Stroking a smoker
Whosthedaddy
PostPosted: 10:45 - 26 Nov 2010    Post subject: Stroking a smoker Reply with quote
How long does it take to get a 2t up and ready for riding?
I know that letting any bike idle for too long on choke is never a good thing but also ragging a bike from cold is just as bad. Does gentle urban riding constitute as 'warming' the bike up with no harsh pull aways from the lights for the first 5-10 minutes or so? Or is it pretty much a gentle ringing of the throttle the best way, well best way to annoy the neighbours anyways.
PostPosted: 10:54 - 26 Nov 2010    Post subject: Re: Stroking a smoker Reply with quote
Depends if its water or air cooled, but normally I warm up the RD by revving it with no load on it, IE in neutral. I only rev it to about 3k initially, then move slowly to about 6k until the needle on the temperature gauge gets off of the stop. Then I ride it and thrash it as soon as its warm.
On a more used road bike I'd probably start the thing up, ride off gently and then thrash it when its warm.
{EDIT} when I talk about 'revving it' I mean blipping the throttle as you would see in GP paddocks in the 80s and 90s {edit}
hmmmnz
PostPosted: 11:51 - 26 Nov 2010    Post subject: Reply with quote
my little air cooled bike gets about 10-20 seconds while i get my helmet on then its a constant thrash from the moment i get out the drive
the humans are dead
I kick arse for the lord
HD
PostPosted: 12:19 - 26 Nov 2010    Post subject: Reply with quote
What bike is it?
Glenben92
PostPosted: 12:47 - 26 Nov 2010    Post subject: Reply with quote
Better off to warm it up with load on the engine. start it, whack the helmet on slowly, check you've got your keys and shit, then jump on and ride gently for the first 10 15 minutes or so, if you wanna be REALLY kind to your engine. takes a surprising amount of time for the engine and oil to FULLY warm through. But I go OTT with care Smile
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
TQ
PostPosted: 13:10 - 26 Nov 2010    Post subject: Reply with quote
He's talking about a two stroke which need to be treated a lot gentler than a four stroke.
Personally it depends on the bike (ie the level of tune). I'd go off MarJay's advice raising or lowering the time and revs depending on whether the bike is more or less tuned than a standard RD.
First Bike :Gilera DNA 50 | Second: Imported 1989 NSR125
Third: 1998 Yamaha XJ600N | Currently: 1999 Yamaha FZS600
Teflon-Mike
tl;dr
PostPosted: 13:23 - 26 Nov 2010    Post subject: Reply with quote
You warm a 4-Stroke up to give the oil a chnce to warm up and thin out, get circulating round the block, coating the cams and rockers and other wirly bits.
On a two-stroke, you dont have such a lubrication system to 'prime', oil gets where its supposed to via the auto-lube pump, or pre-mix, and is washed through with teh charge each combustion cycle. Reason for warming a 2T is to get the piston and bore to temperature so that the metal expands to the right size for the 'running' clerances, to avoid it nipping up.
Its old lore but still reasonably valid, you have alloy piston and iron cylinder. Alloy expands more than steel, so the clerance 'cold' in a lot bigger on the piston to allow it to expand that bit more than the cylinder as it gets hot. BUT the piston will get hotter, faster than the cylinder will.
So you warm a 2T to get the heat into the cylinder and get it the right size, before you start putting load on the engine, or higher revs, that could make it nip-up.
Ref Marjays comments about 'blipping' the throttle on the RD, like 80's race bikes; 'questionable practice', that..... lots of people do it, becouse it sounds / feels good, and its what the racers did, but few actually know why they did it!
Reason was that very highly tuned 2T's often wont 'idle', and the carburation on a race bike is often not great, they dont like holding constant revs or part throttle. On the track, they dont have to very often, they're either cracked wide open accelerating, or completely shut off, while the bikes on the brakes.
So they would blip the throttle to keep them running, for starters.
