Project Bsa B40. (picture heavy) - Updated with images.
steveh
PostPosted: 22:12 - 01 Sep 2010    Post subject: Project Bsa B40. (picture heavy) - Updated with images. Reply with quote
Well, went to see a lady about this bike she had in her back yard for a number of years, she didnt know alot, she said "its a bsa, and its rusty"
Sadly it wasnt a goldstar, i half expected it to be a bantam, but instead it was a 1963 bsa b40 (350)
Alot of it isnt original, the tanks from a b25 Starfire, its got different headlight, tail light and mudguards on it, so im not sure what to do with it yet, any ideas?
Also, wheels are shot, i either need replacement rim/spokes, or get one from another model ect.
cleaned out the carb and managed to get it to fire and kick flames everywere, so its a start!
Any ideas, or were to source parts from would be great!
https://i48.photobucket.com/albums/f215/stesewell/random%20stuff/bsa350.jpg
PostPosted: 23:23 - 01 Sep 2010    Post subject: Reply with quote
Nice little find Thumbs Up
You could have a wander through https://www.classicbikeforum.co.uk/index.php It's small, but might help you source some original parts, if you go that route.
Pat
Suntan Sid
PostPosted: 05:55 - 02 Sep 2010    Post subject: Reply with quote
Looks the nuts AFAIC. Thumbs Up
No matter what anyone tells you replace the big and little end bearings, the original phosphor bronze items are actually made out of “Thornton’s” toffee.
If you want decent suspension, replace front and back with modern equivalents, oem suspension is crap!
“Starfire” tank looks good”, IMO.
I seem to remember my brother had some problems with the magneto and charging system!
Get some knobblies on it for the scrambler look!
Would love to find one of those to restore / bastardise.
How much did you get it for?
Fook, I’m one year older than that bike. Sad
Tim..
PostPosted: 08:03 - 02 Sep 2010    Post subject: Reply with quote
Cool project, will be watching this one Thumbs Up
www.marshallracing.co.uk
CHR15
Turbo nutter bastard
PostPosted: 11:10 - 02 Sep 2010    Post subject: Reply with quote
i once got offered a running goldstar for 500 quid.
i didn't have the money though Sad
the frame looks very similar to a bantam.
(see attachment for my pimped d14/4)
pepperami
PostPosted: 15:13 - 02 Sep 2010    Post subject: Reply with quote
What a great little find Thumbs Up
Parts wont be a problem once you start going to a few bike auto-jumbles.
You will probally find that it is easier to get old Brit bits than it is to get old Jap bits.
This is what i have found whilst trying to get my 1980 Yamaha XS400 back on the road.
Lone-Wolf
PostPosted: 16:56 - 02 Sep 2010    Post subject: Reply with quote
Wotcha.
He would have . . . it ain't got a magneto.
Alternator and coil igniton.
Cheers.
L.W. - www.moonshiners.org.uk
Lone-Wolf
PostPosted: 16:58 - 02 Sep 2010    Post subject: Re: Project Bsa B40. Reply with quote
Wotcha.
If nowt else, keep that front brake in it.
Cheers.
Suntan Sid
PostPosted: 17:57 - 02 Sep 2010    Post subject: Re: Project Bsa B40. Reply with quote
Wotcha.
Sorry, what's that thing with the fins under the headstock, that's what I meant!
CHR15
PostPosted: 18:14 - 02 Sep 2010    Post subject: Reply with quote
rectifier
Lone-Wolf
PostPosted: 18:20 - 02 Sep 2010    Post subject: Reply with quote
rectifier
Wotcha.
Almost.
It's the heat sink for the Zener diode ( the magical device which allows all voltage above 12 to escape down to earth ) A Lucas alternator will output around 30 volts, so you can see why it needs a heat sink.
Cheers.
CHR15
PostPosted: 18:33 - 02 Sep 2010    Post subject: Reply with quote
so does it generate in dc then?
Lone-Wolf
PostPosted: 19:58 - 02 Sep 2010    Post subject: Reply with quote
Wotcha.
No - you would need a dynamo for DC generation.
The alternator produces AC, which in turn goes to a bridge rectifier and gets converted to DC, the excess is then shunted to earth via the Zener diode.
I don't bother with the rectifer and Zener these days, I just fit one of those wonderful magic black boxes - only cost around twenty five quid or so. Got 'em on all my Brit bikes now, and never had any problem with 'em.
Cheers.
steveh
PostPosted: 21:25 - 02 Sep 2010    Post subject: Reply with quote
Time for abit of an update!
Managed to get it running today, started first kick after mucking out the clutch, carb and setting the timing, theres abit of a "knock" when you lean it over, and theres some play in the layshaft, so that will have to be sorted!
