Swapping Front brake discs, is it possible?
0l0dom0l0
PostPosted: 23:30 - 05 Oct 2010    Post subject: Swapping Front brake discs, is it possible? Reply with quote
Do twin front disc bikes, have specific discs for each side or can you swap them over?
the reason i ask is because one if my front discs is slightly thicker than the other and so by swapping them between sides i was hoping i would be able to increase the wear life on them. is this possible?
PostPosted: 23:44 - 05 Oct 2010    Post subject: Reply with quote
Some are symmetrical, some aren't.
I'd probably be addressing why they are measurably different thicknesses in the first place. I'd start with the calliper on the "thin" one.
I suspect any slight increase in disc life you'd get by swapping them would be offset by having to buy two new sets of pads.
Ariel Badger
PostPosted: 23:47 - 05 Oct 2010    Post subject: Reply with quote
the pads will wear with the disks, changing things over will leave you with unevenly worn pads on unevenly worn disks. This will leave you in a perfect state for a fail under breaking.
Wear then down and replace as needed but take your calipers apart to see why things are wearing unevenly, I bet you find a binding pot.
0l0dom0l0
PostPosted: 23:55 - 05 Oct 2010    Post subject: Reply with quote
i have recently had the calipers apart. looks like i might need to again Sad.
PostPosted: 00:11 - 06 Oct 2010    Post subject: Reply with quote
Under normal conditions your discs should wear evenly.
Sticky pots(or sticky sliding caliper) more than likely.
If your discs are semi floating or fully floated type then check that the buttons(bobbins) are free. Stuck buttons will create uneven wear, and can warp some discs (pulsing on the lever).
Pat
The last post was made 16 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 44.32 Kb
