| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 22:49 - 31 May 2010 Post subject: Puncture repair |
Yes i have punctured my inner tube while putting on the new tyre in 3 places!
So i thought why not patch it up?
3 hours later, i get a good seal on one and the one i previously put on blew off typical........it bubbles up and shoots off!
So 2 hours later, re do and i get a perfect seal on it or so i think, test in water for bubbles, its great no air leak!
oh no........bubble...............bubble..............bubble................bubble so jeez a slow leak!
So while i got pissed off i got to work on the next (rear, and is another innertube thats ok) wheel, changed tyre over refit inner tube without nipping and pumped up! holds air so i'm chuffed to bit its not flat! So one wheel done! This time using fairy liquid for ease of fitting.
So why didn't i do that first?
Does anyone has nightmares on this PITA job?
One time its easy, the next is taking the piss.
Any tips on better patching? |
| russeleoin |
 russeleoin Nova Slayer
| cb1rocket |
| cb1rocket |
| Dan79 |
 Dan79 Scooby Slapper
| Vincent |
 Vincent Banned
| cb1rocket |
 Posted: 13:18 - 02 Jun 2010 Post subject: |
I'm roughing up the hole area but not enough i think as its near the seam, which i also think I should rub down flush. I don't chalk, I believe thats only for marking the hole right?
I have managed one hole ok, i keep testing and it doesnt leak so thats ok. Just a really slow leak on the other one (same tube).
I have found that just leaving the rubber glue as a blob all around the edges of the patch tends to make the rubber soft and i can stretch the patch over into a smooth edge after letting the glue dry in about 2 mins.
Bicycle tubes are a piece of piss to repair!
Motorcycle tubes are not  |
| cb1rocket |
| Vincent |
 Vincent Banned
The last post was made 16 years, 148 days ago. Instead of replying here, would creating a new thread be more useful? |