Some pretty Orrible wiring!
https://i48.photobucket.com/albums/f215/stesewell/1963%20bsa%20b40%20project/1.jpg
none original rear light/mud guard
https://i48.photobucket.com/albums/f215/stesewell/1963%20bsa%20b40%20project/2.jpg
what looks to be a pipe hanger welded together to hold the none standard tank in place!
https://i48.photobucket.com/albums/f215/stesewell/1963%20bsa%20b40%20project/3.jpg
motor out, looking less like a bike now!
https://i48.photobucket.com/albums/f215/stesewell/1963%20bsa%20b40%20project/4.jpg
after stripping the motor, theres abit of damage to the bore, im guessing its were its been stood and corroded away.
https://i48.photobucket.com/albums/f215/stesewell/1963%20bsa%20b40%20project/5.jpg
seems the pistons 40thou over size too.
https://i48.photobucket.com/albums/f215/stesewell/1963%20bsa%20b40%20project/6.jpg
started to clean it up, further strip down tomorow!
https://i48.photobucket.com/albums/f215/stesewell/1963%20bsa%20b40%20project/7.jpg
oh, and even got the mrs polishing my head!
https://i48.photobucket.com/albums/f215/stesewell/1963%20bsa%20b40%20project/8.jpg
steve.
CHR15
PostPosted: 21:54 - 02 Sep 2010    Post subject: Reply with quote
renthal ultra lows Thumbs Up
also, they used leaded paint on the frames so try not to breath too much of it if your wire wheeling it. don't want to get aids or anything.
Tim..
PostPosted: 07:31 - 03 Sep 2010    Post subject: Reply with quote
Nice progress. Top marks for the bird getting her hands grubby, she's a keeper Thumbs Up .
pepperami
PostPosted: 09:36 - 03 Sep 2010    Post subject: Reply with quote
More please Thumbs Up
f1fan111
PostPosted: 17:55 - 03 Sep 2010    Post subject: Reply with quote
nice BSA B40 there, trying to find one myself as a project. For spares there is https://draganfly.co.uk or eBay and autojumbles if you know what your looking for.
For ideas could do trials bike as pre65 trials or enduro look
https://www.uk-collectables.co.uk/images/shop/products/51b5368136702357be7ebbd12741c8c5.jpg
or maybe a B40WD
https://www.bsawdb40.com/phy/clim/126225/BSA-WD-B40.jpg
Hope to see more pictures Thumbs Up
Teflon-Mike
tl;dr
PostPosted: 19:48 - 03 Sep 2010    Post subject: Reply with quote
I was at a jumble once and poking areound a rusty army surplus B40, bloke on the stall was surprised any-one could be 'exited' by one. But my introduction to them was in dirt biking.
https://motorbike-search-engine.co.uk/classic-bikes-2/cheney-bsa-b50.jpg
For classic scrambles, A Cheaney Victor is a VERY potent tool.
For Classic Trials, A C15 Ottor, is the way to go.
https://441mettise.co.uk/images/mettise4.gif
(Some run the B40 motors for the added grunt)
I had a C15 I got to do a trials chop on; frustrating project; I ended up putting it in a skip in 1988!
Seem to recall they had 6v electrics and infuriatinglt unreliable distributor ignition, not that I even got as far as that being a problem with mine!
But, as a resto project, ecconomically, B40's now are not worth very exiting money in standard trim.
Most were War Dept spec, and they had the heaviest frames.
Stock street versions wasn't much lighter, though!
Think there were a couple of factory variants that ARE interesting & worth money, but cant remember which ones, apart from the Victors.
Doing a C15/B40 now, for me, I think I'd pander to where the money is.
And yours, probably an ex-mil, civilianised, & far from original, I'd not be too preciouse about making a special out of it, & a Cheaney Victor rep, would be VERY tempting.
Last time I checked, which was about 5 years ago, Cheaney was still going and offering frames for sale, for a Victor Scrambler.
While Sammy Miller Motorcycles offer all the parts to build a complete C15/B40 Ottor from spares; frame, motors, forks, body-work & mudguards etc.
Between them & Rickman (B40 Matisse is the other classic scrambles contender), pretty sure you can pretty much get ALL the bits to build to almost any spec for mud-busting.
AND rediculousely, well fettled examples will fetch sensible money.
Seen a couple of almost concourse restored C15/B40's over the last few years, price tags around £1500, which seems about tier price cap.
But seen 'Victor' replicas, pushing twice that, with Cheaneys or Mittises commanding what I think is 'silly money' for a dirt bike.
BUT then, was at a classic scramble few years ago, and there was a lad HOONING a B441 Jef-Smith replica around, and it was just AWESOME! He was taking big air on the thing, like he was on a moden 'crosser' and ran it not just in the pre 72 / Brit-Bike, but also the 'Twin-Shock' class for outmoded old Jap stuff.... where there was another loon on a Dave Thorpe, Kawasaki KX4?0 (It was definitely the T-shock one!) Going just as hard...
Was one of those memorable 'duels'; two 'Real-Mans Bike' machines, ridden by blokes that COULD ride'em, and giving them thier head! dont normally get exited as a spectator, but that was one of those moments you just KNEW that there was something electric going on on the track, and a spectacle to behold!
anyway, you asked for ideas, and they're mine.
