New PC or upgrade Laptop???
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2  Next
Grendel
PostPosted: 09:04 - 08 Jul 2010    Post subject: New PC or upgrade Laptop??? Reply with quote
I have a Toshiba Satellite S1410-303 Laptop which I bought back in 2002.
The problem I have is it can’t seem to keep up with the modern programs and keeps crashing or running slowly so I was wandering if it would be cheaper to buy a more up to date Processor and more Memory rather than buying a new computer?
Current facts and figures:
Celeron ( R ) CPU 1.50GHz
1.50GHz, 348MB of RAM
18.6GB Capacity
10.9GB Used
7.64GB Free
Just bear in mind i'm a computer numpty so have no idea what i would need to do myself.
Past bike: 2004 Hyosung Comet
Current bike: 1993 Honda Transalp
Transalp Page: https://www.facebook.com/home.php?ref=home#!/group.php?gid=11418462079
panrider_uk
PostPosted: 09:22 - 08 Jul 2010    Post subject: Reply with quote
Put more memory in it. Its a cheap upgrade and will revitalise the machine.
Since SP2 came out for XP 512Mb is really the minimum you can get away with to run a PC on. Preferably upgrade to 1Gb or more.
MArk
PostPosted: 10:40 - 08 Jul 2010    Post subject: Reply with quote
Another vote for more memory.
Visit Crucial Memory and run their scanner tool, it'll tell you how much you can put in your machine, and what type.
Grendel
PostPosted: 10:48 - 08 Jul 2010    Post subject: Reply with quote
Must admit more memory would be the cheaper option?
Your Computer Specifications
256 MB DDR PC2100 128 MB DDR PC2100
Maximum Memory Capacity: 524288 MB
Currently Installed Memory: 384 MB
Available Memory Slots: N.A.
Total Memory Slots: 2
Dual Channel Support: N.A.
CPU Manufacturer: GenuineIntel
CPU Family: Mobile Intel(R) Celeron(R) CPU 1.50GHz Model 2, Stepping 4
CPU Speed: 1495 MHz
I presume everything else should be OK once it has more memory?
Also if i upgrade the memory will it loose all the photo's and files i currently have on the laptop?
PostPosted: 10:53 - 08 Jul 2010    Post subject: Reply with quote
You might want to check what hard drive you've got in it too. My lappy used to have a 30gb 4200rpm drive with a slow access speed, it's now got a 120gb 7200rpm drive in it and is much happier.
Grendel
PostPosted: 10:58 - 08 Jul 2010    Post subject: Reply with quote
It says somthing about FAT32?
Is that the hardrive size?
Mr.Everready
PostPosted: 11:00 - 08 Jul 2010    Post subject: Reply with quote
The files are on your hard drive not your "memory.
As Shaggs says a HD upgrade will help too but then if you've no idea what you're doing it may not be an option.
Mr.Everready
PostPosted: 11:02 - 08 Jul 2010    Post subject: Reply with quote
No. Simply, FAT is the way your files are stored.
10.9GB Used
7.64GB Free
That is the size of your hard drive. Add the 2 together.
doggone
PostPosted: 11:07 - 08 Jul 2010    Post subject: Reply with quote
I don't think it's worth it in an 8 year old laptop.
So much other stuff in there is really dated like how it handles video.
Why not splash out on something like https://www.ebuyer.com/product/186604 - sorted for another 8 years.
Grendel
PostPosted: 11:13 - 08 Jul 2010    Post subject: Reply with quote
I'm trying to avoid buying a new computer really since if i did i'd get a Desktop PC but cant afford £500 for a good one at present.
PostPosted: 11:20 - 08 Jul 2010    Post subject: Reply with quote
Checking the specs, the most memory you could go to is 512mb, which would be £28 from Crucial. The hard drive you have is a 4200rpm jobbie, a new 5400rpm 40gb drive would be about £25 (120gb around £40), so for less than £60 you would see an improvement - obviously not as much as buying a new £400 laptop, but that's the nature of compromise Smile
I'm guessing it's probably been quite a few years since the O/S was reinstalled and the machine given some housekeeping too. Best find a local tame nerd to give you a hand, methinks.
