| stonesie |
 stonesie World Chat Champion
 Posted: 09:18 - 19 Jul 2010 Post subject: Got my CG... Got a problem too... |
The bike got delivered this morning
But 2 minuets after the seller called me to say it was on its way he sent a text "forgot to tell you the centre stand spring has snapped its bracket off the frame, I've given the bits to the van driver"
Fookin great stuff, and the stand is properly bent
https://img267.imageshack.us/img267/5021/dscf0066z.jpg
I cant see where on the frame this needs re-attatching to and I know i cant ride the thing until this is repaired.
Where can i get a new or good used centre stand from?
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| stonesie |
 Posted: 09:29 - 19 Jul 2010 Post subject: |
I really must buy a welder and learn to use it
Just had a better look and I still cant see it under all the muck, it has one of those silly little cone filters on it too, so that's a standard air box and filter on the shopping list too then. |
| radical |
 radical Spanner Monkey
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 12:08 - 19 Jul 2010 Post subject: |
| radical wrote: | The centrestands always bend or break on 100/125 cc Honda singles, get the stand straightened and strengthened with some light angle iron. Sidestands are available for the CG125 which can help but if fitting one never leave the bike running on the sidestand as it can sometimes cause oil starvation to the cylinder head. |
Ditto that advice. Stands on the twins can give grief too!
For now: have a poke about underneath, the stand will be attached to the frame on a big hinge-pin under the back of the engine / foot-peg area, and normally secured with a rusty split-pin and washer.
Use an old stick, or something 'pokie' to get crud out the way, then a brush and deturgent (Laundry Washing Powders good) to clean it up a bit so you can see what you got.
Pliers if you can see the split pin to pull it out.... lol....
Then an old nail to try and poke out whats left after you've snapped the ends with the pliers.....
Give up when you have very little split-pin poking out, beat hinge-pin to death with hammer until it comes out the stand and frame.
Stand removed, bike is rideable........
You will just have to find walls or lamp-posts and 'stuff' to prop it against when you want to park.
Not ideal.... but you can at least go ride!
If only around to some local car repair places, see if any-one will weld it up for you, add some bracing to it if possible, and put the spring pin back on.
Give it a good go over with the rotary wire before you show it them though, or they'll not be too inclined to help you out.
Paint when sorted, re-fit, with lots of copa-slip and a new split pin. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| DrDonnyBrago |
 Posted: 12:26 - 19 Jul 2010 Post subject: |
OP, you have your postcode and address on the pic you posted - nice dog on google maps btw . |
| cb1rocket |
 cb1rocket World Chat Champion
| stonesie |
| DrDonnyBrago |
| pepperami |
 pepperami Super Spammer
 Posted: 15:42 - 19 Jul 2010 Post subject: |
Pictures NOW! or i call the CG police!  ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| stonesie |
| Billing |
 Billing World Chat Champion
| stonesie |
 Posted: 19:53 - 19 Jul 2010 Post subject: |
You sir are a star
New parts ordered from David silver and a pint owed I think  |
| Billing |
 Posted: 20:38 - 19 Jul 2010 Post subject: |
no worries mate my dads house has been ripped apart by builders, so having a little trouble finding bits, I'll send you a pm as soon as i find it though  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
BCF Eastern members map here ---> g.co/maps/2tm8b PM me to be added to it! |
| stonesie |
 Posted: 08:16 - 22 Jul 2010 Post subject: |
It's okay I have one now, nice box of shiny things from Honda
Just letting some penetrating oil soak in before I go and beat the crap out of the pivot pin, it will surrender weather it likes it or not.
I'm in a bad mood at the moment because I'm on holiday, this did not stop my supervisor ringing me at 5AM asking me to be in work by 6 .... He got told to bog off (or something to that effect )
Edit
Pivot pin end belled over so I have resorted to the angle grinder sadly the head of it needs drilling so having a break while the battery charges...
Edit 2
What a ballache that was, burned out all my mini grinder bits for the dremel and the new stand spring was just slightly tight, there must be a easy way but my way worked eventually  |
The last post was made 15 years, 164 days ago. Instead of replying here, would creating a new thread be more useful? |
