Chains...
huskie69
PostPosted: 10:08 - 12 Jan 2011    Post subject: Chains... Reply with quote
As some of you may have read, I'm the proud owner of a Skyjet SJ125. I could fill an entire book with the list of problems it has but I've managed to keep on top of them since I've had it and it's only let me down about 20 times at the most Wink
During my weekend maintenance regime (I give it about 2-3 hours of TLC every weekend!) I noticed the chain was beginning to get slack again. I adjusted the tensioner nuts on the swingarm (it had already been done a few weeks ago) but one of the nuts just turns and doesn't seem to be doing anything - what is it actually doing? I could be completely wrong but I have an idea that the bolt is screwed into the rear axle, the position of the axle is then determined by tightening/untightening the nut on this bolt - am I close? What could cause it to fail?
Anyway, I went to my nearest bike mechanic this morning to see if he could remove a link for me. He said it was actually illegal and that I should really get a new chain (makes sense I suppose as the chain has expanded so much it's likely to jump teeth). He can get one and fit it for £35 - £20 chain and £15 labour. To me, that's not a bad price after reading other people quotes for labour on this site and it saves me the hassle. It's booked in for this afternoon, but is he likely to run into problems with the tension adjuster or is it just my lack of understanding on how the mechanism works?
'10 Skyjet SJ125-23 - Crashed Sad > '09 YBR 125 > '53 Suzuki SV650 - Died Sad > 2010 Suzuki VanVan 125 > '87 Yamaha FZ750 Sold > VTR 1000 FireStorm - Sold > Honda CB1000R
DrDonnyBrago
PostPosted: 10:26 - 12 Jan 2011    Post subject: Re: Chains... Reply with quote
If you are sure that one of the tensioner nuts doesn't do anything then it may cause a problem. Your understanding of how the tensioner works seems pretty accurate although they don't normally screw into the axle itself, normally just into a guide around it (yours very well could screw into the axle). If the tensioner bolt/nut has stripped then turning it wouldn't do anything. If this is the case then you can still adjust the chain etc but it will be trickier as you cannot use the adjusters.
In short, I'm sure I'd be able to do it so he can too, best bet is to warn him before, he may want to fix the problem at your expense and might moan a lot though.
Otherwise the price is very reasonable . Thumbs Up
Note: I'm not convinced that the law actually stipulates it is illegal to remove links, best not to anyway though.
huskie69
PostPosted: 10:32 - 12 Jan 2011    Post subject: Reply with quote
Thanks, I'll warn him before he starts working on it - don't want to piss him off as the other bike mechs around here are useless (they all seem more interested in trying to sell helmet polish and tube caps instead of proper stuff like actual tools!) and this guy seems like a decent bloke.
huskie69
PostPosted: 11:21 - 12 Jan 2011    Post subject: Reply with quote
Oh - and what should I be using for lube? I put it on the rear stand every night, turn the wheel and spray the whole chain in GT85 as I use it for my engineless bikes. Is there something better available?
DrDonnyBrago
PostPosted: 11:32 - 12 Jan 2011    Post subject: Reply with quote
Wouldn't use GT85, it's too thin to work properly and would likely just wash off any remaining lube.
You want a thicker oil so it stays on the chain. There are hundreds of purpose made chain sprays, oils, waxes etc that will cost a small fortune over the life of your riding career.
I however do as follows:
If the chain is dirty, or every 500 miles or so, clean the chain using paraffin (buy it from Homebase and B+Q - sold as lamp fuel - £5 for 4L), this is cheap and gets the crud off really well. Apply it with a p[aintbrush and a small pot, work the dirt out untilt eh chain looks clean, wipe it off with a rag or get the hose on it and wash it off. Let the chain dry and it is ready for lube.
For lube you can use any of the pricey sprays or like me, the cheapest engine oil you can find in whatever grade you can lay your hands on, it can even be used oil if you like (used oil makes your bike dirtier though). Using another paint brush, give the chain a good coating of engine oil on both sides of the chain, wipe the excess off with a rag and you are good to go.
I dont like chain waxes and spray oils, makes too much ju8nk stick to the chain, engine oil is fine but can fling off the chain a bit.
huskie69
PostPosted: 11:50 - 12 Jan 2011    Post subject: Reply with quote
Nice one. I had actually wondered if GT85 was too thin as it doesn't really seem to be doing much - probably goes a way to explaining why I've had chain problems Smile
I've got a kettenmax chain cleaner and use lamp oil to give it a clean every other week - works quite well and saves a bit of back ache!
I did consider using engine oil instead but as I'd never seen it sold in shops as chain oil (everything's in spray cans), I though there was a reason against it - if it's just due to it being a bit dirty, then bugger it - I'd rather have some dirt on my bike and save myself a bit of money in chain maintenance.
When I get my proper bike, a scottoiler will be top of the list of things to get.
mysterious_rider
PostPosted: 11:59 - 12 Jan 2011    Post subject: Reply with quote
illegal to remove links? BULLSHIT. how do you think you get the chains to fit in the first place? They always come to long so you have to remove a few links so you can actually fit it.
Your tensioner has rounded off. Im guessing its a bolt that pulls on the axle via a loop (imagine a washer around the axle. and the bolt is welded to it, so when you tighten it, it pulls on the swingarm forcing the axle to move back/forwards)
going to take a guess you adjusted it without slacking off the axle nut, causing too much strain on the adjuster...causing it to round off..
No big deal really, you can always buy a new one. Depending on the time you might get lucky and be able to fit one off another bike. should get a pic up?