Mr.Everready
PostPosted: 11:23 - 08 Jul 2010    Post subject: Reply with quote
Sounds simple Shaggs but if he thinks that his files are stored on his RAM what chance is going to have installing a new OS and then getting the drivers etc.
divuk83
PostPosted: 11:30 - 08 Jul 2010    Post subject: Reply with quote
While a fresh install, more RAM and a new faster hard drive will improve things don't expect miracles. Only spend money on it if you plan on keeping it a while as its quite a lot of money compared to what the laptop itself is actually worth. Personally I would do a fresh install of windows and start saving for a new laptop.
Dave
Grendel
PostPosted: 11:31 - 08 Jul 2010    Post subject: Reply with quote
THANKS FOR ALL THE HELP FOLKS
I was thinking of taking it here:
https://www.novatech.co.uk/novatech/home.html
for them to do the work.
Since lets face it I only vaguely understood my Commodore 64 when I was a kid so I have no hope of doing the work on it myself.
If you do pay someone to do the upgrades for you, make sure you get your old drive back, preferably in a caddy like this :-
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=310227627628
It's only £3.40, and gives you access to all your old files should they have screwed something up.
Shame you're not local, I'd do it for you for the price of materials and a couple of bacon butties Smile
Mr.Everready
PostPosted: 11:33 - 08 Jul 2010    Post subject: Reply with quote
It won't be cheap. The labour costs will probalbly cost more than the parts you're fitting.
PostPosted: 11:35 - 08 Jul 2010    Post subject: Reply with quote
True, once the total goes anywhere near £100 it'll be cheaper buying a secondhand lappy with a better spec.
panrider_uk
PostPosted: 12:38 - 08 Jul 2010    Post subject: Reply with quote
The memory's only £14.10 from Here (part KTT3614/256).
I'd try that as a cheap, first option as it doesn't involve loads of labour or mucking about with your operating system.
Mark
Grendel
PostPosted: 12:46 - 08 Jul 2010    Post subject: Reply with quote
As you gather i'm no Computer wizzard but how come i can only upgrade to 512MB?
PostPosted: 12:49 - 08 Jul 2010    Post subject: Reply with quote
Just a limitation of the machine, you've got two slots that can only take 256mb each.
Grendel
PostPosted: 12:59 - 08 Jul 2010    Post subject: Reply with quote
That makes sence since i says:
Slot 1: 256MB
Slot 2: 128MB
So need to change the Slot 2 for another 256MB.
PostPosted: 13:13 - 08 Jul 2010    Post subject: Reply with quote
You're usually better off buying a matched pair, but £14 for trying one 256mb stick of RAM wouldn't go amiss.
Grendel
PostPosted: 23:06 - 08 Jul 2010    Post subject: Reply with quote
Mark
Well just looked at the manual the Slot 1&2 i can see is for PC cards. But have now found where the RAM is.
Which one of the 256MB ran do i need to buy or are they the same?
And as for the 20GB Hard Drive i'll wait and see before i change it since can put anything important on memory sticks.
panrider_uk
PostPosted: 00:11 - 09 Jul 2010    Post subject: Reply with quote
Mark
Just buy the 256Mb memory module above (Kingston Memory part no. KTT3614/256). Remove the 128Mb module from your laptop and replace it with the new one. The machine (and Windows) will automatically detect the change.
Mark
Grendel
PostPosted: 06:12 - 09 Jul 2010    Post subject: Reply with quote
Sorry was having a blonde moment didnt think about looking for the part number Rolling Eyes
Just ordered it now so hopefully the Laptop will be working better after.
The last post was made 16 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 138.59 Kb
