clutch sticking, think it may be frozen?
gazz hough
PostPosted: 00:01 - 04 Dec 2010    Post subject: clutch sticking, think it may be frozen? Reply with quote
as far as mechanics go, i'm thoroughly useless.
recently, due to the weather being on a bastardly-cold level and my garage having the insulating skills of an injured pidgeon , my clutch has started to stick fully outwards. I can manage to squeeze it in with a bit of force, but then it doesn't spring back out.
i think it's probably to do with it being cold and the lubrication freezing, could be wrong though.
just want to know if it is what i suspect and how to overcome it, are there any blankets or anti-freeze stuff that i could buy to stop it happening?
yer ma's got a skinhead and collects footy stickers
fiery tupp
PostPosted: 00:27 - 04 Dec 2010    Post subject: Reply with quote
It could just be the cable freezing or damaged ? Confused
If you can't fix it with a hammer , use your head .
rob_scott92
PostPosted: 00:50 - 04 Dec 2010    Post subject: Reply with quote
If it is iced up, perhaps take a hair dryer to the cable? Should help loosen it up a bit i would have thought Wink
Dont suppose you've ever lubed the cable? Could be an idea, i've never done it myself but if you use the clutch when its 'solid' like it is now, it WILL snap eventually. I should know, i had this on my 125. Its not particulary fun riding in the middle of town with no clutch i tell ye! Laughing
First bike: 1982 Suzuki Gs 125 'The beast MK1' Wink > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p
nsr_J22_FOXEYE
PostPosted: 01:13 - 04 Dec 2010    Post subject: Reply with quote
You just "slam" her into gear?
Never Ride Faster Than Your Angel Can Fly
gazz hough
PostPosted: 09:27 - 04 Dec 2010    Post subject: Reply with quote
i'm not sure if it's the cable or the actual mechanism, i'll pull it in, but then it will stay in and the clutch lever will be dead loose and floppy and the clutch stays behind biting point.
dodgydog
PostPosted: 10:19 - 04 Dec 2010    Post subject: Reply with quote
Sounds like the cable seized up.
easy enough to just disconnect it at both ends, then get some oil worked into it to free it.
Dog
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
Suntan Sid
PostPosted: 11:41 - 04 Dec 2010    Post subject: Re: clutch sticking, think it may be frozen? Reply with quote
When I were a nipper my dad had a paraffin "sump heater", similar to this:-
https://www.tfmsuperstore.co.uk/product.lasso?product=Anti-Frost-Sump-Heater.-Parasene.+11537
You filled it up, lit it and let it burn under your car overnight in cold weather. Surpised there weren't more garage fires to be honest. Laughing
Apparently they did the the trick! You could leave one burning in your garage, not neccessarily under your bike, it would keep the frost out!
gazz hough
PostPosted: 17:00 - 04 Dec 2010    Post subject: Reply with quote
just checked it, it's thawed out now.
just need to find a method to keep it warm, will probably find some old blankets or something and whack them over the bike.
was thinking of a cover, but i don't see how a sheet of thin plastic will keep the cold out.
dodgydog
PostPosted: 18:38 - 04 Dec 2010    Post subject: Reply with quote
Could still be worth getting some lubrication into the cable.
It's freezing up because it has water in it......get some oil in there to prevent it.
Dog
dodgydog
PostPosted: 18:40 - 04 Dec 2010    Post subject: Re: clutch sticking, think it may be frozen? Reply with quote
Blimey, didn't know they still did them, I had one under my Vauxhall Victor the last time it was this cold (about 1978)
As you say, surprised it didn't set the car alight.
Dog
The last post was made 15 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 72.41 Kb
