Theoretical Stupidity,
DrDonnyBrago
PostPosted: 22:09 - 03 Nov 2010    Post subject: Re: Theoretical Stupidity, Reply with quote
warped one wrote:
Whilst clearing up the garage a few weeks ago I came across a stash of CB125tde heads and barrels, all looking rather good for the age.
Now my Idea is if I took 8 of these and made them into a circle and did some bashing could I THEORETICALLY make a 992 cb125?
https://www.buzzhunt.co.uk/wp-content/2009/06/radial-engine.jpg
On your own there mate.
nowhere.elysium
The Pork Lord
PostPosted: 22:20 - 03 Nov 2010    Post subject: Reply with quote
Theoretically, you probably could.
However, given your track record for general weirdness, I'm expecting something more along the lines of "Mr. Warped's fantastical four-stroke bumming machine" to be the end result, as opposed to a functional litre engine.
dragstaar
PostPosted: 22:25 - 03 Nov 2010    Post subject: Reply with quote
going by that animation. I'd say fuck making a bike and make some sort f werif fuck machine and ebay it
Teflon-Mike
tl;dr
PostPosted: 22:29 - 03 Nov 2010    Post subject: Reply with quote
Hmmm... in theory......
But your 1000cc Rotary 16, would, at best, make about as much power as a Stock CBR6 four pot....
But in practice....
The crank journals would have to be about a foot wide to fit thje big ends on.
The cam chain tensioners would be a bit of a bitch to get at..
Alternator arangement would be a bit interesting...
with sixteen CDi units, & the associated ignitior coils....
Hate to try and get the plug caps and coil wiring in the right places too...
Oh, and oil getting past the rings in the inverted barells....
Paulington
PostPosted: 22:30 - 03 Nov 2010    Post subject: Reply with quote
8-Way Bumming Machine, sounds like it could be a hit.
The real question, would it be better if it was a 2 stroke or 4 stroke? Thinking.
blurredman
PostPosted: 22:32 - 03 Nov 2010    Post subject: Reply with quote
Are you right in the head? 2 strokeeeeeeeeee Cool
I would breathe the stuff if I could. That fruity smell. Lovely!
swiftb
PostPosted: 22:32 - 03 Nov 2010    Post subject: Re: Theoretical Stupidity, Reply with quote
Theres definetly something sexual about that there animation..
nowhere.elysium
The Pork Lord
PostPosted: 22:34 - 03 Nov 2010    Post subject: Re: Theoretical Stupidity, Reply with quote
I think it's safe to say that you and I have some very different ideas about what sex should be, then.
Carvel
PostPosted: 22:34 - 03 Nov 2010    Post subject: Reply with quote
https://images.motorcyclistonline.com/features/122_2006_03_z+legend_of_the_motorcycle+radial_engine.jpg
Its doable I guess
Teflon-Mike
tl;dr
PostPosted: 22:46 - 03 Nov 2010    Post subject: Reply with quote
Its doable I guess
Does this display my level of depravity..... I looked at that pic and thought:-
"I wonder if you can rotate the engine around the crank, so you can adjust the valve clerances, one bank at a time without having to shift your stool?"
The following thought was:-
"if so... I wonder what noise it would make if you forgot to to the pinch bolts back up, & when you started it up, the engine started spinning like a propeller"
Actually always been fascinated by the radial engine. That one i think is a 7-pot Gnome, fixed cylinder motor.
There was one that had a fixed crank, the pots spinning with the prop. Pretty sure I remember seeing a version where the prop-blades were bolted on the cylinder heads.
Idea of a 2-stroke radial has always apealed, total loss lubrication meaning that they can safely run inverted without the crank-case lube soaking into the inverted pots. Only trouble with the two stroke is the sealed crank-cases per pot, denying the possibility to use a common crank-case and crank journal for all cylinders. I mean, as animation, the crank-case volume doesn't vary enough to use it to 'pump' as a two stroke does, and what little pumping it could do would have to be shared between all cyclinders... unless you super-charged it.....
SO! 16 X5 barels it is then, and a Mini-Cooper supercharger!
PostPosted: 22:47 - 03 Nov 2010    Post subject: Re: Theoretical Stupidity, Reply with quote
swiftb38 wrote:
I'm with the swifty one on that one. Something about that wiggle there looks sexual!
SirEdward
PostPosted: 23:09 - 03 Nov 2010    Post subject: Re: Theoretical Stupidity, Reply with quote
You, filthy, filthy people...; Rather than being DP, it's a 5-way penetration intercourse.
"Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
Pardot Kynes in "Appendix I: The Ecology of Dune""
PostPosted: 23:12 - 03 Nov 2010    Post subject: Re: Theoretical Stupidity, Reply with quote
Not at all. its just a very seductive movement. Imagine that kind of movement on a woman..... Embarassed
swiftb
PostPosted: 23:17 - 03 Nov 2010    Post subject: Re: Theoretical Stupidity, Reply with quote
Thats the angle I was coming from, not some kind of perverse 5 way ramrod, imagine the top piston has a 'ladys' face on it..
ZRX61
Victor Meldrew
PostPosted: 23:32 - 03 Nov 2010    Post subject: Reply with quote
Teflon-Mike wrote:
The crank journals would have to be about a foot wide to fit thje big ends on.....
Of course they wouldn't....
but you need an odd number of cylinders, so either throw one away or find another one.. so assuming 9 the firing order would be 1,3,5,7,9,2,4,6,8 (or 1,3,5,7,2,4,6 for a 7 cylinder).
The tricky bit is the cam because radials use a ring cam that moves at 1/5 engine speed, not a shaft like inline engines...
So get yourself a master rod...or two...
https://img.photobucket.com/albums/v317/ZRX61/Warbirds/10-30-11001.jpg
It's only about 3 1/2in wide,... but almost 30in across...when it has the slave rods attached
https://img.photobucket.com/albums/v317/ZRX61/Warbirds/10-30-11002.jpg
They're not one night stands, they're auditions.
Moo.
PostPosted: 23:36 - 03 Nov 2010    Post subject: Reply with quote
You mean like a woman sat ontop of you doing that.. i can see where your coming from.. question is, why does this woman have 5 buckets on her?
A2 Passed 18/6/10
PostPosted: 23:37 - 03 Nov 2010    Post subject: Reply with quote
cus we have strange tastes! Laughing
swiftb
PostPosted: 23:59 - 03 Nov 2010    Post subject: Re: Theoretical Stupidity, Reply with quote
https://www.passionup.com/images/shakeit.gif
DrDonnyBrago
PostPosted: 09:06 - 04 Nov 2010    Post subject: Re: Theoretical Stupidity, Reply with quote
If by woman you mean sexy starfish with club feet and boxing gloves...
I agree entirely Mr. Green .
map
Mr Calendar
PostPosted: 11:57 - 04 Nov 2010    Post subject: Re: Theoretical Stupidity, Reply with quote
Why am I thinking Suck, Squeeze, Bang, Blow.
...and not necessarily in a 4-stroke kind of way Embarassed
The last post was made 15 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 123.64 Kb
