| jessie61271 |
 jessie61271 L Plate Warrior
| unspec |
 unspec Nova Slayer
| Grimnir |
 Grimnir Trackday Trickster
 Posted: 13:11 - 19 Jun 2010 Post subject: |
Like the new panels!
Whenever you take the oil filter off, it will drip on the collector and stink like a bastid when you start it up. Might not be such a problem for you as it looks like you have plenty more to do first. Keep the updates coming... |
| unspec |
 unspec Nova Slayer
| teabag |
 teabag Renault 5 Driver
| unspec |
 unspec Nova Slayer
| qarka |
 qarka Spanner Monkey
 Posted: 21:21 - 26 Jun 2010 Post subject: |
 ____________________ Previous - Sinnis Apache - Honda Bros 400 - Yamaha SR500 - Honda Transalp - Kawasaki ZX-7R - Honda CB-1 - Honda 929 Fireblade - Honda NTV650 [b]Current[\b] Honda CB500 |
| Grimnir |
 Posted: 22:05 - 26 Jun 2010 Post subject: |
Looking good - keep the updates & pics coming  |
| deleted111 |
 deleted111 World Chat Champion
 Posted: 16:40 - 27 Jun 2010 Post subject: |
Been following this for quite a while now,
really liking the look of it with the green bodywork
I doubt I'd ever have the patience for something like this, good work mate! |
| unspec |
 unspec Nova Slayer
 Posted: 18:55 - 15 Jul 2010 Post subject: |
Been quiet for a while.
Bike went in for the MOT...and failed.
Some silly stuff I should have sorted with the lights and bars touching the tank at full lock but there was one significant item, the brakes.
Those damn tokico calipers just cant seem to get and feel. So I hunted on ebay and bagged myself a m/c and front caliper set for a CBR900RR for just £33
Here is a caliper.
https://homepage.mac.com/jrsanderson/images/zzr600/nissins.jpg
The Honda uses M8 bolts but the holes in the fork mounting points are for M10s. So, I fabricated some sleeves by getting some 10mm steel tube from B&Q with 1mm walls and cut them down to size.
https://homepage.mac.com/jrsanderson/images/zzr600/sleeves.jpg
I then used some M8 bolts and used a washer to position the caliper correctly relating to the disc and another washers to spread the load of the head of the bolt.
https://homepage.mac.com/jrsanderson/images/zzr600/newcaliperbolts.jpg
I also had to do a bit of filing on the caliper to stop the discs from fouling on them and a little was needed of the mounting points on the forks. However, with that done it was a good fit.
https://homepage.mac.com/jrsanderson/images/zzr600/nissinsfitted.jpg
I didn't stop there and decided that I'd use that master cylinder as well just to complete the system. It wasn't too tricky to mount.
https://homepage.mac.com/jrsanderson/images/zzr600/newmcfitted.jpg
I put it back into the garage on a retest and it passed
However, disaster was to strike not even 5 minutes after leaving the garage!
While riding the bike my clutch failed!
After getting it home via the RAC, I found that the (bodged) cable was fine but the arm it pulls had slipped down, indeed I could almost pull the thing out of the clutch cover.
Draining the engine and taking off the clutch cover and the clutch actuator arm was mine. I think it is safe to say it is fucked.
https://homepage.mac.com/jrsanderson/images/zzr600/clutchactuatordamage1.jpg
https://homepage.mac.com/jrsanderson/images/zzr600/clutchactuatordamage2.jpg
So, I've got a replacement arm on order along with a new gasket (there was horrible instant gasket used before), new sump plug and crush washer (it was leaking a little) and clutch cable (the other one was bodged to tighten it up even further resulting in a very stiff clutch.
So the wait begins. Hopefully that is all that is required and I don't have to rebuild the clutch. I'd like to avoid that if possible. |
| unspec |
 unspec Nova Slayer
| unspec |
 unspec Nova Slayer
 Posted: 11:49 - 17 Jul 2010 Post subject: |
All the parts arrived today, so I'll be working on the bike this weekend  |
| unspec |
 unspec Nova Slayer
| woll |
 woll World Chat Champion
 Posted: 20:23 - 18 Jul 2010 Post subject: |
If it was me i'd get the sump welded/replace the sump it it was cracked.
Bikes looking good mate  ____________________ Current Bike- Suzuki DRZ400 SM K6
Damaged spleen, damaged kindey, 2 popped lungs, 2 broken ribs, broken face, broken wrist and 5 back fractures... remember kids walls hurt |
| unspec |
 unspec Nova Slayer
| Gazdaman |
 Gazdaman I did a trackday!!!
| unspec |
 unspec Nova Slayer
 Posted: 23:08 - 22 Jul 2010 Post subject: |
No real news, just to say my EBC clutch rebuild kit arrived today.
I'll fit it at the weekend.  |
| unspec |
 unspec Nova Slayer
| unspec |
 unspec Nova Slayer
| mad4it028 |
 mad4it028 World Chat Champion
 Posted: 23:16 - 23 Jul 2010 Post subject: |
if you just snapped the head off remove all other bolts then the cover or whatever you were bolting up and wind the rest of the bolt out with grips  ____________________ always looking to buy bikes crashed ,unfinished projects,none runners pm me
currently riding kawasaki z1000 only bike ive ever loved |
| unspec |
 unspec Nova Slayer
| unspec |
 unspec Nova Slayer
 Posted: 11:53 - 24 Jul 2010 Post subject: |
| Gazdaman |
 Posted: 14:55 - 24 Jul 2010 Post subject: |
Nice one! First time I've ever heard an actual success story for one of those!
Gaz |
| unspec |
 unspec Nova Slayer
| unspec |
 unspec Nova Slayer
The last post was made 16 years, 37 days ago. Instead of replying here, would creating a new thread be more useful? |
