ZX6R running problems
ride_to_die
PostPosted: 13:59 - 14 Dec 2010    Post subject: ZX6R running problems Reply with quote
my 02 636 ninja has been cutting out sometimes. Sometimes it starts other times it doesn't. On occasion, when you turn the key nothing happens, no lights, horn or even the needle sweep. When it does start, during riding, the revs drop to about 3k and then the bike cuts out, i've tried gassing it when the revs drop, sometimes it just cuts out other times it comes back to life.
The bike is used all year round. I use Pro FST in every tankful. I've checked the fuses, side stand switch and some connectors. They all seem ok. The battery is regularly plugged into a conditioner and is only 4 months old.
I'm at my wits end as this is the last thing i need this time of year with being skint as it is.
Any ideas/suggestions?
Thanks,
Sam.
I'm not here for a long time, I'm here for a good time.
mad4it028
PostPosted: 14:10 - 14 Dec 2010    Post subject: Reply with quote
i once bought a bike sold as spares or repairs with the exact symptoms
for me it turned out to be a loose earth strap
Barry_M2
PostPosted: 14:37 - 14 Dec 2010    Post subject: Reply with quote
This is also the first thing I would check with the symptoms you mention.
Next, electrical connectors.
It will be an electrical problem, not a fueling issue.
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
ride_to_die
PostPosted: 14:41 - 14 Dec 2010    Post subject: Reply with quote
Thanks for the replys guys, hopefully its something simple. Whereabouts on the bike will the earth strap be?
Barry_M2
PostPosted: 15:49 - 14 Dec 2010    Post subject: Reply with quote
You'll need to check the battery terminals are tight, then try and follow the thick black wire from the negative terminal and see where it earths on the frame. It's usually only around 5-6 inches long.
There may also be an earth strap from frame to engine. Kawasaki like to earth them on the top of the gearbox (under carbs area).
c_dug
PostPosted: 16:55 - 14 Dec 2010    Post subject: Reply with quote
Also why the pro FST stuff? Surely it doesn't suffer carb icing since it doesn't have carbs Laughing
ride_to_die
PostPosted: 17:00 - 14 Dec 2010    Post subject: Reply with quote
The battery terminals are tight. I'll trace the wire from the negative and see if its ok.
c-dug: Its the first 636(A1P) which has carbs Thumbs Up
The last post was made 15 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.32 - MySQL Queries: 13 - Page Size: 53.69 Kb
