| Quickly |
 Quickly Crazy Courier
| Syris the Indomitable |
 Syris the Indomitable Crazy Courier
 Posted: 13:35 - 29 Oct 2010 Post subject: |
That's what I would do and just fill in any deep scratches with car body filler, sand till smooth.
Rub down with 80 grit wet and dry.
Then rub down with 1200 grit wet and dry paper until smooth.
Shake the can vigorously for two minutes.
Holding the spray can approximately 25cm away from the surface to be painted, apply a 2 to 3 coats of paint at 20 -30 minute intervals.
Allow the paintwork 24 hours to dry then rub it down with 1200 grit wet and dry paper. It should lose its gloss appearance and take on a dull, matt finish. Clean with warm, soapy water, rinse and dry.
Apply clear lacquer.
https://www.youtube.com/watch?v=xG4ex1Q4Xak ____________________ In Greek mythology Ichor is what immortals have in the place of blood
Those that mind, don't matter...Those that matter, don't mind. Do you agree with this? |
| Rogerborg |
 Rogerborg nimbA
| Teflon-Mike |
 Teflon-Mike tl;dr
| map |
 map Mr Calendar
 Posted: 14:22 - 01 Nov 2010 Post subject: |
I'd say before you paint, either primer of colour, to make sure you wipe over with some solvent based cleaned just to make sure panels clear of any muck and oil. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| alan0259 |
 alan0259 Nova Slayer
| TQ |
 TQ Trackday Trickster
| map |
 map Mr Calendar
The last post was made 15 years, 355 days ago. Instead of replying here, would creating a new thread be more useful? |