Next up, race 2t's would often be over-cooled, built specifically to be ridden under hard load, they needed a lot of cooling to stop them overheating under power, so idling they'd often actually NOT get warm enough to stop them siezing.
But more importantly, they drank pre-mix, and it was usually quite a thin oil-ratio. Race bikes would run around 50:1 petroil, where your little strimmer motor might run as much as 25:1. Reason being that at high speeds, and loads, motor is sucking a heck of a lot more oil in with the extra fuel, so it doesn't need as much oil in the petrol to keep it lubed, and extra oil means less power and risk of oiled plugs. so they'd 'blip' the throttle to get the extra fuel, and hence lubricating oil, from acceleration enritchement into the motor, to stop them siezing whist warming up....
Standard road 2T, with oil injection shouldn't have any of those problems........ but still sounds cool and feels good!
None of which really answers the question, though, BUT.... reason I mention it, is becouse its entirely dependent on the bike.
Something like an MZ125 should pretty much run from cold.
Something like an Aprillia RS250, be worth letting it idle until the water-jackets warm.
Something like a tuned Suzuki X7, drinking pre-mix.... you'd need to know your bike and its foibles!
Rough reckoner? when it's warm enough to run cleanly and take load with the choke off.... that's when its warm enough.
HD
PostPosted: 13:34 - 26 Nov 2010    Post subject: Reply with quote
There you go Laughing
I read it all and I always do, does help a lot Karma
Paulington
PostPosted: 16:29 - 26 Nov 2010    Post subject: Reply with quote
I ran the SC125 and RS50 by turning it on, getting straight on it, getting out of the drive and then ragged it.
Did it for a year on the RS50 and about 3 months on the SC125, no problems.
The KDX200 is from 1989, that gets kicked over, out the drive and ragged, no problems.
The old superkart engine which was a CR250 and then a 250 Rotax (six-speed one) was started then ragged with no problems too, often rebuilt though as it was for racing.
The Rotax FR125 engine in my kart, that was also warmed up by one slowish lap whilst the tyres warmed up (~850m or so) and then ragged from there. Rebuilt every ~30 hours.
Maybe I'm just lucky with two strokes! Laughing!
HD
PostPosted: 16:48 - 26 Nov 2010    Post subject: Reply with quote
Or maybe we are just all faggots! I don't want to risk it though.
What I am going to do is go round the block once on mine, then go up the hill. The only way to get out of my 'district/area' is uphill.
Paulington
PostPosted: 16:54 - 26 Nov 2010    Post subject: Reply with quote
Now that's just mean. Wink.
I think the reason my two strokes lasted despite me ragging them was the fact they were all properly cared for in the best way possible with the best oil all the time etc.
Since I was racing two strokes at the time we knew them inside out in terms of maintenence so whilst they were ragged they were checked often, compression checks, peek at the cylinder and look for any signs of wear, the best oil and plugs you can buy so it wasn't ragged and not maintained like most two strokes nowadays. They were also rebuilt far before they'd have seized/scored the barrel through neglect.
There just isn't a need to over-do it when it comes to 2-strokes, I hear people saying you should warm them up for 15-20 minutes before you rag it and it's all crap in my opinion, as someone as said, as soon as it goes without choke, it's ready!
Al
PostPosted: 18:21 - 26 Nov 2010    Post subject: Reply with quote
With the air cooled Vespa I just start and go, It needs the choke to start when cold but won't idle with it on, then runs fine without choke.
Normally take it easy for the first couple of miles, which is hard on a vespa as you need to be a bit aggressive with it just to maintain a normal speed Smile
Yamaha FZR400RR 3tj
My Instagram Thingy
27cows
PostPosted: 18:40 - 26 Nov 2010    Post subject: Reply with quote
10 seconds of choke and away we go on the RXS. Lesser strokers can be fickle. Had a 350 Powervalve once that used to need a full two minutes on choke and then about five minutes of throttle restraint before it would rev cleanly. LC500 was a fucking nightmare in the really cold weather. Sometimes it wouldn't warm up properly even after a reasonably long ride.
