16gb USB memory stick reading 64gb
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2  Next
steven_191
PostPosted: 17:00 - 15 Oct 2010    Post subject: 16gb USB memory stick reading 64gb Reply with quote
I bought a 64gb USB stick in china a while ago. When I say 64gb I actually 16gb. It reads on the computer as 64gb though. I know they reprogramme them to read higher numbers to cheat you out of money. Luckily it was still cheap even for 16gb. Can I get it back to reading what it's supposed to? Formatting doesn't work.
SillyMe
PostPosted: 17:46 - 15 Oct 2010    Post subject: Reply with quote
Your gunna have issues with this.
I will be suprised if it works for more than week or after so many read writes.
1)there must be something written on the tip of the pen drive(some codes of the pen drive manufacturer)....2)see the data transfer speed ..if the speed is greater than 10 Mb then correct and if less than 2 Mb then the fake one................
and these pen drives also don't stores information if the data is in folders.
Do the following steps:-
1. Right click on my computer icon and open manage.
2. Then open disk management.
3. There u see ur pen drive.
4. Right click on ur pen drive and click on format.
5. After successful formating restart ur computer.
6. Ur pen drive wil work again.
comand prompt way of formating pendrives is really working great.
from the start menu run the cmd. then type h: (if ur pendrive is in 'h' drive)
then type [format h:].
goto Start>run>cmd press enter
and type format then your drive at last (Smile
example
format j: ("j" is the drive)
and if u want to quick format it
than type
format j:/q
H: {letter of your pendrive} Press Enter
Format H: press Enter
Again Press Enter
y press Enter
Press Enter
Exit Press Enter
Open the DOS prompt (Start >> Run >> cmd)
Type:
FORMAT X: /FS:FAT32 /Q /V:PenDrive
This will also reformat the Pen drive, using the FAT32 file system, and label the drive PenDrive. Replace X: with the actual drive letter of your Pen Drive
Pen drive resizing. https://www.fileguru.com/apps/pen_drive_resize_softwarepen_drive_resize_software
Once made equal to man, woman becomes his superior.
The man who says "I may be wrong, but -" does not believe there can be any such possibility
Owned and rode: Honda 100H, Honda MBX 125, Kawasaki AR 125, Suzuki RG 125 Pepsi, Honda NSR125 RK, Honda NRS 125 race bike, Suzuki GSXR 400 Bandit, Aprilia RS 125 O2, Honda CG125, Kawasaki KMX 125, Aprilia RS 125 O6, Suzuki XT225 and now Honda XR 400. ( A few scooters and other dead beats in between)
Inkognito
PostPosted: 19:17 - 15 Oct 2010    Post subject: Reply with quote
You don't have to restart your PC after formatting an external harddrive/usb drive. You only do that if you format a brand new disk and setting up partitions. Or if you're re-formatting your primary partition to install winblows etc.
Also why would you use FAT32 these days?
Unless you're running windows 98 or something i don't see any reason for FAT32. Unless the drive doesn't support NTFS.
I suspect he will need to do a proper format if anything so quick format is pretty useless as it doesn't really format the drive but rather overwrites existing data with nothing.
Also if it really is 64gb then using FAT32 would not be a good idea. There are size limits to FAT32. Think it's 32gb or something.
Edit: Have you tried something like partition magic on the drive to see what it looks like there?
Maybe re-do the partition and see if that helps. Will need a format after you've done that.
lllN30lll
PostPosted: 19:22 - 15 Oct 2010    Post subject: Reply with quote
You've purchased a fake, what do you expect? lol
Download this https://www.heise.de/software/download/h2testw/50539 run it, £5 to charity says it's fake.
Turbo R1
CRF450R
SillyMe
PostPosted: 21:53 - 15 Oct 2010    Post subject: Reply with quote
Old South bridge peripheral, I would'nt format to NTFS if i was you, it's guna be a fake 2 mg transfer rate anyway.
Sorry pal. I have seen loads of them.
Disadvantages: of NTFS
There are, however, few drawbacks when using NFTS on a USB drive. First and foremost, it requires more writing to the USB drive. Thus slower access to the device but not to the extend that turns off people from using it.
As far as the encryption is concerned you will not be able to access them from other computers. This could be a perfect feature, depending to what extend you want to secure the USB drive. If you think this will cause trouble when you need to do use it in multiple stations then don't do the files encryption.
