Full Throttle problems ?
X9-rider
PostPosted: 01:31 - 17 Dec 2010    Post subject: Full Throttle problems ? Reply with quote
When riding the bike at full Throttle, be flat out or accelrating from stand still, if Throttle is fully open the bike shudders and feels like its about to cut out, and lose power, but if i leave it at half Throttle everthing is fine regardless of down hill, up hill low speed or high speed, it appears the bike is having problems with the Throttle been full open.
Any ideas ?
Nixon
PostPosted: 02:13 - 17 Dec 2010    Post subject: Reply with quote
I have just checked with the met office, but I still don't understand what "full throtal weather" is, is it worse than snow and ice?
Relentless This post is not being displayed because the poster is banned. Unhide this post / all posts.
nsr_J22_FOXEYE
PostPosted: 11:01 - 17 Dec 2010    Post subject: Reply with quote
Check you air filter is fully connected with no extra way for air to get in other than standard, If that is ok check your exhaust is fully connected with no gas escaping before the end can
Never Ride Faster Than Your Angel Can Fly
PostPosted: 11:03 - 17 Dec 2010    Post subject: Re: Full Throtal problems ? Reply with quote
X9Travels wrote:
When riding the bike at full throtal weather flat out or accelrating from stand still, if throtal is fully opent he bike shudders and feels like its about to cut out, and lose power, but if i leave it at half throal everthing is fine regardless of down hill, up hill low speed or high speed, it appears the bike is having problems with the throtal been full open.
Any ideas ?
Throttle
Whether
dextersaurus
PostPosted: 12:41 - 17 Dec 2010    Post subject: Reply with quote
See that wee button under the box you typed in?
Yeah, that one! that one that says 'spell check'.
Will save you looking like a knob.
As already said, sounds like it's running rich/lean.
Give that carb some lovin'
X9-rider
PostPosted: 13:23 - 17 Dec 2010    Post subject: Reply with quote
sorry about my start post forgive me i'm dylecicx and been late i didnt run the post via the softwere i normally run it via.
anyways i check exhaust all is good, and Air filter is tight and good and air filter its self is clean inside.
Mite do as suggested in clean the carb out, but anything els ?
Acemastr
PostPosted: 13:46 - 17 Dec 2010    Post subject: Reply with quote
Dyslexia... a fake 'disorder' created to make stupid people feel better.
2016 Toyota Tacoma Limited
dextersaurus
PostPosted: 14:16 - 17 Dec 2010    Post subject: Reply with quote
Not clean it out.
More check the mixture is right, make sure it's not too lean/rich.
that, or get rid of that thing and buy a bike Wink
nsr_J22_FOXEYE
PostPosted: 15:37 - 17 Dec 2010    Post subject: Reply with quote
when did it start happening? did you change anything before hand? how long are you letting her warm up for? and have you got a few pound to get a new spark plug?
hornetmike
PostPosted: 21:12 - 19 Dec 2010    Post subject: Reply with quote
what bike is it ?
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
Ol
PostPosted: 16:03 - 20 Dec 2010    Post subject: Reply with quote
Last i remember he was on a CG and had ditched the glorified peds ???
as above, sounds like a fuelling issue to me, check fuel filters clean maybe?
dextersaurus
PostPosted: 17:44 - 20 Dec 2010    Post subject: Reply with quote
Well if it's a CG, that's simple.
Had exactly the same when i bought mine, was due to it running too rich, and flooding it/wetting the plug rather than firing.
There's a wee screw under the carb you can get to if you use a small screwdriver.
Use that to change the fuel/air mix, and get it running properly.
Dunc
X9-rider
PostPosted: 18:12 - 20 Dec 2010    Post subject: Reply with quote
Bike i own is in my Signature.
check the mixture is right....well i am not quite sure how to do it on a Piaggio engine.
The bike has a auto-choke, its at 2,000rpm then atter 30 secs the auto choke comes off and drops to 1,400rpm and then i get on a ride off.
So its fully warmed up, i was at snakes pass yesterday and it tempoary stoped shuddering and once off the snakes pass ( -10 ) and on to the dule carriagway it did 75mph with out struggling.
Spark plug gap checked and is fine and is in good condtion, not white not black but a nice dry light brown.
checked the belt, that looks heathy, and the oil is a nice clear with brown tint but feels weak, but dont see how that could effect top speed and shuddering.
As for Acemastr, Middle Finger
I'am not awear that the piaggio X9 has a fuel filter, i know it has a fuel pump.
Mind you this bike is now 10 yrs old. could it be old age ? its only done 18,700 miles
Fisty
PostPosted: 18:36 - 20 Dec 2010    Post subject: Reply with quote
The shuddering is to stop you falling asleep on it. Again.
Fatter and faster than Fret
X9-rider
PostPosted: 18:58 - 20 Dec 2010    Post subject: Reply with quote
Trust me that will never happen again Laughing Learn the hard way first time and never again Smile
scince last post i been thinking....... Could the Rollers have anything to do with this shuddering?
Codemonkey
PostPosted: 19:05 - 20 Dec 2010    Post subject: Reply with quote
Could it be fuel starvation ? Maybe the breather in the fuel filler is blocked with ice. Try opening the filler cap to see if the problem goes away.
X9-rider
PostPosted: 19:18 - 20 Dec 2010    Post subject: Reply with quote
fuel starvation is one feeling i would say it is. But the fule pump looks good.
the breather is under the Tank hidden away, its nice to ride but a shit of a heap to work on, as everything is enclosed.
after reading comments i would conclude ither its :
Rollers have Flat spots
fuel starvation
running too rich
mixture is not right
Got an impact wench mite check rollers.
Stalk
PostPosted: 19:38 - 20 Dec 2010    Post subject: Reply with quote
It's not that strange problem known as carb iceing is it? Just a suggestion as I have no direct experiance of this. (In other words' it's never happened to me)
Stalk.
X9-rider
PostPosted: 22:25 - 20 Dec 2010    Post subject: Reply with quote
carb icing ....someone explain that one, i heard in a review of the the 2001 X9 that i ride suffers from carb icing.
All 2001 Piaggio X9s had the carb icing issue till 2004 models where it was solved i belive.
X9-rider
PostPosted: 22:30 - 20 Dec 2010    Post subject: Reply with quote
just googled carb icing, no it cant be that as it was doing this in summer weather conditions.
Noxious89123
PostPosted: 01:13 - 21 Dec 2010    Post subject: Reply with quote
Carb icing usually causes problems when you stop after a long time with the throttle open, and the bike won't idle. So it doesn't sound like it'd be that anyway.
The last post was made 15 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 2.52 - MySQL Queries: 13 - Page Size: 127.11 Kb
