| steven_191 |
 steven_191 Nearly there...
| SillyMe |
 SillyMe Trackday Trickster
 Posted: 17:46 - 15 Oct 2010 Post subject: |
Your gunna have issues with this.
I will be suprised if it works for more than week or after so many read writes.
1)there must be something written on the tip of the pen drive(some codes of the pen drive manufacturer)....2)see the data transfer speed ..if the speed is greater than 10 Mb then correct and if less than 2 Mb then the fake one................
and these pen drives also don't stores information if the data is in folders.
Do the following steps:-
1. Right click on my computer icon and open manage.
2. Then open disk management.
3. There u see ur pen drive.
4. Right click on ur pen drive and click on format.
5. After successful formating restart ur computer.
6. Ur pen drive wil work again.
comand prompt way of formating pendrives is really working great.
from the start menu run the cmd. then type h: (if ur pendrive is in 'h' drive)
then type [format h:].
goto Start>run>cmd press enter
and type format then your drive at last (
example
format j: ("j" is the drive)
and if u want to quick format it
than type
format j:/q
H: {letter of your pendrive} Press Enter
Format H: press Enter
Again Press Enter
y press Enter
Press Enter
Exit Press Enter
Open the DOS prompt (Start >> Run >> cmd)
Type:
FORMAT X: /FS:FAT32 /Q /V:PenDrive
This will also reformat the Pen drive, using the FAT32 file system, and label the drive PenDrive. Replace X: with the actual drive letter of your Pen Drive
Pen drive resizing. https://www.fileguru.com/apps/pen_drive_resize_softwarepen_drive_resize_software ____________________ Once made equal to man, woman becomes his superior.
The man who says "I may be wrong, but -" does not believe there can be any such possibility
Owned and rode: Honda 100H, Honda MBX 125, Kawasaki AR 125, Suzuki RG 125 Pepsi, Honda NSR125 RK, Honda NRS 125 race bike, Suzuki GSXR 400 Bandit, Aprilia RS 125 O2, Honda CG125, Kawasaki KMX 125, Aprilia RS 125 O6, Suzuki XT225 and now Honda XR 400. ( A few scooters and other dead beats in between) |
| Inkognito |
 Inkognito Brolly Dolly
| lllN30lll |
 lllN30lll World Chat Champion
| SillyMe |
 Posted: 21:53 - 15 Oct 2010 Post subject: |
Old South bridge peripheral, I would'nt format to NTFS if i was you, it's guna be a fake 2 mg transfer rate anyway.
Sorry pal. I have seen loads of them.
Disadvantages: of NTFS
There are, however, few drawbacks when using NFTS on a USB drive. First and foremost, it requires more writing to the USB drive. Thus slower access to the device but not to the extend that turns off people from using it.
As far as the encryption is concerned you will not be able to access them from other computers. This could be a perfect feature, depending to what extend you want to secure the USB drive. If you think this will cause trouble when you need to do use it in multiple stations then don't do the files encryption.
How to enable USB drive with NTFS?
1. You need to connect your USB device to your computer, that's for sure. Right-click on My Computer from the desktop and choose Manage.
2. Click on "Device Manager" and expand out "Disk Drives". There are maybe couple of drives depending on how many USB drive & hard drive connected to your PC.
3. Right click on USB drive and select "properties". After that, click on the "Policies" tab and choose "Optimize for performance" radio button. Finally click OK and you are done!
If you right-click on USB drive and select "Format.." you will see NTFS is now available. ____________________ Once made equal to man, woman becomes his superior.
| Finglonga |
 Finglonga World Chat Champion
 Posted: 23:55 - 15 Oct 2010 Post subject: |
| SillyMe |
 Posted: 07:51 - 16 Oct 2010 Post subject: |
Wow! ____________________ Once made equal to man, woman becomes his superior.
| steven_191 |
 Posted: 10:28 - 16 Oct 2010 Post subject: |
Haha that's amazing.
