Respray Question
Vman
PostPosted: 17:34 - 10 Jan 2011    Post subject: Respray Question Reply with quote
How much should I be looking at to have a bike resprayed professionally? The bike only has a fairing around the cockpit and plastic covers and a little plastic at the rear, front mudguard and tank. I'm Hampshire based, so would be delighted to hear of any sprayers near(ish) to me that you would recommend. I'm after matt black by the way,
Thanks in advance.....
Marmalade
PostPosted: 18:33 - 10 Jan 2011    Post subject: Reply with quote
Matt black? get the cans out and save yourself a wedge.
Pull it apart, sand it a bit, primer and a few good doses of matt black and you've got your very own 2 wheel blackboard
I'm waiting for a couple of warmer days as i have a panel i need to spray, failing that i'll stick a heater in the shed and do it in there
Vman
PostPosted: 19:38 - 10 Jan 2011    Post subject: Reply with quote
Thanks for that, but I'd prefer to have a non-fecked up job done! Not overly happy with doing it myself, I want a really good finish!
PostPosted: 20:25 - 10 Jan 2011    Post subject: Reply with quote
If you do it yourself and nob it up, it'll cost you the same to get it done professionally anyway.
It's really not that hard, even with rattle-cans. You just need to be patient. I'll tell you more ... later.
Shaft
PostPosted: 21:33 - 10 Jan 2011    Post subject: Reply with quote
Since I run a bodyshop, I can give you a rough idea, but I don't know if painters who specialise in bikes (we do cars, but we've done a couple of bikes recently) have lower labour rates, mechanics certainly seem to.
The major part of any respray is the preparation, typically this takes around 1-1.5 hours per panel, more if there are repairs to be done or if it's a complicated shape, such as a heavily shaped tank.
Any areas of bare metal or dubious quality paint will then need to be stabilised and primed, which then needs further preparation, before the top coat goes on.
The actual final finish takes about an hour.
It seems you've got 5 panels, so allowing a bit to be safe, that's around 10 hours of work, including painting; at my rates, that would be £350.
Add to that about £100 paint and materials and you end up with £450+ VAT.
As I say, bike painters might be cheaper on labour and that doesn't include any specialised work/materials, such as repairs or plasticisers, which you may have to use if any of the panels are subject to a large amount of flexing.
One thing I would say is, if you want a near perfect matt or satin black finish, preparation is doubly important, as is a dust free environment to paint in; if you get particles of dust or imperfections in the finish, you can't polish them out as you would with gloss, the only option is to flat down and paint again.
That won't bother some painters, but some might charge you extra simply because you don't want a gloss finish, because it means they have to get it perfect from the gun.
Hope that helps.
Vman
PostPosted: 21:53 - 10 Jan 2011    Post subject: Reply with quote
Great reply, thanks for that, I've just found a fella in Fareham which is just down the road from me, I'll give him a ring tomorrow. That price seems fair enough for a quality job. I don't think I'd get the prep right and just screw it up and be really disappointed.
Shaft
PostPosted: 22:33 - 10 Jan 2011    Post subject: Reply with quote
You're welcome.
I know a lot of people think painting is some kind of black art, but it's actually worth doing some experimenting, you can get some very good results using spray cans.
If you take your time, use the right equipment and take some care with the environment, there's no reason why you can't do it yourself.
You might want to try getting hold of some scrap panels and having a go.
Shaft
PostPosted: 16:27 - 12 Jan 2011    Post subject: Reply with quote
A little further thought on this:
I was chatting about this to my painter earlier and his main concern was getting a perfect, dust free finish, using matt/satin colours.
He suggested a vinyl wrap, which any decent signwriter should be able to organise.
Probably wouldn't be much cheaper than a respray, but it could be another option.
PostPosted: 18:14 - 12 Jan 2011    Post subject: Reply with quote
I think so anyway: this is a rattlecan job:
https://img196.imageshack.us/img196/8788/paintedbike.jpg
White undercoat, metallic bronze, lacquer, job's a good 'un. The artifact on the side panel is a reflection, not a blemish. Smile
Louise
PostPosted: 19:26 - 12 Jan 2011    Post subject: Reply with quote
I started to rattle can the R1 but gave up after the two lower fairings too forever to get right.
Im looking at £400 for two colours.
Shaft
PostPosted: 21:41 - 12 Jan 2011    Post subject: Reply with quote
Looks good Roger Thumbs Up
One thing I will say is (and this is not a criticism) is that it slightly lacks the depth you get from a gun, which is one of faults of aerosols, due to the paint being very thin.
I've got some old RD250 panels lurking in my garage and, prompted by this thread, I'm thinking about doing a 'how to' guide, detailing a few of the dos and don'ts of home repairing/spraying, if anyone thinks that might be useful?