From an entirely mercenary point of view, given teh work needed, I'd dirt it; but then I also happen to like the dirt variants.
BUT, its your project.
B40 was around long enough and offered in enough guises, and you have a bike thats such a blank canvas, you could take it in whatever direction appeals to you.
Oh.... I have another reason that mud-larking it would be favourite with me..... 'the other half'....... she's too diddy to get her leg over (& Hence NICK) a long legged dirt-bike!
How tall is your missus?
I mean, she's polishing bits of the bike now, for you.....
When its done.... how long till she says something along the lines "Well I DID help you build it!" and expect her name on the insurance! Wink
steveh
PostPosted: 19:57 - 03 Sep 2010    Post subject: Reply with quote
Seems to be a little bit of interest, so ill keep posting!
Got the motor fully stripped down now, with abit of a list of what i need, as i thought the bronze crank bush is completley shot, it looks like its picked up on the crank and spun round, its marked the castings, so im not sure what im going to do with it yet, ive heard rumours that you can get roller bearings to fit, ill have to dig around!
heres some pictures!
the Bronze bush, that supposed to stay in the crankcase!
https://i48.photobucket.com/albums/f215/stesewell/4a.jpg
The nurled up bush, its even got pop marks were someones tried to make it stay in the casings... sigh.
https://i48.photobucket.com/albums/f215/stesewell/a3.jpg
luckily theres no play in the crank, but its abit rotten.
https://i48.photobucket.com/albums/f215/stesewell/a2.jpg
and a random shot.
https://i48.photobucket.com/albums/f215/stesewell/a1.jpg
so whoever built this last clearly had no idea! now its time to start hunting for motor spares, going to rebore the barrel at work, so im going to be after a 80.5mm piston for it, not sure whats going to be the best place to be honest, if anyone knows of a company that might be able to help it would be much apprechiated.
oh, and i know im getting ahead of myself, but i really like this!
https://caybroendumsparetime.blogspot.com/2009/11/my-bsa-tracker.html
steve.
Teflon-Mike
tl;dr
PostPosted: 21:44 - 03 Sep 2010    Post subject: Reply with quote
IS..... that thing lurking in top right hand corner of pic, with 'ray-gun' silencers, what I THINK it might be?....
Prey tell, cos theres no mention of a tripple in your sig-line.....
350 Tracker Street-Scambler..... Hmmm Yes, very tempting.....
steveh
PostPosted: 22:08 - 03 Sep 2010    Post subject: Reply with quote
yeah its my old fella's 1969 rocket III Thumbs Up
Teflon-Mike
tl;dr
PostPosted: 11:21 - 04 Sep 2010    Post subject: Reply with quote
YUM!
https://members.shaw.ca/elrojo/motorcycles_files/bsa_files/bsa_rocket_3.jpg
Amazing what lurks in hidden corners of folks sheds, innit?
I went round to a freind of a freinds a little while back, to borrow a crypton tune.
Poking out from under a dust sheet was a curiouse front hub with scoop on it.....
'That looks familiar!' Thunked I!
I waited till FofF came back and asked, tentatively if it belonged to what I thought it belonged to..... and if I could pull the dust sheet off.....
He grinned....
"Well what do you think's under there?" He asked.....
"Something styled by Craig Vetter..." I replied.....
"Have a look!" He said
https://www.bikeexif.com/wp-content/uploads/2009/03/triumph_x-75_hurricane.jpg
He was also the unconvinced owner of a B40..... complete with dodgy ignition, and a 1930's BSA V-Twin!
steveh
PostPosted: 16:15 - 04 Sep 2010    Post subject: Reply with quote
yep thats identical to my old fellas, his next one is the x75 hurricane, awsome bit of kit!
steveh
PostPosted: 21:10 - 16 Sep 2010    Post subject: Reply with quote
Well, time for an update, not too much really, few new bearings and bushes arrived recently, got the frame, motor and few other bits bead blasted on my day off.
https://i48.photobucket.com/albums/f215/stesewell/1963%20bsa%20b40%20project/IMG_0331.jpg
created myself abit more work cleaning the shit out,but its worth it imo
https://i48.photobucket.com/albums/f215/stesewell/1963%20bsa%20b40%20project/IMG_0333.jpg
https://i48.photobucket.com/albums/f215/stesewell/1963%20bsa%20b40%20project/IMG_0336.jpg
head
https://i48.photobucket.com/albums/f215/stesewell/1963%20bsa%20b40%20project/IMG_0328.jpg
And i couldnt resist putting it together to see what it looks like!
https://i48.photobucket.com/albums/f215/stesewell/1963%20bsa%20b40%20project/IMG_0342.jpg
I will be assembling the motor next, ive just finished porting the head a little, lapping in the vavles, and fitting a 60thou over sized piston to get read of a horrible rust mark in the barrel.
Oh, and i intend on taking it with me to barbon hill climb this year for a little bit of a giggle Very Happy
steve.
The last post was made 16 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 152.76 Kb