I tested it by trying to download 64gb of data but it topped out at 16gb. I've just plugged it into another computer and it says it's not formatted. I'll try some of the guides later but if it don't work I'll see what the inside looks like with a hammer |
| steven_191 |
| chris-red |
 Posted: 12:41 - 17 Oct 2010 Post subject: |
| Esoteric1 wrote: | Your gunna have issues with this.
example
than type
format j:/q
Again Press Enter
y press Enter
Press Enter
Exit Press Enter
Type:
Pen drive resizing. https://www.fileguru.com/apps/pen_drive_resize_softwarepen_drive_resize_software |
That was a wasted post did you even read the last line?
Also you are wrong about NTFS the majority of things since 2000 can read NTFS any PC with an OS newer than Windows NT can read it.
If I where you I would try learning things not just copy and pasting answers.
People use NTFS for a reason.
Fat can only have a 4gb file size as a maximum, it is less stable and slower at read big files. It has a slight advantage at reading smaller files but not enough to be any concern. It is also crap at reading fragmented data whereas NTFS can take it in it's stride. AFAIK there is No/Minimal difference in write speed. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| DanceLikeAMon... |
 DanceLikeAMon... World Chat Champion
| SillyMe |
 Posted: 14:23 - 17 Oct 2010 Post subject: |
| Quote: | That was a wasted post did you even read the last line?
Fat can only have a 4gb file size as a maximum, it is less stable and slower at read big files. It has a slight advantage at reading smaller files but not enough to be any concern. It is also crap at reading fragmented data whereas NTFS can take it in it's stride. AFAIK there is No/Minimal difference in write speed. |
Just a few tips on formatting and resizing sugestions actually in reference to the original question, but if you read a little further you would have noticed it was fake, so none of this actually matters.
Looking back I don't see where top contributed to the thread.
I wonder if he knows what ZFS file systems means without googleing it.? ____________________ Once made equal to man, woman becomes his superior.
| SillyMe |
 Posted: 16:05 - 17 Oct 2010 Post subject: |
There's nothing wrong with google, the CIA use it. https://technology.timesonline.co.uk/tol/news/tech_and_web/article3652494.ece ____________________ Once made equal to man, woman becomes his superior.
| Phoenix |
 Phoenix Twisted Firestarter
 Posted: 16:23 - 17 Oct 2010 Post subject: |
| chris-red wrote: | That was a wasted post did you even read the last line?
Have to agree, Esoteric1, your posts do seem to be generally wrong. NTFS would not be a problem, virtually any computer running these days will read an NTFS drive, can't see him hooking up a 16gb flash drive to a Windows 95 machine, NTFS is also for the majority faster than FAT, not slower. The only issue with using NTFS on a flash drive is if you plan to use it in other hardware like music players, DVD players with USB in etc as they will often only read FAT16/32.
Your method of formating is little more than deleting too, and there's no reason to use a command prompt format, it's just a long way to do a windows one. It certainly won't resize the drive. Proper low level format software is needed for a genuine format and even some of the best programs still can't resize hacked flash drives.
Lastly, hacked flash drives do transfer at more than 2mb/s, where you came up with that arbitrary figure is anyone's guess. The memory isn't of inferior quality, it's just smaller than than it appears usually, I've had a few fake memory items, all transfer at normal speeds. They also hold directory structures so again, not sure what you mean they won't let you create folders.
| chris-red |
| SillyMe |
 Posted: 16:35 - 17 Oct 2010 Post subject: |
Yeah you right about the FAT32 and NTFS issue, Vista actually has a facility to format USB pen drives to NTFS https://www.youtube.com/watch?v=-fv1cwY3iYE.
I posted a link to resizing software and a set of other instruction of how this could be achieved, I also posted how formating could be done using command prompt.
Just posting a few suggestions, no need for a penis measuring competition.
Anyway the threads dead, it died long ago when it was ascertained that the said pen drive was fake.
Finished munching on those salt and vinigar crips yet keyboard warrior. ____________________ Once made equal to man, woman becomes his superior.
| Phoenix |
| SillyMe |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
 Posted: 16:40 - 17 Oct 2010 Post subject: |
| Phoenix wrote: | | Esoteric1 wrote: | Anyway the threads dead, it died long ago when it was ascertained that the said pen drive was fake.
