Advice on 2 stroke mopeds (Newbie)
GREENI3
PostPosted: 20:35 - 26 Nov 2010    Post subject: Advice on 2 stroke mopeds (Newbie) Reply with quote
I was thinking about buying a Suzuki AY 50 K3 and was wanting to find out basic information about a 2 stroke engine. How to maintain it? How many miles before it needs an engine rebuild? How many miles can it do on a full tank? That sort of stuff. Also if anyone knows any information about the Suzuki AY 50 that would be a great help too.
Thanks
JD-234
PostPosted: 11:59 - 27 Nov 2010    Post subject: Reply with quote
wont really need an engine rebuild you dont full throttle every wear and use good oil and change the spark plug every few month
rs50 ftl. Engine rebuild by the time you get to the bottom of your drive
connornrg
PostPosted: 17:02 - 27 Nov 2010    Post subject: Reply with quote
i was given one once and no matter what could not get it above 34mph :/
Bikes (Not Bikes Really Just Shitty Mopeds)
**04 - Piaggio NRG MC3**02 - Yamaha Aerox 50/100**07 - Piaggio NRG Power - Shit.**
dextersaurus
PostPosted: 19:24 - 27 Nov 2010    Post subject: Reply with quote
which is faster than you should be doing at 16 anyways.
Dunc
dextersaurus
PostPosted: 19:36 - 27 Nov 2010    Post subject: Re: Advice on 2 stroke mopeds (Newbie) Reply with quote
How to maintain it?
see the bit called 'the workshop'?, post in there, plenty help available. don't post anything about de-restriction. you'll get the piss taken out of you.
around 15k-20k miles i'd say, just to be safe. will most likely do a hell of a lot more than that. Big difference paying £30 for a piston& rings and £120 for a rebore though
about 80-90 miles - 6.8L tank, 70mpg
https://www.reviewcentre.com/info-7692.html
i've never owned a 50cc 2t, don't quote me on anything... just what i'm assuming from the fact that they're all the same.
Dunc
binge
Emo Kiddy
PostPosted: 21:12 - 27 Nov 2010    Post subject: Reply with quote
Cant be bothered to look it up, but If I'm right in thinking the AY50 is a Suzuki Katana moped, Then they are really cool scooters.
Dead quick off the line as they are fairly light. They are electronically restricted via the CDI as well as a restrictor in the variator and exhaust.
Dam_Buster had one years ago when I had my speedfight. We fitted a bigger carb, 70cc MHR Bore kit, Leo-Vince ZX exhaust, lighter rollers etc. And although it accelerated extremely quick for a scooter, it still would not pass 45mph, Where as my Speedfight with a similar spec was capable of over 60mph.
Ben
Teflon-Mike
tl;dr
PostPosted: 01:56 - 28 Nov 2010    Post subject: Reply with quote
https://s178.photobucket.com/albums/w269/teflons-torque/050_B_001_Motor/twostroke.gif
https://s178.photobucket.com/albums/w269/teflons-torque/050_B_001_Motor/Arbeitsweise_Zweitakt.gif
The 2-Stroke Engine
JD-234
PostPosted: 21:49 - 28 Nov 2010    Post subject: Reply with quote
How can you see how a powerband works from that diagram
blurredman
PostPosted: 22:06 - 28 Nov 2010    Post subject: Reply with quote
JD-234
PostPosted: 22:55 - 28 Nov 2010    Post subject: Reply with quote
LOOL Thumbs Up
Livefast123
PostPosted: 11:33 - 29 Nov 2010    Post subject: Reply with quote
I had a liquid cooled Suzuki Katana (AY50 WR) for a number of years, bought it new in 2000. Used it to commute to work and never had an ounce of bother. The liquid cooled ones are much better.
Fitted a Malossi 70 kit, uprated Delorto carb, Malossi gear up kit, Leo Vinci ZX exhaust, variator kit and springs and then had it set up by Taffspeed in Newport on the Dyno. To be fair it then went like a 100m sprinter on steroids. Went off the clock downhill and would cruise at 50 - 60 real speed without issue. Luckily they have decent rubber for a scoot and the brakes.......well i stopped.
It's different to the usual peds out there and cheaper although doing any of the above will have licence implications for you and will be illegal. I had my full licence and just fancied seeing what i could create Thumbs Up
Current ride - Yamaha MT-07
t101
PostPosted: 03:27 - 05 Dec 2010    Post subject: Reply with quote
runner 125 sp - pretty much the only ped worth it. someone WILL steal it though.
PostPosted: 06:59 - 05 Dec 2010    Post subject: Reply with quote
And how exactly does that information help a 16 year old choose his <50cc transport?
TheManWithThe...
PostPosted: 21:34 - 12 Dec 2010    Post subject: Reply with quote
Im 16 and riding a 2 stroke MBK nitro (Yamaha Aerox). As said before, just keep it topped up with good quality 2-stroke oil (Castrol etc) and everything should look after itself (unless it overheats, or you buy a shed) id recommend liquid cooled as well...just to make sure it doesn't over-heat.
mines an 03 plate on 4000 miles, about 700 of those are mine, so id hope it doesn't need a re-build during the time i have it.
mine does about 100 miles on a 8 litre tank (costs roughly £7 to fill it up fully), although full throttle for sustained periods destroy the efficiency Confused
MBK Nitro 50, Sold. Kawasaki ER-5, Honda ST1100
"Anyone can jump a motorcycle! The trouble begins when you try to land it..."
GREENI3
PostPosted: 21:50 - 12 Dec 2010    Post subject: Reply with quote
Ye, I bought the Suzuki in the end. 22k on the clock, but had a rebuild at around 20. Got the seat off and had a good look at the engine and everything looks pretty good. Thumbs Up Put a bit of oil on all the connections e.t.c. Only downside was that the seat lock has half a key stuck inside so I have to get that sorted out before I can take it out for a ride. 12 months tax and mot for 300 quid, I thought was a good deal. I reckon it's still got a lot of life still left in it yet.
andym
PostPosted: 02:06 - 13 Dec 2010    Post subject: Reply with quote
I got a moto roma wasp in me garage, derestricted (I think), would do 58mph (downhill with a tail wind though), would happily sit at 45-50, just that I traveled about 54 miles a day and figured I was killing it as I was full throttle all the way.... mind you.... it never seemed to bother.
I was always told 2 strokes are very unreliable.... I got mine as a non runner.... changed the fuel lines, scrubbed the carb, topped it up and it ran fine since.
Mind you... they look like shit
The last post was made 15 years, 84 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 111.89 Kb