H1 would stutter and grumble for ten minutes and then suddenly launch into a massive power surging wheelie. Great fun on icy roads Shocked Death trap, but a hugely entertaining one.
Stroker motors only work as small singles for everyday use. Bigger engines are OK for race/competition use, crap for the road.
PostPosted: 18:56 - 26 Nov 2010    Post subject: Re: Stroking a smoker Reply with quote
Overkill.
My TZR gets however long it takes to shut a garage door at idle. I keep it below 5,000rpm until it's up to temp.
HD
PostPosted: 19:07 - 26 Nov 2010    Post subject: Reply with quote
May want to check t'other thread in the workshop but what plug did you use in your rs?
And by maintenance how can you look at the cylinder and stuff without taking it apart?
And how do I do compression checks on a Derbi Senda? Confused
I am keen to make mine reliable, not another chavvy 16 year old Derbi...
Thanks Very Happy
Glenben92
PostPosted: 19:42 - 26 Nov 2010    Post subject: Reply with quote
didn't notice that! well... i did but i have a very short attention span Shocked i'd still recommend a similar sequence, but as you say, being MORE gentle
Whosthedaddy
PostPosted: 20:17 - 26 Nov 2010    Post subject: Reply with quote
I am really surprised at the replies so far. I had previous conceptions that it seemed to take an age before moving off?
Sounds like my Yamaha 2t scooter in Oz.
Although it had no choke starting was fine but it would not idle correctly at all, really lumpy and cutting out after a minute or so. When warmed up it ran and idled as sweet as a nut. Only downside on the journey in the mornings were stopping at the copious lights, kept having to blip it like a chav to stop it from cutting out.
Pernig
PostPosted: 22:45 - 26 Nov 2010    Post subject: Reply with quote
When I start my H100 up I put the choke, the revs go up to about 3k, then slowly down to 2k. Once it is idling at 2k with the choke on it will idle at just under 1.5k without. Doesn't take long at all. I just give it a few revs and let it idle for a minute or two.
If I try and thrash it from cold it won't go any higher than 4k until it is warm, but if I ride off slowly and keep it under 4-5k for about a mile (which takes one and a half to two minutes) it is nice and responsive.
H100 Breaking for spares
hmmmnz
PostPosted: 23:43 - 26 Nov 2010    Post subject: Reply with quote
HD wrote:
What bike is it?
an old kh125 and a 67vespa they both get the same heavy handed treatment from me
the humans are dead
reggie
PostPosted: 01:32 - 27 Nov 2010    Post subject: Reply with quote
i start my rx 154 and drive of straght away i dont go past 7k til its at at atleast 65C
when the shit hits the fan make sure its facing the other way.
covduude This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 08:03 - 27 Nov 2010    Post subject: Re: Stroking a smoker Reply with quote
Bear in mind that my bike has a stage 3 Stan Stephens tune, and various people on here refer to him as Stan Seizeums. Also, I rarely ride it and so always treat it very gently when I get it out.
PostPosted: 11:55 - 27 Nov 2010    Post subject: Re: Stroking a smoker Reply with quote
Does treating it very gently defeat the object of having the stage 3 tune?
Out of interest, how much power is that producing?
Welshd1k
PostPosted: 12:13 - 27 Nov 2010    Post subject: Re: Stroking a smoker Reply with quote
ms51ves3 wrote:
[quote="MarJayBear in mind that my bike has a stage 3 Stan Stephens tune, and various people on here refer to him as Stan Seizeums. Also, I rarely ride it and so always treat it very gently when I get it out.
Out of interest, how much power is that producing?[/quote]
an ypvs with pipes and a tunne maby 70 ish
The last post was made 15 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 144.83 Kb