What, you mean on the first post?  |
Correct well said.
Just another bunch of keyboard warriors getting high from muching salt en vinigar crisps putting the world to rights in there own minds.
Sigh!, Yaaarrn! Never mind! ____________________ Once made equal to man, woman becomes his superior.
| chris-red |
 Posted: 16:48 - 17 Oct 2010 Post subject: |
| Esoteric1 wrote: | Yeah you right about the FAT32 and NTFS issue, Vista actually has a facility to format USB pen drives to NTFS https://www.youtube.com/watch?v=-fv1cwY3iYE.
Finished munching on those salt and vinigar crips yet keyboard warrior. |
As I said before not a keyboard warrior happy to meet anyone face to face that has a problem with me.
The drive still works this seems to be what you cannot grasp. Yes it is a fake but it works as a drive just a 16 not a 64 if he could find software that work change the size that windows recognises it as it would be a fully functioning 16gb pen drive.
Did you actually look at the link you posted? Probably not, point to where to software that resizes pen drives is on that page, it's a loads of unrelated keyword linked software.
This is what I'm getting at spamming barely relevant links and copy and pastes is pointless.
What difference does formatting from the command prompt do to formatting in Windows? Again more pointless irrelevant information. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| chris-red |
| SillyMe |
 Posted: 17:57 - 17 Oct 2010 Post subject: |
Read the original question and reform it into some logical coherent syntax we can all understand.
I bought a 64gb USB stick in china a while ago. When I say 64gb I actually 16gb. It reads on the computer as 64gb though. I know they reprogramme them to read higher numbers to cheat you out of money. Luckily it was still cheap even for 16gb. Can I get it back to reading what it's supposed to? Formatting doesn't work.
You joined this thread to slag off other people, measure penis sizes as the analogy goes, and made no offer to answer this illogical question your self in the first place.
You been shot down and already, your a keyboard warrior sat there slagging others off. This thread died long ago so pee off please.
I quote "Formatting doesn't work"
So I posted some suggestions, get off the case dood.
Answer questions in stead of slagging people off.
I already admitted i was wrong about the FAST32 and NTFS transfer rates and now stand corrected.
Edit: An obsessive compulsive Hunter of the weak and lonely strangers.
https://img177.imageshack.us/img177/2954/14577166274c811ac841040.png ____________________ Once made equal to man, woman becomes his superior.
| chris-red |
 Posted: 21:47 - 17 Oct 2010 Post subject: |
| Esoteric1 wrote: | Read the original question and reform it into some logical coherent syntax we can all understand.
Hunter of the weak and loney strangers.
https://img177.imageshack.us/img177/2954/14577166274c811ac841040.png |
This thread hasn't died the problem is still there.
I hunt people who post BS and unhelpful comments such as your self.
I have no idea why you keep going on about being a keyboard warrior or penis sizes, I'm purely pointing out you have been posting irrelevant crap. The reason this forum is good is because most people do try to help and post useful comments not just spam copy and pasted shite.
| Quote: | You been shot down and already, your a keyboard warrior sat there slagging others off. |
Been shot down already how is that?
Will say it again am happy to meet up with anyone who thinks I'm a keyboard warrior.
| Quote: | Hunter of the weak and loney strangers. |
Are you actually implying you are a weak and 'loney' [SIC] stranger?
Also
Your = possesive
You're = You are
In simple terms 'your a...' is wrong ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| SillyMe |
 Posted: 21:52 - 17 Oct 2010 Post subject: |
.....................................................Goodbye!
| chris-red |
 Posted: 22:01 - 17 Oct 2010 Post subject: |
No logical reply then  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| SillyMe |
 Posted: 22:09 - 17 Oct 2010 Post subject: |
You give me a thumbs because I just gave you one. ____________________ Once made equal to man, woman becomes his superior.
The last post was made 15 years, 329 days ago. Instead of replying here, would creating a new thread be more useful? |
