| HD |
 HD World Chat Champion
 Posted: 22:50 - 28 Nov 2010 Post subject: What damage can a top end bearing do? |
Okay so I have rebuilt my bike (details here)
Basically there is a ticking noise at very low revs on my bicycle. As soon as I rev it, it goes.
While rebuilding the bike, we didn't do the top end bearing. As far as my dad could tell, the bearing was fine.
Still not 100% it is that. Could just be the exhaust being a bit tinny while ticking over but yeah.
So:
a) what else could it be?
b) what damage would it do if it has gone?
Thanks guys  ____________________ Rusty '02 Vito Camper + CBR600F3 |
| Raffles |
 Raffles World Chat Champion
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 23:04 - 28 Nov 2010 Post subject: |
derbi senda? yeah right.
hard to tell. could be a lot of things. can you get a recording?
future reference as a matter of course, if you're replacing the piston you may as well replace the bearing to avoid things like this for the sake of about £3. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| HD |
| MaybeGuy |
 Posted: 23:15 - 28 Nov 2010 Post subject: |
sounds like it could be idling a little too low? its possible...
2 strokes arent the quietest engines anyway.
tappets are on 4 stroke engines. hence why that guy is a div. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| fiery tupp |
 fiery tupp Trackday Trickster
| HD |
| MaybeGuy |
 Posted: 23:22 - 28 Nov 2010 Post subject: |
yeah, it should be idling at about 1500-2000rpm. not close to dying. try and find videos on youtube and make it sound like that ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| HD |
| Raffles |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 15:59 - 29 Nov 2010 Post subject: |
Its a 50cc two-stroke. Little end bearing, if it let go, could seriousely mash the engine.
Without the rollers in teh con-rod little end, conrod stands to get bent or broke, hardened rollers are likely to get into the ports, get dragged between piston and bore; snag in the bottom end bearings.....
Ie: can make a pretty nice mess of the whole shibang......
Worst case..... might do no more than make some nasty noises, and leave some debris in the crank-case..... you never know.
BUT, I suspect the noise is knocking.
You made comment about how its been semi-de-restricted, and you haven't messed with the carb.
Tune a bike, to makle more power, its going to need more petrol in the charge to make the extra power.
Tuning it, so it can drag more air in, without re-jectting will normally result in more air, same petrol hence a weak mixture, and that leads to funny knocking noises, known as 'knock'; or pre-ignition.
If your getting that at idel..... dont ride the damn thing! Put it under load and its likely to go incredibly weak and start melting pistons.
I think its back to your original connundrum of getting the jetting right for the mods you've made......
But I haven't heard it so could be barking up the wrong tree. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| MaybeGuy |
 Posted: 17:13 - 29 Nov 2010 Post subject: |
| Teflon-Mike wrote: | Its a 50cc two-stroke. Little end bearing, if it let go, could seriousely mash the engine.
But I haven't heard it so could be barking up the wrong tree. |
however... if a bike is set to idle as close to dying as he says it is, then it'll knock a fair bit as the engine runs unevenly and not carrying momentum. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Blue_SV650S |
 Blue_SV650S World Chat Champion
| HD |
 Posted: 19:35 - 29 Nov 2010 Post subject: Re: What damage can a top end bearing do? |
| Blue_SV650S wrote: | If a little end bearing goes, it tends to throw its bits about, this will invariably take out one or more of the following:-
1.the piston&ring/s
2. the bottom end
3. the con rod (little end eye)
4. the barrel
5. pockmark the head
A rattle on idle that clears with revs does sound like little end.
How did your dad inspect to deem the little end OK? |
Uh oh. And err, not too sure really. Speak to him tonight and ask him.
And as promised; the videos:
Warming Up - here
After a little bit of a run - here
And on a little run to see if this helps at all? - here
This is the noise so you lot can have a better guess.
If possible Matt, can I drive round yours on Friday to let you have a quick look?
Thanks gents  ____________________ Rusty '02 Vito Camper + CBR600F3 |
| MaybeGuy |
 Posted: 19:47 - 29 Nov 2010 Post subject: |
from the video i'd say it sounds pretty sweet. can you pick out the sound you're hearing from the video?
after reading your older thread, i'd say you're being a bit hopeful about the bike.
it's only a 50cc. 20mph up a hill sounds about right. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| HD |
 Posted: 19:50 - 29 Nov 2010 Post subject: |
The sound from say 0:08 in the first bit. there is the usual sound then a tapping
And really? Thats shit cos everywhere around me is hills Guess Ill just have to get onto the flat then! ____________________ Rusty '02 Vito Camper + CBR600F3
| MaybeGuy |
 Posted: 19:51 - 29 Nov 2010 Post subject: |
ah right. didnt watch the first video.
then again im on laptop speakers.
also, is that keyham? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| HD |
| MaybeGuy |
 Posted: 20:00 - 29 Nov 2010 Post subject: |
the less you run it, the more likely you are to be able to get away with re-using the base gasket if you do need to do the small end. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| HD |
| MaybeGuy |
 Posted: 20:17 - 29 Nov 2010 Post subject: |
if its the small end, it'll cost you a base gasket and a bearing. possibly a gudgeon pin.
why waste £15 on a full set when you dont need to?
impossible to tell for definate from a video. sounds about right with the tapping from the top end in my experience though ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| HD |
| MaybeGuy |
 Posted: 20:22 - 29 Nov 2010 Post subject: |
mechanics and garages are fucking scum. dont do that, unless they just listen and dont charge you.
i could have a look i guess, but not at my house like you suggested before. i could do without some cumslut nicking my bikes ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| HD |
| P.addy |
 P.addy Red Rocket
The last post was made 15 years, 329 days ago. Instead of replying here, would creating a new thread be more useful? |
