What's cheaper?
nowhere.elysium
The Pork Lord
PostPosted: 21:42 - 14 Jun 2010    Post subject: Re: What's cheaper? Reply with quote
warped one wrote:
Having a new final drive shaft put in
Or
A new engine?
Warped Crying or Very sad Crying or Very sad Crying or Very sad
We talking about the Hyosung here?
Depending on eBay, I'd bank on the final drive shaft being a cheaper part, but probably much harder to find. I've found the drive shaft for the 250, but not the 650. Sorry.
You might be able to see if the SV650 engine will fit in there?
nowhere.elysium
The Pork Lord
PostPosted: 22:08 - 14 Jun 2010    Post subject: Reply with quote
warped one wrote:
Yes it's the GT650r
The nut wound itself off the shaft, and the front sprocket jumped off the splines onto the threads, thus grinding them off.
Found the shaft for $89 but then theres fitting and such, plus a new washer and nut.
Well, now's your chance to practice your spannering skills.
Provided you're out of the nuthouse now, I may well be able to offer some assistance.
nowhere.elysium
The Pork Lord
PostPosted: 22:18 - 14 Jun 2010    Post subject: Reply with quote
East London.
If you're already stripping the engine down, there's not a huge amount of point in taking it to a garage - you're about 85% there, at that point. Buy a gasket set, get the seals you need, and crunch through it. Seriously - if you're going that far, then there's no need to hand over to a garage.
:edi: I thought you were based near to Enfield. I'm guessing you're much further north, if your profile is correct.
PostPosted: 00:54 - 15 Jun 2010    Post subject: Reply with quote
Warped.
Since you have to either fit a new shaft OR a new engine, why not fit a new sprocket, then the nut (or A nut), then tack-weld the nut onto the shaft with a mig welder? You MIGHT wreck the seal, but it's unlikely, you WILL ruin the shaft, but it's already ruined, you've basically got nothing to lose.
Even if it lasts long enough to wear out the sprocket, grind off the tack-welds and repeat.
PostPosted: 00:57 - 15 Jun 2010    Post subject: Reply with quote
Just thought, the shaft probably isn't hardened, so you could also drill & tap it for a bolt to secure the sprocket.
Digitalize
PostPosted: 01:31 - 15 Jun 2010    Post subject: Reply with quote
On a Hyosung? Neutral
Seriously, might be your bike or whatever, but there is many many better bikes out there.
1998 CB600F Hornet
Welshd1k
PostPosted: 01:52 - 15 Jun 2010    Post subject: Reply with quote
dont start it! he will private message you rageing!
Digitalize
PostPosted: 01:55 - 15 Jun 2010    Post subject: Reply with quote
He can rage all he wants. ITS A HYOSUNG. If it breaks, see if you can bodge it, if not, buy a Japanese bike, where spares are wonderfully available, and cheap.
Or drop an SV650 engine in it, probably get one for no more than 500, a Good Hornet lump is about £300
1998 CB600F Hornet
ollieholt
PostPosted: 02:09 - 15 Jun 2010    Post subject: Reply with quote
i agree with the engine swap. probably better if your keeping the bike for a few more years. good old sv650 v twin charm good ish power and plenty of grunt. pretty much the same output.
if not then like has been said, if you have it all in bits just do the swap yourself?
Laughing < This? Well this is just a day brightner.
nowhere.elysium
The Pork Lord
PostPosted: 12:43 - 15 Jun 2010    Post subject: Reply with quote
warped one wrote:
I'm actually in Grimsby Lincs. But thanks for the offer anyway. If i'm ever back down your way i'll drop you a PM and get you wasted if you like.
Mark.
Sounds like a laugh. If I wake up with stubble burn, though, there will be a reckoning Laughing
PostPosted: 17:05 - 15 Jun 2010    Post subject: Reply with quote
Think the first thing I would try is to get someone with a bit of experience an the right size die to try and recut the thread on the shaft.
If you do need to replace the shaft I presume they are vertically split crankcases so would probably require a complete engine strip.
rac3r
PostPosted: 17:07 - 15 Jun 2010    Post subject: Reply with quote
I'd rather have a Hyosung GT650 than an SV 650 Thumbs Up
Chequered Flag
ThoughtContro...
PostPosted: 17:32 - 15 Jun 2010    Post subject: Reply with quote
I'd rather have a working SV than a non-working Hyo Razz
Looks nicer for sure, tho Hyosung are supposed to beat Suzuki in the water soluble bike stakes.
As can be seen, a tw@ to source parts for, whereas SV parts are so common they give em away in Lucky Bags Very Happy
If an SV engine fits why not just get an SV engine?
Prize cunt
nowhere.elysium
The Pork Lord
PostPosted: 17:35 - 15 Jun 2010    Post subject: Reply with quote
I'd rather have an SV650 than a Monster 620 Wink
Warped - I'd suggest getting hold of a piss-cheap seized engine off of something, strip down the gearbox until you're comfortable with how it all fits together, then fit the part yourself. THis apporach will fit well within the grand you've allocated.
Until Hyosung's parts network improves, that would seem to be the best option you have.
Failing that, see if an SV engine will fit. Not ideal, I know, but it's an option nonetheless.
rac3r
PostPosted: 17:36 - 15 Jun 2010    Post subject: Reply with quote
Razz
Chequered Flag
nowhere.elysium
The Pork Lord
PostPosted: 17:45 - 15 Jun 2010    Post subject: Reply with quote
rac3r wrote:
Razz
You love it, you slaaaag! Laughing
PostPosted: 18:28 - 15 Jun 2010    Post subject: Reply with quote
warped one wrote:
Kickstart - Sorry to tell you matey, but I do play with tap die's and welding plants for a living, the thread is ermm. FUCKED
Fair enough. Could you cut it down and use a smaller nut? I wouldn't think that the nut should have a massive force on it (just so long as it can't come off).
The last post was made 16 years, 92 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 140.88 Kb