How to enable USB drive with NTFS?
1. You need to connect your USB device to your computer, that's for sure. Right-click on My Computer from the desktop and choose Manage.
2. Click on "Device Manager" and expand out "Disk Drives". There are maybe couple of drives depending on how many USB drive & hard drive connected to your PC.
3. Right click on USB drive and select "properties". After that, click on the "Policies" tab and choose "Optimize for performance" radio button. Finally click OK and you are done!
If you right-click on USB drive and select "Format.." you will see NTFS is now available.
Finglonga
PostPosted: 23:55 - 15 Oct 2010    Post subject: Reply with quote
Is this the one? Wink
https://img843.imageshack.us/img843/3090/fakeusbflashdrive.jpg
Mr. Green
Andy Sez....
F.Y.Y.F.F.
SillyMe
PostPosted: 07:51 - 16 Oct 2010    Post subject: Reply with quote
Wow!
steven_191
PostPosted: 10:28 - 16 Oct 2010    Post subject: Reply with quote
Finglonga wrote:
Haha that's amazing.
I tested it by trying to download 64gb of data but it topped out at 16gb. I've just plugged it into another computer and it says it's not formatted. I'll try some of the guides later but if it don't work I'll see what the inside looks like with a hammer
steven_191
PostPosted: 10:32 - 16 Oct 2010    Post subject: Reply with quote
And also it's definately fake. Sony vaio don't make USB drive. They are micro vault or something. Of course I found this out when I got back home from hong kong
PostPosted: 12:41 - 17 Oct 2010    Post subject: Reply with quote
example
than type
format j:/q
Again Press Enter
y press Enter
Press Enter
Exit Press Enter
Type:
That was a wasted post did you even read the last line?
Also you are wrong about NTFS the majority of things since 2000 can read NTFS any PC with an OS newer than Windows NT can read it.
If I where you I would try learning things not just copy and pasting answers.
People use NTFS for a reason.
Fat can only have a 4gb file size as a maximum, it is less stable and slower at read big files. It has a slight advantage at reading smaller files but not enough to be any concern. It is also crap at reading fragmented data whereas NTFS can take it in it's stride. AFAIK there is No/Minimal difference in write speed.
DanceLikeAMon...
PostPosted: 13:31 - 17 Oct 2010    Post subject: Reply with quote
I bought a 200GB Sony USB stick for about £2 from the Pearl Market in Beijing. It was obviously a fake as everything sold there is.
Managed to write one file to it, then couldn't read or write on it anymore after that.
Also purchased the worst quality copy of Watchmen on BluRay I have ever seen. It was like VHS quality but with vaseline smeared over the screen. If memory serves, it wasn't even a BluRay disc it was a VCD.
SillyMe
PostPosted: 14:23 - 17 Oct 2010    Post subject: Reply with quote
Just a few tips on formatting and resizing sugestions actually in reference to the original question, but if you read a little further you would have noticed it was fake, so none of this actually matters.
Looking back I don't see where top contributed to the thread.
I wonder if he knows what ZFS file systems means without googleing it.?
SillyMe
PostPosted: 16:05 - 17 Oct 2010    Post subject: Reply with quote
There's nothing wrong with google, the CIA use it. https://technology.timesonline.co.uk/tol/news/tech_and_web/article3652494.ece
Phoenix
Twisted Firestarter
PostPosted: 16:23 - 17 Oct 2010    Post subject: Reply with quote
Have to agree, Esoteric1, your posts do seem to be generally wrong. NTFS would not be a problem, virtually any computer running these days will read an NTFS drive, can't see him hooking up a 16gb flash drive to a Windows 95 machine, NTFS is also for the majority faster than FAT, not slower. The only issue with using NTFS on a flash drive is if you plan to use it in other hardware like music players, DVD players with USB in etc as they will often only read FAT16/32.
Your method of formating is little more than deleting too, and there's no reason to use a command prompt format, it's just a long way to do a windows one. It certainly won't resize the drive. Proper low level format software is needed for a genuine format and even some of the best programs still can't resize hacked flash drives.
Lastly, hacked flash drives do transfer at more than 2mb/s, where you came up with that arbitrary figure is anyone's guess. The memory isn't of inferior quality, it's just smaller than than it appears usually, I've had a few fake memory items, all transfer at normal speeds. They also hold directory structures so again, not sure what you mean they won't let you create folders.
