ID that bike
woll
PostPosted: 17:36 - 06 Oct 2010    Post subject: ID that bike Reply with quote
My brother has been bought a bike for his birthday by his missus, it's a right wreck needs a lot of tlc and a fair few parts. But he can't order anything because it has nothing we can i.d. it from on the bike. But i reckon one of you lot will know what it is.
Its a 350 suzuki 2t
3 gears (not sure about that one)
and the kickstart doubles up as the gear lever.
I'm waiting for him to email me the pictures of the bike in question.
TUG
PostPosted: 17:39 - 06 Oct 2010    Post subject: Reply with quote
The only thing that sounds like that to me is a CZ 125 lol.
I'm intregied
Haz ER-5, innit!
Teflon-Mike
tl;dr
1970's, 350 (twin cyclinder?) two-smoke, with a gear-lever that lifts to become the Kick-starter?
Sounds like a CZ to me..........
Could some-one have stuck Suzuki badges on it, or dumped a CZ motor in a Zook frame, perhaps?
Frost
PostPosted: 17:43 - 06 Oct 2010    Post subject: Reply with quote
https://www.suzukicycles.org/photos/T/T350/1970_T350_blue_right_450.jpg
T350
woll
PostPosted: 17:46 - 06 Oct 2010    Post subject: Reply with quote
i've only seen some crappy low res pics of it but the badges on the tank are suzuki, not sure if it helps but it would appear that the carb/air box is in the engine casing.
nowhere.elysium
The Pork Lord
PostPosted: 17:49 - 06 Oct 2010    Post subject: Reply with quote
T350
Dammit, you beat me to it.
Any idea of the year? That might help narrow it down a bit.
woll
PostPosted: 17:55 - 06 Oct 2010    Post subject: Reply with quote
AFAIK he has absolutely no idea Laughing could prove interesting
Carvel
PostPosted: 18:09 - 06 Oct 2010    Post subject: Reply with quote
T350
They're 6 speed and have a normal kicstarter, gever lever setup.
Teflon-Mike
tl;dr
PostPosted: 18:53 - 06 Oct 2010    Post subject: Reply with quote
OK, back to the books!First Port of Call Henshaw.
Aparently suziki pioneered the CCI 'Controlled Crankshaft Injection' auto-lube system, and did so on thier early comuter-bies of the 1950's that were confined pretty much to the Jap home market.
First 'twin' was the Colleda TT of 1956, which derived the 1960 'Twin-Ace' and T10, developed for export (US) markets. had e-start & indicators. FOUR speed hear-box. Pressed steel frame.
Disc valves didn't come in racing until 1962, & Ernst Degnars defection from MZ.
1966 T20 'Super-Six' 250cc Six-Speed gear-box. Kick-Start. Tube steel frame.
Makes reference to 'smaller' T200, and 'larger' T500 (Implied 200cc & 500cc versions) & 'enlarged' versions of T10 in 305 & 316cc capacities.
Then goes on to describe the GT380 tripple & the derivative X7, which would seem to be too late to be pertinant to this bike.
HOWEVER: if its a T20 'super-Six' derivative, must have six speed box. If its a T10 derivative, would be four, possibly five speed.
Carb in or close to crank-case suggests Disc-Valved version, so post '63, more likely post '66, as Henshaw describes bikes previouse to the super-Six as 'unsporting'.
Looking at contemprary brochure shot in Henshaw of T10, makes no mention of disc valves, (Makes more of the 'extra-long- clutch lever, & 'sturdy fender!) so presumeably piston ported, but does mention twin cabs and they LOOK to be enclosed in a casing moulded to the engine.....
Wilson's entries for Suziki are sparse.Only early srtoker it mentions is the TC250 'Street-Scrambler' version of the Super-Six (I thought it was called the Hustler'), definitely got a seperate kick-start & 250cc.
Roland Brown, re-iterates most of what was in Henshaw, only adding a little elaboration that the T10 of '63 was thier first 'export' success, and the 'original' Colleda was a 90cc 4-stroke single, one the T10 was based on was the Colleds RB 125.
Pics of 'Super-Six' show clearly visible exposed carbs, in conventional location behind barrel.....
RIGHT, found what I was looking for, another Roland B coffee table tomb! Bridgestone 350GTR
Often confused with the 'Super-Six', its styling was very very similar, but disc valved with the carbs in the side of the crank-case, behind engine casings. Mentions the Super-Six AND provides it was piston ported Not disc.... so that accounts for conventional location of carbs then.... I had the idea there was some tortiouse induction tract, but seems its the Bridgestone that has that.
anyway, dont know if any of that may help.... looking distinctly like it's going to be a T10.
dextersaurus
PostPosted: 21:01 - 06 Oct 2010    Post subject: Reply with quote
^ /thread
woll
PostPosted: 21:05 - 06 Oct 2010    Post subject: Reply with quote
Still not been sent the pictures... will put them up when it gets here
Carvel
PostPosted: 21:06 - 06 Oct 2010    Post subject: Reply with quote
The T10 has a seperate kicker aswell.
