Bandit missing on 2 cylinders
bandit600
PostPosted: 14:00 - 19 Aug 2010    Post subject: Bandit missing on 2 cylinders Reply with quote
I have recently purchased a R Reg Bandit 600 which has been stood for around 2 years in someones garage.
After a new battery, plugs and oil filter it fires up fine, but it is missing on 2 cylinders. It's fine with the choke on but once switched off it runs like a dog and cuts out, and will not idle for long.
I have heard about fuel going off, so i have put some new fuel in but seems to be still doing the same, although it is mixed with the old, which probably was'nt a good idea.
I am hopefully going to clean the carbs out this weekend, and wondered if anyone has any advice on this, as it will be a first for me. What is the best carb cleaner to use and best way to do it. I don;t really want to remove the carbs if i can help it, but would this be the only way to do it.
Thanks in advance.
Barry_M2
PostPosted: 14:08 - 19 Aug 2010    Post subject: Reply with quote
If it fires ok with the choke on I'd suspect one of the following.
Air leak on the inlet somewhere, or blocked pilot jets. You will need to take the carbs off.
Personally, I'd go with blocked pilot jets.
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
bandit600
PostPosted: 17:55 - 19 Aug 2010    Post subject: Reply with quote
Thanks for the advice Barry.
chillyman0
PostPosted: 18:39 - 19 Aug 2010    Post subject: Reply with quote
Could be that the float needles are sticking, try cleaning the ends of them with some emery cloth when you get the carbs apart.
1996 gsf600n (sold)
bandit600
PostPosted: 13:28 - 23 Aug 2010    Post subject: Reply with quote
Thanks for the tips guys.
I pulled the carbs off on Saturday and found the main jet on number 1 was completley blocked, the other 3 about 70% blocked, and 1 pilot jet blocked, i am amazed i even got the thing started before.
Cleaned them all up, and gave it some fresh fuel with redex and it fires first time and runs great, although i think the carbs need balancing now, so a trip to the garage as i have no gauges.
Ditto
PostPosted: 14:12 - 23 Aug 2010    Post subject: Reply with quote
Yup, when a bikes been stood a while, any running problems are almost certainly carbs. Sometimes coils but usually carbs.
Don't get them balanced until you've done a full service, oil, plugs, valve clearances etc. Balancing should be the last step.
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
bandit600
PostPosted: 14:17 - 23 Aug 2010    Post subject: Reply with quote
Thanks Ditto
The last post was made 16 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 50.37 Kb