PostPosted: 16:34 - 17 Oct 2010    Post subject: Reply with quote
I know it is fake Steve told me in the pub after he came back from hong kong, you can still write to it it just fools windows into making it believe it is bigger than it is. Try reading the post again he is asking for a tool that resets the file size not how to format the drive ATM whether it is FAT or NTFS is not the issue. He already said formatting doesn;t work I.e. he has tried it and knows how to do it.
I might was well have posted a copy and paste from google on how to install a CD drive from google for all the good it did.
Try only answering questions when you know the answer not copy and pasting from google. Nothing is wrong with google you not understanding questions and posting copy and paste shite is the issue.
SillyMe
PostPosted: 16:35 - 17 Oct 2010    Post subject: Reply with quote
Yeah you right about the FAT32 and NTFS issue, Vista actually has a facility to format USB pen drives to NTFS https://www.youtube.com/watch?v=-fv1cwY3iYE.
I posted a link to resizing software and a set of other instruction of how this could be achieved, I also posted how formating could be done using command prompt.
Just posting a few suggestions, no need for a penis measuring competition.
Anyway the threads dead, it died long ago when it was ascertained that the said pen drive was fake.
Finished munching on those salt and vinigar crips yet keyboard warrior.
Phoenix
Twisted Firestarter
PostPosted: 16:39 - 17 Oct 2010    Post subject: Reply with quote
What, you mean on the first post? Rolling Eyes
SillyMe This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
PostPosted: 16:48 - 17 Oct 2010    Post subject: Reply with quote
As I said before not a keyboard warrior happy to meet anyone face to face that has a problem with me.
The drive still works this seems to be what you cannot grasp. Yes it is a fake but it works as a drive just a 16 not a 64 if he could find software that work change the size that windows recognises it as it would be a fully functioning 16gb pen drive.
Did you actually look at the link you posted? Probably not, point to where to software that resizes pen drives is on that page, it's a loads of unrelated keyword linked software.
This is what I'm getting at spamming barely relevant links and copy and pastes is pointless.
What difference does formatting from the command prompt do to formatting in Windows? Again more pointless irrelevant information.
PostPosted: 16:56 - 17 Oct 2010    Post subject: Reply with quote
Seriously what have you contributed to this thread?
Telling him how to format which he has said he already has.
Posted a link claiming to be for changing the size of a pen drive but was full of over junk software.
Saying load of junk about FAT vs NTFS which was not only unrelated but wrong
What have you contributed that has been relevant or helpful in this thread?
SillyMe
PostPosted: 17:57 - 17 Oct 2010    Post subject: Reply with quote
Read the original question and reform it into some logical coherent syntax we can all understand.
You joined this thread to slag off other people, measure penis sizes as the analogy goes, and made no offer to answer this illogical question your self in the first place.
You been shot down and already, your a keyboard warrior sat there slagging others off. This thread died long ago so pee off please.
I quote "Formatting doesn't work"
So I posted some suggestions, get off the case dood.
Answer questions in stead of slagging people off.
I already admitted i was wrong about the FAST32 and NTFS transfer rates and now stand corrected.
Edit: An obsessive compulsive Hunter of the weak and lonely strangers.
https://img177.imageshack.us/img177/2954/14577166274c811ac841040.png
PostPosted: 21:47 - 17 Oct 2010    Post subject: Reply with quote
Hunter of the weak and loney strangers.
This thread hasn't died the problem is still there.
I hunt people who post BS and unhelpful comments such as your self.
I have no idea why you keep going on about being a keyboard warrior or penis sizes, I'm purely pointing out you have been posting irrelevant crap. The reason this forum is good is because most people do try to help and post useful comments not just spam copy and pasted shite.
Been shot down already how is that?
Will say it again am happy to meet up with anyone who thinks I'm a keyboard warrior.
Are you actually implying you are a weak and 'loney' [SIC] stranger?
Also
Your = possesive
You're = You are
In simple terms 'your a...' is wrong
SillyMe
PostPosted: 21:52 - 17 Oct 2010    Post subject: Reply with quote
.....................................................Goodbye!
PostPosted: 22:01 - 17 Oct 2010    Post subject: Reply with quote
No logical reply then Thumbs Up
SillyMe
PostPosted: 22:09 - 17 Oct 2010    Post subject: Reply with quote
You give me a thumbs because I just gave you one.
The last post was made 15 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 152.52 Kb