I'm stumped, it cant be a suzuki
PostPosted: 21:17 - 06 Oct 2010    Post subject: Reply with quote
Tank badges are not a good way to tell what a bike is. My Jawa currently has a Honda CG125 tank on it.
The only bikes I've ever seen or heard of with a gear lever that doubles as a kickstart are Jawas or CZs. In fact, I think it may even be patented.
It also implies that the kickstart is on the left of the bike. This is also an almost exclusively Eastern European feature. If it's a Jap bike with a left hand kickstart it's weird. If it's a Jap bike with a right hand gear shift, it's old and rare.
As far as I'm aware, Jawa/CZ never made a crankcase induction motor but they DID make them with shrouded carbs (big alloy casting that bolts over the top of the carb and doubles as an airbox).
Simple test.
What side is the chain on?
Japanese bikes have the chain on the left of the bike. Eastern European ones have the chain on the Right. That's nearly a rule (probably a couple of exceptions to prove the rule).
Ooh. Can you see if it's a boxer twin rather than a single or paralell? Could be an MZ BK350 motor. They are cool as fuck and rare as rocking horse poo.
dextersaurus
PostPosted: 21:20 - 06 Oct 2010    Post subject: Reply with quote
OH.
Sounds like a Jawa 350 to me, maybe someone dropped it and replaced the tank off an old suzuki.
You never know Laughing
https://motorbike-search-engine.co.uk/classic-bikes-2/1987-jawa-350.jpg
Dunc
Edit: try and check the gears, if it has 4, that'll help...
Teflon-Mike
tl;dr
PostPosted: 21:21 - 06 Oct 2010    Post subject: Reply with quote
Depends where the anomolies lie.
Starting point will be with head-stock & crank-case stamping, & seeing what that turns up, then looking at the features.
May be that a gear-change cross-over linkage has confused the kick-start thing. Could be its not a 350 but a 250, might not be a T10, might be a T200, or a Super-Six or Hustler..... then might NOT be a Suzuki.
If it DEFINITELY has a combined Kick/Gear lever though, would suggest a CZ/Jawa engine...... and trying to think here, but might also explain 3-speed gear-box. Seem to recall some-where reading that they had a four-speed box, but WITHOUT neutral, there was som other mechanism that found Neutral no matter what gear you were in.
Anyway, all speculation until we get 'photos and more details.
Intreguing though.....
dextersaurus
PostPosted: 21:24 - 06 Oct 2010    Post subject: Reply with quote
Post up the pictures Laughing
Dunc
woll
PostPosted: 21:29 - 06 Oct 2010    Post subject: Reply with quote
That's the thing dunc i aint got the friggin pictures lol, my brother was meant to be emailing them a few hours ago.
They have a four speed box with poorly hardened dogs on the top gear sprocket that can break off leaving you with only 3 gears (happened to me 3 times on 2 different bikes).
They have a mechanism which finds neutral in spite of what gear you're in. It's called the gear lever.
TUG
PostPosted: 01:37 - 07 Oct 2010    Post subject: Reply with quote
ITS A CZ
Haz ER-5, innit!
woll
PostPosted: 12:46 - 07 Oct 2010    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=206591
PostPosted: 13:17 - 07 Oct 2010    Post subject: Reply with quote
Plenty of European bikes have left hand kickstarts/right hand chains too (annoying when oiling the chain on a road bike as over-oiling leads to it dripping on the tyre.)
My old KTM and more recent Husaberg both had left hand kickstart. My parents got a kickstart added to their BMW R60/6 (standard option) as they were using it for overland in Africa and that was on the left hand side too.
Think rotax may to blame for a quite a few of the west European examples.
PostPosted: 13:27 - 07 Oct 2010    Post subject: Reply with quote
It's much more basic than that.
In Europe they drive on the right. They fit sidecars to the right of the bike. The kickstart is positioned on the left so it doesn't land up between the bike and the sidecar. (Particularly relevant for any of the boxer twins where you have to stand next to the bike to work the kicker).
In the UK and Japan, we drive on the left and fit sidecars on the left. Hence kickstarts on the right.
Frost
PostPosted: 13:39 - 07 Oct 2010    Post subject: Reply with quote
Mates KTM had the kick start on the Left. It meant you had to get off the bike to start it. My old SRX had the kick start on the right, i don't think i could have started it with my left Laughing
PostPosted: 16:19 - 07 Oct 2010    Post subject: Reply with quote
You get used to the left hand kickstart after a while - the KTM was a 2 stroke, so wasn't too bad, but the Hussy could be a right pig. Probably helped that I used to start my mum's beemer when I was 11 Smile.
Sure I've seen japanese dirt outfits with the outfit to the right. Bit different to standard sidecars, but then can't see anyone doing anything else on a Husaberg really!
PostPosted: 16:23 - 07 Oct 2010    Post subject: Reply with quote
Having owned a wide assortment of bikes, I'm happy using a kickstart on either side of the bike from astride the bike or standing next to it.
You know you're getting good on a Jawa or CZ when you can flick the kickstart up using your foot without looking at it.
The last post was made 15 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.77 - MySQL Queries: 15 - Page Size: 138.99 Kb
