New boots don't work!
Jonbek
PostPosted: 12:56 - 04 Nov 2010    Post subject: New boots don't work! Reply with quote
I've been riding about on my new yamaha ybr 125 with normal leather type shoes without any problems, not great for ankle protection mind. So I bought some boots from j & s on ebay. Look fine and fit fine. They are only about 30 quid. Just been out for a ride and found I can't operate the gears. Impossible to move from 1st to 2nd they just won't fit under the gear lever! Nightmare.
Do you reckon it's a problem with the boots or am I just being a stupid tw@t??? Shocked
Paxovasa
PostPosted: 13:03 - 04 Nov 2010    Post subject: Re: New boots don't work! Reply with quote
You could adjust the gear lever Thumbs Up
Undo the bolt, slide it off and put the lever back on but increase the gap so you can get boot under the lever Thumbs Up
Dazbo666
PostPosted: 13:07 - 04 Nov 2010    Post subject: Reply with quote
Unless there's something specific about tyour bike, or you're wearing teddy boy shoes, I can't think what the problem is??
https://www.masqueradecostume.co.uk/Gallery/Album/Hire%20Boots%20And%20Shoes/slides/GENTS%20TEDDY%20BOY%20SHOE.jpg
Word of the day : DILLIGAF
DrDonnyBrago
PostPosted: 13:12 - 04 Nov 2010    Post subject: Reply with quote
I had that exact problem on my CBT. I bought some racey boots for use when I passed and couldn't fit my foot under the lever of a new version YBR125. They got me out a VAN VAN 125 which had a longer gear lever.
My suggestion is to get them softened up by wearing them around the house, they will stretch and will be ok after a while.
Jonbek
PostPosted: 13:14 - 04 Nov 2010    Post subject: Reply with quote
hahaha
The foot rest is much higher than the gear lever so can't get the boot under,is fine with my current shoes. Will try adjusting it cheers...
supZ
PostPosted: 13:17 - 04 Nov 2010    Post subject: Reply with quote
this
new 'proper' bike boots will be stiff (like any new boots tbh) and require a bit of time to wear in.
when i first got my vertigos i had to lift my leg just to change gear as i couldnt move my ankle! now they've worn in they're fine
CBR954RR - Daily toy
CBR600RR - Trackbike
Jonbek
PostPosted: 13:18 - 04 Nov 2010    Post subject: Reply with quote
I've worn them around the house for about 3 days to try and get used to them but no luck..
DrDonnyBrago
PostPosted: 13:24 - 04 Nov 2010    Post subject: Reply with quote
Do some lunges Thumbs Up
Valentino Mossy
You should be able to adjust the gear linkage rod to make the lever come up a bit.
I had exactly the same problem moving from my old boots to my new RST's.
Took a while to get use to but after moving the gsxr's lever a bit, it was okay.
PostPosted: 14:10 - 04 Nov 2010    Post subject: Reply with quote
Your gear lever will slide onto a splined shaft, either directly or through a linkage (likely directly on the YBR). The lever will be clamped on with a bolt. It's literally a 5 minute job to undo the bolt, slide the lever off the shaft, rotate it slightly to raise it and re-fit.
tk338
PostPosted: 15:19 - 04 Nov 2010    Post subject: Reply with quote
Not wanting to echo what everyone else has said, although i probably will, I did do the moving the gear lever with a ybr 125, it took a couple of minutes to get it right, slide it onto the splined shaft, sit on the bike see if it fits, off again, minor adjustment etc...
Word of warning though I found it best when I put mine so the top of my foot was touching the bottom of the lever, and not too high or you'll hit yourself in the chin when you go to change down again. It'll take a bit of getting used too, too, but well worth it when you get it right.
I can't remember if the if the right size tool was in the OEM toolkit either I think I had to buy another, it was too difficult to use under the bike and I almost stripped the bolt...
Either way with the right tools its an easy job, and takes 5 minutes.
map
Mr Calendar
PostPosted: 15:24 - 04 Nov 2010    Post subject: Reply with quote
tk338 wrote:
...I did do the moving the gear lever with a ybr 125, it took a couple of minutes to get it right, slide it onto the splined shaft, sit on the bike see if it fits, off again, minor adjustment etc...
A little easier if you get some help as you can sit on the bike and get someone else to put it in the right position.
Jonbek
PostPosted: 17:00 - 04 Nov 2010    Post subject: Reply with quote
I'm going to take it into Sale Yamaha so they can do it,i'm shit at that sort of thing and will make a botch of it.
Cheers for the advice
Ciar?n
PostPosted: 19:44 - 04 Nov 2010    Post subject: Reply with quote
It is damn near impossible to ride an older model YBR in boots.
Fact.
Which is why we all wear TCX shoes in our shop.
HD
PostPosted: 19:58 - 04 Nov 2010    Post subject: Reply with quote
Fact.
Is that the X-square ones by any chance? They look nice Laughing
Ciar?n
PostPosted: 20:50 - 04 Nov 2010    Post subject: Reply with quote
X-cubes, and i'm wearing some cheaper pair atm, freebies lol
HD
PostPosted: 21:14 - 04 Nov 2010    Post subject: Reply with quote
Haha. Any good? Think I may get a pair.
Though part of me thinks if Im gonna buy boots I may buy the proper thing :/
stonesie
PostPosted: 21:17 - 04 Nov 2010    Post subject: Reply with quote
I had the same problem on the CG125 with my new boots, still ware my old walking boots when I go out on that.
2wheelsteve
PostPosted: 22:12 - 04 Nov 2010    Post subject: Reply with quote
Yep had the same problem with a new pair I bought recently, I move the shift a notch or two but still not as easy as my old boots, you'll get used to it like everything really, ride safe Thumbs Up Smile
Ride Safe
PostPosted: 23:42 - 04 Nov 2010    Post subject: Re: New boots don't work! Reply with quote
When I first wore motocross boots (I presume these are normal boots you've got, not dirt bike boots?) I always had this problem and kept thinking I needed to move the gear lever up.
However, doing so would mean it would be too high for going down, as it was already about right or a little too high for that.
I didn't notice when, but at some point I just wasn't have the problem, without anything changing.
Been using them for a few years now and while I don't like them on road bikes, managed to ride a GSXR1000 fine with them, despite a relatively 'extreme' riding position.
HD
PostPosted: 23:53 - 04 Nov 2010    Post subject: Reply with quote
I always used to go into neutral on slow corners Laughing
But yeah, leave it where it is and wear your boots in cos else you'll end up in neutral all of the time.
Or just move the lever up for a couple hundred miles, wear your boots in then put it down 'gen Smile
Mark65
PostPosted: 10:11 - 05 Nov 2010    Post subject: Reply with quote
Yes undo the nut and remove the bolt completly as it sits in a groove behind the splines on the shaft, it will then slide straght off easily.
Mark
Frost
PostPosted: 10:44 - 05 Nov 2010    Post subject: Reply with quote
On small bikes i always find the gear change linkage position annoying. It's either so far up that i need to take my foot completely off the peg to change down, or i struggle to get my toe under it. Big bikes seem designed more for man sized feet and don't seem to give me this problem. One solution i've found is to move my toe to the side, down, then up, kinda flicking the side of the lever rather than trying to get my whole toe under it.
The last post was made 15 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 117.88 Kb
