicker than tracing through the loom. If you dont get a reading then youve got a loose connector or very broken wire, if you do get a reading, then it should be ok, although it would still be advisable to switch it to ohms and check the resistance as it is posible to get 12volts but have high resistance.
Any volts value between 9-13 should be ok, it wont be higher than that unless the engines running and if its low than that then youve probably got your lights on or a super low battery. For resistance, figures between 0-15ohms would be perfectly fine in my opinion, more than that could cause issues, anything more than 100ohm and you have some serious bad connections or wire which will likely have become corroded or similar. Its not a definative test of current throughput ability but it will be enough to point you in the right direction. Have you googled for how to test vehicle faults with a multimeter or something similar? Might well be a youtube video detailing it. |
| peugeot xps 50 |
The last post was made 16 years, 131 days ago. Instead of replying here, would creating a new thread be more useful? |
