Got my CG... Got a problem too...
stonesie
PostPosted: 09:18 - 19 Jul 2010    Post subject: Got my CG... Got a problem too... Reply with quote
The bike got delivered this morning Very Happy
But 2 minuets after the seller called me to say it was on its way he sent a text "forgot to tell you the centre stand spring has snapped its bracket off the frame, I've given the bits to the van driver"
Fookin great stuff, and the stand is properly bent Evil or Very Mad
https://img267.imageshack.us/img267/5021/dscf0066z.jpg
I cant see where on the frame this needs re-attatching to and I know i cant ride the thing until this is repaired.
Where can i get a new or good used centre stand from?
DrDonnyBrago
PostPosted: 09:23 - 19 Jul 2010    Post subject: Reply with quote
If that is the bracket then it'll need to be welded back on, shouldn't cost too much. It looks though like it is just the end that has broken. My cbr has something similar, a bolt sticks out of the engine/frame and the hole in the end hooks over it. If the mount broke off then snapped metal should be easy to spot, if not look for a bolt/post showing some wear on it.
Stands are on eBay - or get the welder to sort that at the same time.
stonesie
PostPosted: 09:29 - 19 Jul 2010    Post subject: Reply with quote
I really must buy a welder and learn to use it Embarassed
Just had a better look and I still cant see it under all the muck, it has one of those silly little cone filters on it too, so that's a standard air box and filter on the shopping list too then.
radical
PostPosted: 11:22 - 19 Jul 2010    Post subject: Reply with quote
The centrestands always bend or break on 100/125 cc Honda singles, get the stand straightened and strengthened with some light angle iron. Sidestands are available for the CG125 which can help but if fitting one never leave the bike running on the sidestand as it can sometimes cause oil starvation to the cylinder head.
Teflon-Mike
tl;dr
PostPosted: 12:08 - 19 Jul 2010    Post subject: Reply with quote
Ditto that advice. Stands on the twins can give grief too!
For now: have a poke about underneath, the stand will be attached to the frame on a big hinge-pin under the back of the engine / foot-peg area, and normally secured with a rusty split-pin and washer.
Use an old stick, or something 'pokie' to get crud out the way, then a brush and deturgent (Laundry Washing Powders good) to clean it up a bit so you can see what you got.
Pliers if you can see the split pin to pull it out.... lol....
Then an old nail to try and poke out whats left after you've snapped the ends with the pliers.....
Give up when you have very little split-pin poking out, beat hinge-pin to death with hammer until it comes out the stand and frame.
Stand removed, bike is rideable........
You will just have to find walls or lamp-posts and 'stuff' to prop it against when you want to park.
Not ideal.... but you can at least go ride!
If only around to some local car repair places, see if any-one will weld it up for you, add some bracing to it if possible, and put the spring pin back on.
Give it a good go over with the rotary wire before you show it them though, or they'll not be too inclined to help you out.
Paint when sorted, re-fit, with lots of copa-slip and a new split pin.
DrDonnyBrago
PostPosted: 12:26 - 19 Jul 2010    Post subject: Reply with quote
OP, you have your postcode and address on the pic you posted - nice dog on google maps btw Thumbs Up .
cb1rocket
PostPosted: 12:27 - 19 Jul 2010    Post subject: Reply with quote
I would get a new bracket, where the end has broken off. As for the pin if the bracket broke first then the pin on the frame should still be there. Give it a good clean and then new bracket and then re-attach
stonesie
PostPosted: 13:24 - 19 Jul 2010    Post subject: Reply with quote
Thanks, just ignore my dad in his shorts Shocked
I have found the peg that the bracket moves on and its a bit worn but fine for now, so as cb1rocket said i just need a new bracket.... Anybody got one of these knocking about?
Also the stand and pivot have sort of become one piece, I need replacements because I tend to put things beyond use when the persuader comes out to play (8 Lb lump hammer)
I've already fitted a new battery, tensioned the chain and had a look at the swing arm bushes and bearings, all good to go but the chain is getting ready and so is the rear sprocket. Also fitted hell plates Twisted Evil
DrDonnyBrago
PostPosted: 14:26 - 19 Jul 2010    Post subject: Reply with quote
Stick some pics up when you are done, most of BCF ride either a CG125 or a RXS100. The CG fan boys will love you for it Mr. Green .
pepperami
PostPosted: 15:42 - 19 Jul 2010    Post subject: Reply with quote
Pictures NOW! or i call the CG police! Smile
stonesie
PostPosted: 16:13 - 19 Jul 2010    Post subject: Reply with quote
Pictures moved to the Bike Pics section.
Billing
PostPosted: 19:44 - 19 Jul 2010    Post subject: Reply with quote
bought a pack of 5 of those C shaped spring brackets, will go and have a look for them, then will get one sent off to you.
best place for a centre stand is either ebay for a second hand one or david silver spares for new (about £40 IIRC!)
stonesie
PostPosted: 19:53 - 19 Jul 2010    Post subject: Reply with quote
You sir are a star Very Happy
New parts ordered from David silver and a pint owed I think Thumbs Up
Billing
PostPosted: 20:38 - 19 Jul 2010    Post subject: Reply with quote
no worries mate Smile my dads house has been ripped apart by builders, so having a little trouble finding bits, I'll send you a pm as soon as i find it though Thumbs Up
stonesie
PostPosted: 08:16 - 22 Jul 2010    Post subject: Reply with quote
It's okay I have one now, nice box of shiny things from Honda Cool
Just letting some penetrating oil soak in before I go and beat the crap out of the pivot pin, it will surrender weather it likes it or not.
I'm in a bad mood at the moment because I'm on holiday, this did not stop my supervisor ringing me at 5AM asking me to be in work by 6 Thumbs Down .... He got told to bog off (or something to that effect Twisted Evil )
Edit
Pivot pin end belled over so I have resorted to the angle grinder Twisted Evil sadly the head of it needs drilling so having a break while the battery charges...
Edit 2
What a ballache that was, burned out all my mini grinder bits for the dremel and the new stand spring was just slightly tight, there must be a easy way but my way worked eventually Smile
The last post was made 15 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 89.6 Kb
