| hmmmnz |
 hmmmnz Super Spammer
 Posted: 05:51 - 14 Aug 2010 Post subject: project 67 Vespa (1)50s (update 4/10/2012) |
a week ago i picked up this motley vespa 50s small frame
its been fitted with a 150cc large frame engine,
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/111022874_full.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/111022850_full.jpg
as you can see, its had a pretty rough life and has been cut down,
a bit of a fad in the late 80's,
so thats the bad, the good is the engine has had extensive work done, porting, the the crank intake has been modified, and she runs pretty damn well breathing through the 200cc carb,
its also been fitted with a custom expansion chamber, and 10" wheels to give her a bit of clearance,
any way, the wee vespa will never be an original scoot again, so there is no point even trying to make it so,
but i will give her a complete strip down and try and give it a bit of normalcy again,
strip down, take 1
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF2968Medium.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF2969Medium.jpg
some one has cut of the side panel, so the engine is always exposed now
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF2970Medium.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF2971Medium.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF2972Medium.jpg
engine out (less than 30mins)
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF2973Medium.jpg
what they had to do to fit the larger engine in.
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF2974Medium.jpg
its to push the shock back wards so it doesnt hit the engine, ill come up with a better method
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF2975Medium.jpg
and front end off
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF2977Medium.jpg
all the cables out
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF2978Medium.jpg
and done!!
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF2979Medium.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF2980Medium.jpg
so thats stage 1,
on the next episode... foot well and leg shields... ____________________ the humans are dead
I kick arse for the lord
| twotakt |
 twotakt World Chat Champion
| hmmmnz |
| stevo as b4 |
 Posted: 22:49 - 16 Aug 2010 Post subject: |
Cool project I'm thinking of doing up a PK small frame Vespa as a future project, just for something to nip into town on in summer and to go for a little tat down the back lanes on.
Can never have enough 2stroke's!  |
| hmmmnz |
 Posted: 12:18 - 13 Sep 2010 Post subject: |
well progress pics,
i have cut a new floor and welded it in place
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF3010Small.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF3007Small.jpg
i also re-inforced the floor
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF2997Small.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF3001Small.jpg
its mostlty just spoted in place
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF3000Small.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF3005Small.jpg
on both sides,
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF3009Small.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF3008Small.jpg
except for the very front where its welded right the way down the seam
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF3003Small.jpg
i also rebuilt the front end, and milled part of the fork to shift the wheel center again,
f knows why but the wheel ran about 15mm off center, it might be the off set of the rims, although they are specific 10" rims to fit the 150 super forks,
any way, some of the strip down pics
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF2985Small.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF2984Small.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF2983Small.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/vespa/DSCF2982Small.jpg
any ways thats it for now, i have a bit more grinding to do to the welds, and then ill bog with fibre filler, then regular filler,
then start on the paint prep,
i have all new cables, pads, bearings, etc etc, which will be fitted as i go, lucky i stripped the front end, as the needle bearings were missing needles?? and that off center problem which was causing a weave is now sorted,
ill keep ya posted,
im waiting on a few more bits to arrive, but hopefully the build will pick up pace a bit now.... stupid work permitting, ____________________ the humans are dead
| CHR15 |
 CHR15 Turbo nutter bastard
 Posted: 18:21 - 13 Sep 2010 Post subject: |
are you sticking some kind of crazy engine in it or something? ____________________ Turbocharged drag thing / project death weapon / GK73A
Ste: I'm not entirely sure how you'd go about verbally abusing someone with a potato but I'm sure it's possible. |
| Frost |
 Frost World Chat Champion
 Posted: 18:35 - 13 Sep 2010 Post subject: |
| hmmmnz |
| Gazdaman |
 Gazdaman I did a trackday!!!
| hmmmnz |
| Frost |
| hmmmnz |
 Posted: 08:47 - 25 Sep 2010 Post subject: |
| hmmmnz |
| Frost |
| hmmmnz |
 Posted: 08:17 - 30 Sep 2010 Post subject: |
| hmmmnz |
 Posted: 08:39 - 02 Oct 2010 Post subject: |
| CHR15 |
 Posted: 09:17 - 02 Oct 2010 Post subject: |
looks good
what's happened to your vf though!
looks like its been in a volcano ash cloud. ____________________ Turbocharged drag thing / project death weapon / GK73A
| hmmmnz |
| hmmmnz |
 Posted: 13:13 - 06 Oct 2010 Post subject: |
| eddclarke |
This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
 eddclarke Brolly Dolly
| Carvel |
 Carvel World Chat Champion
 Posted: 20:36 - 11 Oct 2010 Post subject: |
Talk about short notice. It finished 1m 34s after you posted
Hmmmmmmmmmmmmmmmnz, dude this is an awesome project. I love the colour, and the levers  ____________________ 2002 Aprilia RSV1000R, Cbr600Fs, Mk1 B12, Vfr400 NC30...
Matt B: I can deal with crushed nuts to beat Ollie. |
| Gazdaman |
| Carvel |
| eddclarke |
 Posted: 21:26 - 11 Oct 2010 Post subject: |
I love ebay I am quite shocked how fast that sold! I might have a 2000 PX200 for sale soon. It's red in much better condition. I will update when I know if its for sale ____________________ Honda XR125L 06 ----> Yamaha FZ6 05 + ex SAS XR250 --> VFR800 + XR250r |
| devojunior |
 devojunior Brolly Dolly
The last post was made 16 years, 11 days ago. Instead of replying here, would creating a new thread be more useful? |