StevenF
PostPosted: 02:41 - 13 Jan 2011    Post subject: Reply with quote
It would be very useful, please do! I did my car trim a couple of years ago and it was hard work (mostly due to the textured bumper). The biggest thing was the time and patience needed! I don't have much of that... and the fact I was doing it in my garage.... where I had been sanding the body work. Turned out not too bad though!
Phoenix
Twisted Firestarter
PostPosted: 03:00 - 13 Jan 2011    Post subject: Reply with quote
I like the colour but a picture like this really doesn't remotely show how good a paintjob is, even the worst rattle can job can look fine from a distance. At this distance it's clear that the paint is not finished in any way, not rubbed back and polished and/or possibly a high gloss finish paint used with gloss lacquer which usually then goes matt.
Its when you look even slightly closely at a rattle can job that the poor quality shows, i've yet to see one which doesn't look terrible, may look fine at 10 metres, at 2 it's awful. It is possible to get a good finish though with aerosol cans, I just think the type of people who use them can't be bothered to try. I've managed to get a smooth and high gloss finish on panels before and it really isn't that hard, I'll do a whole bike one day and see how it weathers.
ZRX61
Victor Meldrew
PostPosted: 03:05 - 13 Jan 2011    Post subject: Reply with quote
It *should* be useful, however, it will probably turn into a huge pissing contest as has happened in the past when people with pro paint skills try to offer advice and/or knowledge etc.
They're not one night stands, they're auditions.
Frost
PostPosted: 06:54 - 13 Jan 2011    Post subject: Reply with quote
I've made rattle can paintjobs look spot on before, but it does take a lot of time and even some trial and error. Obviously you have all the prep work to do as usual, but i find rattle can paint needs lots of primer, and it has to be perfect. Even then the finish is crap once laquerd, so i usually put on loads and loads of laquer (5+ coats) then once that's hardened for a week or more i flat it down with some polish. On one bike i used Autosol to get the laquer completely flat, it seriously looked like it had just come out of a showroom Laughing
PostPosted: 11:11 - 13 Jan 2011    Post subject: Reply with quote
Sure, you won't get the same quality as a proper professional job, but you don't have to aim for that. I went with a metallic with a fair bit of sparkle, on the basis that as you get closer it catches the eye and distracts from the lack of genuine depth.
Anyway, it worked out well for me, and fitted my budget and the look I wanted. My point remains that if you've got the time and inclination, it's worth having go.
Phoenix
Twisted Firestarter
PostPosted: 18:17 - 13 Jan 2011    Post subject: Reply with quote
It's all about the finishing off like you say, you can save even a bad job with some effort. While I didn't attempt to use autosol for fear of it removing the entire lot with one swipe I did use wet and dry and rubbing compound on the final coat of lacquer, I also used about 5 coats so there was plenty of depth preventing me going through it especially on corners.
These are about the best shots I have of a VFR panel I sprayed to match the original scheme about 6 or 7 years ago using Halfords paint, a much better finish can be achieved with a proper rattle can supplier, Halfords paint and nozzles are rubbish.
It's still not great to see but the gloss is there and the smooth finish, none of this textured stuff, it's not like glass but with the better spray cans you can almost achieve that, it's the priming and wet n dry stage that get's it completely flat. I should point out the white section is original paint so is as good as you'd get.
https://i238.photobucket.com/albums/ff264/kiowan/Misc/DSCF0069.jpg https://i238.photobucket.com/albums/ff264/kiowan/Misc/DSCF0071.jpg
tutton
PostPosted: 20:01 - 13 Jan 2011    Post subject: Reply with quote
i disagree with your post about disagreeing good sir!
I dont see the point of a guide as its different for everyone, i watch other people and i just dont paint like them Laughing
ZRX61
Victor Meldrew
PostPosted: 23:50 - 13 Jan 2011    Post subject: Reply with quote
I wasn't refering to you, ya muppet. I did stick my oar in another paint thread yesterday after someone posted a bunch of bullshit about what to use.....
Shaft
PostPosted: 01:16 - 14 Jan 2011    Post subject: Reply with quote
Having read the other thread, I take your point.
I haven't got shedloads of time on my hands just now, so I could do without spending hours compiling a pictorial thread about something I've been doing for 30 years, only for it to be dissed by all and sundry, but I might do it when I'm not so busy.
ZRX61
Victor Meldrew
PostPosted: 01:49 - 14 Jan 2011    Post subject: Reply with quote
I usually just point them at tutorials on the web & leave them be Smile
tutton
PostPosted: 01:55 - 14 Jan 2011    Post subject: Reply with quote
lol tutorial for all
use a roller! so much easier Laughing
flat out the roller marks Wink
jokes.
ha i remember the days of paint threads and the flames,
ps i hate solvent basecoat, waterbase FTW
The last post was made 15 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 124.72 Kb
