Puncture repair
cb1rocket
PostPosted: 22:49 - 31 May 2010    Post subject: Puncture repair Reply with quote
Yes i have punctured my inner tube while putting on the new tyre in 3 places! Evil or Very Mad
So i thought why not patch it up?
3 hours later, i get a good seal on one and the one i previously put on blew off typical........it bubbles up and shoots off!
So 2 hours later, re do and i get a perfect seal on it or so i think, test in water for bubbles, its great no air leak!
oh no........bubble...............bubble..............bubble................bubble so jeez a slow leak!
So while i got pissed off i got to work on the next (rear, and is another innertube thats ok) wheel, changed tyre over refit inner tube without nipping and pumped up! holds air so i'm chuffed to bit its not flat! So one wheel done! This time using fairy liquid for ease of fitting.
So why didn't i do that first?
Does anyone has nightmares on this PITA job?
One time its easy, the next is taking the piss.
Any tips on better patching?
russeleoin
PostPosted: 23:17 - 31 May 2010    Post subject: Reply with quote
Hi CB, I have found inflating the tube just enough to make it round inside the tyre before setting the second bead does the trick. It will also help to seat the valve so when you inflate fully the valve does not slide back into the tube. Once you have the second bead in place try squeezing the tyre in sections, again this will help to locate the tube inside.
Russ
I love classic merc's but bikes take up less space.
Current ride is a Yamaha YB 100 and I love it! Oooow and now a running GPZ400R!
Next stop, Direct Access hopefully by the end of summer.
cb1rocket
PostPosted: 13:15 - 01 Jun 2010    Post subject: Reply with quote
Cheers Russ
Have taken that into account, any thoughts on the patch repair?
Has anyone successfully repaired and patched up an inner tube?
cb1rocket
PostPosted: 20:57 - 01 Jun 2010    Post subject: Reply with quote
bumpy bump!
Dan79
PostPosted: 23:45 - 01 Jun 2010    Post subject: Reply with quote
One tip on getting the tyre back on the rim, do not use fairy liquid, it's a great lubricant but will corrode the metal like heck. Nothing is friendlier to rust than washing up liquid. Use talcum powder (dry), does the job without corroding plus your fingers won't slip so much when you push the beads on the wheel rim.
Previous bikes - 1984 Honda VF500 (FII) Interceptor and 1990 Yamaha RXS100
Current bikes - 1984 Honda VF500 (V30) Magna
cb1rocket
PostPosted: 13:18 - 02 Jun 2010    Post subject: Reply with quote
I'm roughing up the hole area but not enough i think as its near the seam, which i also think I should rub down flush. I don't chalk, I believe thats only for marking the hole right?
I have managed one hole ok, i keep testing and it doesnt leak so thats ok. Just a really slow leak on the other one (same tube).
I have found that just leaving the rubber glue as a blob all around the edges of the patch tends to make the rubber soft and i can stretch the patch over into a smooth edge after letting the glue dry in about 2 mins.
Bicycle tubes are a piece of piss to repair!
Motorcycle tubes are not Evil or Very Mad
cb1rocket
PostPosted: 13:24 - 02 Jun 2010    Post subject: Reply with quote
Tubes are cheap but as my luck with changing tubes are pretty poor, it starts to add up quite some bit!
The last post was made 16 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 59.89 Kb
