| Nemo |
 Nemo Could Be A Chat Bot
 Posted: 23:56 - 17 Jul 2010 Post subject: Should there be oil in there?.... |
I have an '03 Suzuki GX 125, wish is pretty identical to the GS 125.
Basically the starter motor has packed up, well, it makes the noise but doesn't turn anything (best I can describe it).
My mate thought it might just be carbon brushes or something silly and has a spare one I can have any way.
Went to take it out, but it's not as simple as pull it out, so start to unbolt the casing where the generator magnito thing sits, and oil starts dripping out.
Just wondering why or how there would be oil in there. If the seal has gone, would I have to take out the whole engine and strip it just to change that seal? ____________________ Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo |
| stonesie |
 stonesie World Chat Champion
 Posted: 00:06 - 18 Jul 2010 Post subject: |
You should be able to unbolt the magneto plate and remove it and see the oil seal beneath, a careful hand should be able to drill a small hole in it without damaging the area that the seal runs on.
Next you screw a small self tapping screw into the oil seal and yank the bugger out with pliers, 2 opposite screws may be required.... Install a new one with a suitably sized deep socket (to drive it on the outer rim) then build it all back up and jobs a good-un  |
| stuartadair |
 stuartadair Crazy Courier
| Nemo |
 Posted: 23:29 - 19 Jul 2010 Post subject: |
So it's nothing to worry about?
I need to somehow get the starter motor out and it's not as simple as "tug" it out (I was hoping it would be).
So I don't know whether taking this casing off would help.
Would this mean that I will have to drain the oil out to do it?
Thanks for the advice, put my mind at rest, sounds depressing but never had a 4-stroke before  ____________________ Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
| N cee thirty |
 N cee thirty Banned
| Nemo |
 Posted: 00:00 - 20 Jul 2010 Post subject: |
| rob yarrr wrote: | i toke the magneto off my cg and there was a small amount of oil that came out,to lube the flywheel gear
put it all back together and it was fine,you've probs done the same |
I didn't take the magneto off though, just started to undo the case and oil started dripping out, not gushing, but dripping.
Might take the case fully off and see what happens, need to work out how to get the starter motor out first though. ____________________ Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
| N cee thirty |
 N cee thirty Banned
| oriel dave |
 oriel dave Nova Slayer
 Posted: 00:31 - 20 Jul 2010 Post subject: |
As said I don't think you need to worry about a bit of oil dripping out, but are you sure you need to be taking the engine casing off? Isn't the starter motor just bolted onto the front?
Also are you sure the starter motor is your problem? Does it bump start? ____________________ Europe Trip 2009 |
| SnowTigeress |
 SnowTigeress Brolly Dolly
 Posted: 01:12 - 20 Jul 2010 Post subject: |
have you got the bible for your bike?
15 quid answers lots of silly questions..
as im finding out building my first project my cb125 has a dry magnito,where some have wet ones ____________________ Real bikers build their own Renovated and Riding a 1986 Honda CB125TD-C called the Pup. Full Licence 13/09/2012, 1994 Moto Guzzi 750 Strada
Can-Do Girl that does spanners TOO!
TheSmiler: binning it is better than going around a roundabout the wrong way |
| P.addy |
 P.addy Red Rocket
| stuartadair |
| Nemo |
| fiery tupp |
 fiery tupp Trackday Trickster
| P.addy |
 P.addy Red Rocket
| fiery tupp |
The last post was made 16 years, 23 days ago. Instead of replying here, would creating a new thread be more useful? |