Mark65
PostPosted: 12:05 - 12 Jan 2011    Post subject: Reply with quote
The chain tugs go over the rear axle or bolt, then the adjusters screw against the rear of the swingarm which in turn pulls the wheel backwards or when you slaken them it allows the wheel to go forward, when the tension and alignment is correct you lock them off woth the locking nut then tighten the rear bolt to secure everything. If your adjustment bolt is turning all the time its either at the end of adjustment, in which there will probably be no bolt sticking out or the threads could be stripped. the adjusters in the image are showing plenty of adjustment avaliable if they were on a wheel.
Mark
huskie69
PostPosted: 12:07 - 12 Jan 2011    Post subject: Reply with quote
I thought that too - but I went to 3 other bike shops in the area, all with a similar response - and none of them sell chain/link removal tools as there's not enough demand for them :S!!!
Yep Thumbs Up. Exactly that! On hindsight, it now makes perfect sense that the bolt has stripped - funny though that the manual doesn't mention loosening the axle before adjusting the tensioner - it's probably obvious to mechanically minded peeps but mechtards like me are a bit blind with things like this Smile
huskie69
PostPosted: 12:12 - 12 Jan 2011    Post subject: Reply with quote
Thanks for posting a pic Mark.
Someone should be writing a book for bike mechanic novices with pics like this so we can understand the concept of how it all works. I didn't know how an engine worked til I got my bike!
any takers?!!!
Mark65
PostPosted: 12:34 - 12 Jan 2011    Post subject: Reply with quote
We all have the learning curve to visit now and then Wink, i myself have picked up a lot of knowledge on these forums and thats what people are here for to help each other and post porn Twisted Evil , now do you really need the new chain or just adjusters?.
Mark
huskie69
PostPosted: 12:41 - 12 Jan 2011    Post subject: Reply with quote
These forums do provide about 90% of information I need, and I'm glad everyone's so helpful (and patient!)
Looks like both chain and tensioners need replacing - the tensioners have adjusted as far as they can.
If I get a new chain fitted - I'm pretty confident it won't be anywhere near as poor quality as the original plus the mechanic will do a better job than I could.
DrDonnyBrago
PostPosted: 12:51 - 12 Jan 2011    Post subject: Reply with quote
Fitting a chain is VERY easy mate, especially with a smaller bike where you can use a split link. Look into the price of a chain and sprocket kit on ebay etc, if the chain is worn the sprockets are probably knackered too; it is good practice to replace the whole lot as a set. If you buy your own, look out for a DID chain, they are good and quite reasonably priced.
DrDonnyBrago
PostPosted: 12:53 - 12 Jan 2011    Post subject: Reply with quote
any takers?!!!
https://www.dansmc.com/mc_repaircourse.htm
There is already one written Thumbs Up .
Ignore the Americanisms/christian BS and it is actually a REALLY good guide.
mysterious_rider
PostPosted: 13:03 - 12 Jan 2011    Post subject: Reply with quote
I'm shocked that the manual didn't say to slacken the axle nut off!?!?!!
Best thing you can do, go buy yourself a splitter
i have
https://cgi.ebay.co.uk/STANDARD-MOTORCYCLE-CHAIN-BREAKER-TOOL-MOST-CHAINS-/220597017187?pt=UK_Motorcycle_Parts&hash=item335c9b5a63
and its served me so well in the past, absolutely worth its weight in gold.
Make sure itll fit your chain though (the chain pitch)
Mark65
PostPosted: 14:14 - 12 Jan 2011    Post subject: Reply with quote
+1, I did my first over xmas, very straight forward, although the side float on the front sprocket is a bit disconcerting but its normal.
I tried an Afam C+S kit , x ring chain with gold plates, mainly as every one used did i thought i could let others know what a diff make is like at a similair price.
Mark
fiery tupp
PostPosted: 15:20 - 12 Jan 2011    Post subject: Reply with quote
We used to us , a hammer a masonry nail & a small socket to remove links on small bikes , filing the end of pins & knocking through one at a time . A little crude but it worked in emergencies Neutral
If you can't fix it with a hammer , use your head .
nightshaddow
PostPosted: 17:44 - 12 Jan 2011    Post subject: Reply with quote
this is the complete rear axle and tensioner system off the bike
https://img215.imageshack.us/img215/2224/spindle1.jpg
mysterious_rider
PostPosted: 18:01 - 12 Jan 2011    Post subject: Reply with quote
are the bolts replacable? Get them replaced if you can. Thumbs Up
if not, what will work is, where the nut has threaded put a larger nut over it (to act as a washer) and so it tightens further up the bolt, rather than trying to tighten on the threaded part. Just obviously don't overtighten. And only adjust with the axle nut loose.
nightshaddow
PostPosted: 18:15 - 12 Jan 2011    Post subject: Reply with quote
with a bit of work yes they are welded in but if you need to replace it will be easy enough to replace them
Glenben92
PostPosted: 18:59 - 12 Jan 2011    Post subject: Reply with quote
Am I the only person who thinks £20 will definitely be a non o-ring chain and will last about a minute?
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
Mark65
PostPosted: 22:39 - 12 Jan 2011    Post subject: Reply with quote
oh noes, what about sprockets?, cant see a £20 chain being o ring.
Mark65
PostPosted: 22:41 - 12 Jan 2011    Post subject: Reply with quote
Prolly clean a lot of that of with a drill and wire wheel , then paint, or replace if cheap enough.
The last post was made 15 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.77 - MySQL Queries: 13 - Page Size: 133.06 Kb
